в чем проблема вставить код как положено?
Нажимаете кнопку </> и вставляете код. И никаких проблем с кавычками
я так и делаю
Вы видимо не внимательно прочитали тему
делали бы - проблем бы не было
This is a library for the BMP280 humidity, temperature & pressure sensor
Designed specifically to work with the Adafruit BMP280 Breakout
----> http://www.adafruit.com/products/2651
These sensors use I2C or SPI to communicate, 2 or 4 pins are required
to interface.
Adafruit invests time and resources providing this open source code,
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by Limor Fried & Kevin Townsend for Adafruit Industries.
MIT license, see LICENSE.txt for more information
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#define BMP_SCK (13)
#define BMP_MISO (12)
#define BMP_MOSI (11)
#define BMP_CS (10)
Adafruit_BMP280 bmp; // I2C
//Adafruit_BMP280 bmp(BMP_CS); // hardware SPI
//Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
while ( !Serial ) delay(100); // wait for native usb
Serial.println(F("BMP280 test"));
unsigned status;
//status = bmp.begin(BMP280_ADDRESS_ALT, BMP280_CHIPID);
status = bmp.begin();
if (!status) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring or "
"try a different address!"));
Serial.print("SensorID was: 0x"); Serial.println(bmp.sensorID(),16);
Serial.print(" ID of 0xFF probably means a bad address, a BMP 180 or BMP 085\n");
Serial.print(" ID of 0x56-0x58 represents a BMP 280,\n");
Serial.print(" ID of 0x60 represents a BME 280.\n");
Serial.print(" ID of 0x61 represents a BME 680.\n");
while (1) delay(10);
/* Default settings from datasheet. */
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, /* Operating Mode. */
Adafruit_BMP280::SAMPLING_X2, /* Temp. oversampling */
Adafruit_BMP280::SAMPLING_X16, /* Pressure oversampling */
Adafruit_BMP280::FILTER_X16, /* Filtering. */
Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
Serial.print(F("Temperature = "));
Serial.print(bmp.readTemperature());
Serial.println(" *C");
Serial.print(F("Pressure = "));
Serial.print(bmp.readPressure());
Serial.println(" Pa");
Serial.print(F("Approx altitude = "));
Serial.print(bmp.readAltitude(1013.25)); /* Adjusted to local forecast! */
Serial.println(" m");
Serial.println();
delay(2000);
да я Вас явно чем то задел.
Scanning…
I2C device found at address 0x76 !
done
Тестировалось на Arduino IDE 1.8.5
Дата тестирования 26.10.2017г.
#include <Wire.h>
void setup(){
Wire.begin();
while (!Serial);
Serial.println("\nI2C Scanner");
void loop(){
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 8; address < 127; address++ ){
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0){
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4) {
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000);
#include <Wire.h>
while (!Serial) delay(100);
// Ограничение скорости I2C до 100 кГц
Wire.setClock(100000);
if (!bmp.begin(0x76)) {
Serial.println(F("Датчик не найден!"));
// Настройки датчика
Serial.println(F("Готово!\n"));
float temp = bmp.readTemperature();
float pressure_mmhg = bmp.readPressure() * 0.00750062;
float altitude = bmp.readAltitude(1012);
Serial.print(F("Temp: "));
Serial.print(temp);
Serial.println(F(" *C"));
Serial.print(F("Pressure: "));
Serial.print(pressure_mmhg);
Serial.println(F(" mmHg"));
Serial.print(F("Altitude: "));
Serial.print(altitude);
Serial.println(F(" m\n"));
delay(2000);
что то поменялось ?)))
Temp: 23.44 *C
Pressure: 616.83 mmHg
Altitude: 1716.22 m
это хорошо или плохо ?)))
вы в горах или нет ?
кхе кхе, скорее всего нет))) попробуйте добавить резистор для i2c
балбес, связь с модулем есть.
Какой стабильный датчик. Немецкое качество.
от 3.3 вольт! а что плохого в балбесе ?))) ну ленюсь я немного… у всех должны быть свои слабости!
ой я может быть опять с другим путаю датчиком…))) он кажется и работает только от 3.3 вольт…
tolyan77
а вы его проверяли на ардуино уно ?
а можете подсказать какое у вас сейчас
Какое давление в вашем регионе по данным погоды?
751
но высота точно не почти 2000 метров:(
в чем сарказм?
Неужто не замечаете сов падение?
только две ноды:(
@tolyan77 есть возможность, поменяйте модуль bmp280, хоть понятно будет где копать.
высота высчитывается исходя из давления вроде, или нет ?
может где то в библиотеке надо указывать… но искать и чистать мне лень)))
да блин уже второй модуль нужно менять, тут явно что то не то, есть bme280
я написал 751
