Нашел реализацию от Espressif. Да, она существует, но в отдельной библиотеке аппаратного ускорения ИИ (dot product там у них и еще кой чего)
Сравнил аккуратненько все три реализации на буферах размером в 5 кбайт. ESP32-S3 240мгц, память - внутренняя, выровненная на 4.
memcpy() : 100000 cycles, 1354522 usec : 13.50 микросекунд на одно memcpy(Dst, Src, 5*1024)
esps3_memcpy() : 100000 cycles, 301953 usec : 3.01 --
dsps_memcpy_aes3() : 100000 cycles, 295768 usec : 2.96 --
Вот код dsps_memcpy_aes3 (создайте файл dsps_memcpy.S в каталоге с вашим скетчем)
* SPDX-FileCopyrightText: 2023 Espressif Systems (Shanghai) CO LTD
* SPDX-License-Identifier: Apache-2.0
#include <xtensa/config/core-isa.h>
#include <xtensa/config/core-matmap.h>
// This is memory access for ESP32S3 processor.
.text
.align 4
.global dsps_memcpy_aes3
.type dsps_memcpy_aes3,@function
// The function implements the following C code:
// void *dsps_memcpy_aes3(void *arr_dest, const void *arr_src, size_t arr_len);
// Input params Variables
// arr_dest - a2 loop_len - a5, a6
// arr_src - a3 p_arr_des - a7
// arr_len - a4 div_48 - a8
// align_mask - a9
esp32s3 optimized memcpy function works with both, aligned and unaligned data.
arr_dest aligned --> - _main_loop_aligned, 32 bytes in one run through the cycle, only aligned data
arr_src aligned / - Check modulos to finish copying the remaining data outside of the cycle
- Modulo 8 and 16 - S3 instructions for aligned data, the rest of the modulos are generic
arr_dest aligned ---> - _main_loop_unaligned, 48 bytes of source unaligned data in one run through the cycle,
arr_src unaligned / (the destination must always be aligned)
- Check modulos to finish copying remaining data outside of the cycle
- Modulo 32 and 16 - S3 instructions for unaligned data, the rest of the modulos are generic
arr_dest unaligned -> - First, use generic instructions to align the arr_dest data (keep increasing
arr_src aligned / the arr_dest pointer until the pointer is aligned)
- Once arr_dest is aligned treat the rest of the data as:
either both aligned (if arr_src happens to be aligned after the arr_dest aligning),
or as arr_dest aligned and arr_src unaligned
- Continue as mentioned above
arr_dest unaligned -> - Very same approach as with arr_dest unaligned and arr_src aligned
arr_src unaligned /
if the arr_len is less than 16, jump to _less_than_16 label and copy data without any s3 instructions or cycles
#define MEMCPY_OPTIMIZED 1 // Use optimized memcpy or ANSI memcpy
#define TIE_ENABLE 0 // Put a dummy TIE instruction to the ANSI memcpy to induce TIE context saving
dsps_memcpy_aes3:
#if MEMCPY_OPTIMIZED
// S3 optimized version of the memcpy (with TIE instrucstions)
entry a1, 32
mov a7, a2 // a7 - save arr_dest pointer
blti a4, 16, _less_than_16
// arr_dest alignment check
movi.n a9, 0xf // 0xf alignment mask
and a13, a9, a2 // 0xf AND arr_dest pointer
beqz a13, _arr_dest_aligned
movi.n a14, 16 // a14 - 16
sub a13, a14, a13 // a13 = 16 - unalignment
sub a4, a4, a13 // len = len - (16 - unalignment)
// Aligning the arr_dest
// keep copying until arr_dest is aligned
// Check modulo 8 of the unalignment, if - then copy 8 bytes
bbci a13, 3, _aligning_mod_8_check // branch if 3-rd bit of unalignment a13 is clear
l32i.n a15, a3, 0 // load 32 bits from arr_src a3 to a15, offset 0
l32i.n a14, a3, 4 // load 32 bits from arr_src a3 to a14, offset 4
s32i.n a15, a2, 0 // save 32 bits from a15 to arr_dest a2, offset 0
s32i.n a14, a2, 4 // save 32 bits from a14 to arr_dest a2, offset 4
addi.n a3, a3, 8 // increment arr_src pointer by 8 bytes
addi.n a2, a2, 8 // increment arr_dest pointer by 8 bytes
_aligning_mod_8_check:
// Check modulo 4 of the unalignment, if - then copy 4 bytes
bbci a13, 2, _aligning_mod_4_check // branch if 2-nd bit of unalignment a13 is clear
addi.n a3, a3, 4 // increment arr_src pointer by 4 bytes
addi.n a2, a2, 4 // increment arr_dest pointer by 4 bytes
_aligning_mod_4_check:
// Check modulo 2 of the unalignment, if - then copy 2 bytes
bbci a13, 1, _aligning_mod_2_check // branch if 1-st bit of unalignment a13 is clear
l16ui a15, a3, 0 // load 16 bits from arr_src a3 to a15
addi.n a3, a3, 2 // increment arr_src pointer by 2 bytes
s16i a15, a2, 0 // save 16 bits from a15 to arr_dest a2
addi.n a2, a2, 2 // increment arr_dest pointer by 2 bytes
_aligning_mod_2_check:
// Check modulo 1 of the unalignment, if - then copy 1 byte
bbci a13, 0, _arr_dest_aligned // branch if 0-th bit of unalignment a13 is clear
l8ui a15, a3, 0 // load 8 bits from arr_src a3 to a15
addi.n a3, a3, 1 // increment arr_src pointer by 1 byte
s8i a15, a2, 0 // save 8 bits from a15 to arr_dest a2
addi.n a2, a2, 1 // increment arr_dest pointer by 1 byte
_arr_dest_aligned:
// arr_src alignment check
and a15, a9, a3 // 0xf (alignment mask) AND arr_src pointer
beqz a15, _arr_src_aligned
// arr_src unaligned, arr_dest aligned (arr_des either aligned originally or modified to be aligned by the Aligning the arr_des routine)
// Calculate modulo for non-aligned data
movi a8, 89478486 // a8 - div_48 constant
muluh a5, a8, a4 // a5 - loop_len = arr_len / 48
movi a9, 48 // a9 - 48
mul16s a8, a9, a5 // a8 - 48 * loop_len
sub a6, a4, a8 // a6 - loop_len_MOD 48
ee.ld.128.usar.ip q2, a3, 16 // Preload from arr_src
ee.ld.128.usar.ip q3, a3, 16 // Preload from arr_src
// Main loop arr_src unaligned
loopnez a5, ._main_loop_unaligned // 48 bytes in one loop
ee.src.q.ld.ip q4, a3, 16, q2, q3 // preload and shift from arr_src
ee.vst.128.ip q2, a2, 16 // store to aligned arr_dest
ee.src.q.ld.ip q2, a3, 16, q3, q4 // preload and shift from arr_src
ee.vst.128.ip q3, a2, 16 // store to aligned arr_dest
ee.src.q.ld.ip q3, a3, 16, q4, q2 // preload and shift from arr_src
ee.vst.128.ip q4, a2, 16 // store to aligned arr_dest
._main_loop_unaligned:
// Finish the _main_loop_unaligned outside of the loop from Q registers preloads
// Check modulo 32 of the loop_len_MOD, if - then copy 32 bytes
bbci a6, 5, _unaligned_mod_32_check // branch if 5-th bit of loop_len_MOD a6 is clear
ee.src.q.ld.ip q4, a3, 0, q2, q3 // preload and shift from arr_src
ee.src.q q3, q3, q4 // final shift
j _follow_unaligned
_unaligned_mod_32_check:
// Check modulo 16 of the loop_len_MOD, if - then copy 16 bytes
bbci a6, 4, _unaligned_mod_16_check // branch if 4-th bit of loop_len_MOD a6 is clear
ee.src.q q2, q2, q3 // final shift
addi a3, a3, -16 // put arr_src pointer back
j _follow_unaligned
_unaligned_mod_16_check:
addi a3, a3, -32 // put arr_src pointer back
// Check modulo 8 of the loop_len_MOD, if - then copy 8 bytes
_follow_unaligned:
bbci a6, 3, _unaligned_mod_8_check // branch if 3-rd bit of loop_len_MOD a6 is clear
_unaligned_mod_8_check:
// Finish the rest of the data, as if the data were aligned, no S3 instructions will be used further after the jump
j _aligned_mod_8_check
// Both arrays (arr_src and arr_dest) aligned
_arr_src_aligned:
// Calculate modulo 32 for aligned data
srli a5, a4, 5 // a5 - loop_len = arr_len / 32
slli a6, a5, 5
sub a6, a4, a6 // a6 - loop_len_MOD 32
// Main loop arr_src aligned
loopnez a5, ._main_loop_aligned // 32 bytes in one loop
ee.vld.128.ip q0, a3, 16 // load 16 bytes from arr_src to q0
ee.vld.128.ip q1, a3, 16 // load 16 bytes from arr_src to q1
ee.vst.128.ip q0, a2, 16 // save 16 bytes to arr_dest from q0
ee.vst.128.ip q1, a2, 16 // save 16 bytes to arr_dest from q1
._main_loop_aligned:
// Modulo 32 check
beqz a6, _aligned_mod_32_check // branch if mod_32 = 0
// finish the end of the array outside of the main loop
bbci a6, 4, _aligned_mod_16_check // branch if 4-th bit of loop_len_MOD a6 is clear
ee.vld.128.ip q0, a3, 16 // load 128 bits from arr_src to q0, increase arr_src pointer by 16 bytes
ee.vst.128.ip q0, a2, 16 // save 128 bits to arr_dest from q0, increase arr_dest pointer by 16 bytes
_aligned_mod_16_check:
bbci a6, 3, _aligned_mod_8_check // branch if 3-rd bit of loop_len_MOD a6 is clear
ee.vld.l.64.ip q0, a3, 8 // load lower 64 bits from arr_src a3 to q0, increase arr_src pointer by 8 bytes
ee.vst.l.64.ip q0, a2, 8 // save lower 64 bits from q0 to arr_dest a2, increase arr_dest pointer by 8 bytes
_aligned_mod_8_check:
// Check modulo 4 of the loop_len_MOD, if - then copy 4 bytes
bbci a6, 2, _aligned_mod_4_check // branch if 2-nd bit of loop_len_MOD a6 is clear
_aligned_mod_4_check:
// Check modulo 2 of the loop_len_MOD, if - then copy 2 bytes
bbci a6, 1, _aligned_mod_2_check // branch if 1-st bit of loop_len_MOD a6 is clear
_aligned_mod_2_check:
// Check modulo 1 of the loop_len_MOD, if - then copy 1 byte
bbci a6, 0, _aligned_mod_32_check // branch if 0-th bit of loop_len_MOD a6 is clear
_aligned_mod_32_check:
mov a2, a7 // copy the initial arr_dest pointer from a7 to arr_dest a2
retw.n // return
_less_than_16:
// If the length of the copied array is lower than 16, it is faster not to use esp32s3-optimized functions
// Check modulo 8 of the arr_len, if - then copy 8 bytes
bbci a4, 3, _less_than_16_mod_8_check // branch if 3-rd bit of arr_len a4 is clear
_less_than_16_mod_8_check:
// Check modulo 4 of the arr_len, if - then copy 4 bytes
bbci a4, 2, _less_than_16_mod_4_check // branch if 2-nd bit of arr_len a4 is clear
_less_than_16_mod_4_check:
// Check modulo 2 of the arr_len, if - then copy 2 bytes
bbci a4, 1, _less_than_16_mod_2_check // branch if 1-st bit of arr_len a4 is clear
_less_than_16_mod_2_check:
// Check modulo 1 of the arr_len, if - then copy 1 byte
bbci a4, 0, _less_than_16_mod_1_check // branch if 0-th bit of arr_len a4 is clear
_less_than_16_mod_1_check:
retw.n // return
#else // MEMCPY_OPTIMIZED
// ansi version of the memcpy (without TIE instructions) for testing purposes
entry a1, 32
srli a5, a4, 4 // a5 - loop_len = arr_len / 16
// Run main loop which copies 16 bytes in one loop run
loopnez a5, ._ansi_loop
l32i.n a13, a3, 8 // load 32 bits from arr_src a3 to a13
l32i.n a12, a3, 12 // load 32 bits from arr_src a3 to a13
s32i.n a13, a2, 8 // save 32 bits from a13 to arr_dest a2
s32i.n a12, a2, 12 // save 32 bits from a13 to arr_dest a2
addi.n a3, a3, 16 // increment arr_src pointer by 12 bytes
addi.n a2, a2, 16 // increment arr_dest pointer by 12 bytes
._ansi_loop:
// Finish the remaining bytes out of the loop
bbci a4, 3, _mod_8_check // branch if 2-nd bit of arr_len a4 is clear
l32i.n a14, a3, 4 // load 32 bits from arr_src a3 to a15
s32i.n a14, a2, 4 // save 32 bits from a15 to arr_dest a2
addi.n a3, a3, 8 // increment arr_src pointer by 4 bytes
addi.n a2, a2, 8 // increment arr_dest pointer by 4 bytes
_mod_8_check:
bbci a4, 2, _mod_4_check // branch if 2-nd bit of arr_len a4 is clear
_mod_4_check:
bbci a4, 1, _mod_2_check // branch if 1-st bit of arr_len a4 is clear
_mod_2_check:
bbci a4, 0, _mod_1_check // branch if 0-th bit of arr_len a4 is clear
_mod_1_check:
// if arr_len is shorter than 16, skip adding TIE instruction, to fix the panic handler before the main_app() loads
blti a4, 16, _less_than_16_1 // branch, if arr_len a4 is shorter than 16 bytes
#if TIE_ENABLE // put dummy TIE instruction to induce TIE context saving
ee.zero.qacc // initialize q0 to zero (dummy instruction)
#else // TIE_ENABLE
nop // compensate one cycle, when TIE is disabled to get the same benchmark value
#endif // TIE_ENABLE
_less_than_16_1:
retw.n // return
#endif // MEMCPY_OPTIMIZED
