Помогите с кодом для копилки
#include <LiquidCrystal.h>
#include <Servo.h>
#include <Adafruit_NeoPixel.h>
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
Servo servo;
Adafruit_NeoPixel strip(4, 0, NEO_GRB + NEO_KHZ800);
volatile bool leftButtonPressed = false;
volatile bool leftbuttonconfirmation = false;
volatile int rightButtonCounter = 0;
static int accumulatedMoney = 0;
static unsigned long resetConfirmationStartTime = 0;
int ultrasonicTrigPin = 4;
int ultrasonicEchoPin = 5;
int schet =0;
bool stopschet=false;
  attachInterrupt(0, leftButtonISR, RISING);
  attachInterrupt(1, rightButtonISR, RISING);
  lcd.begin(16, 2);
  servo.attach(1);
  strip.begin();
  strip.show();
  lcd4();
  pinMode(ultrasonicTrigPin, OUTPUT);
  pinMode(ultrasonicEchoPin, INPUT);
  static bool POL = false;
  static bool forceSensorZero = true;
  digitalWrite(ultrasonicTrigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(ultrasonicTrigPin, HIGH);
  delayMicroseconds(10);
  long duration = pulseIn(ultrasonicEchoPin, HIGH);
  int cm = duration / 58;
  int forceValue = analogRead(A0);
  if (cm>275) {
     strip.clear();
     strip.show();
     POL = false;
     lcd4();
  if (cm<275 && cm>225) {
     strip.clear();
     strip.setPixelColor(0, 0, 255, 0);
     strip.show();
     POL = false;
     lcd4();
  if (cm<235 && cm>125) {
     strip.clear();
     strip.setPixelColor(1, 255, 255, 0);
     strip.show();
     POL = false;
     lcd4();
  if (cm<125 && cm>55) {
     strip.clear();
     strip.setPixelColor(2, 255, 50, 0);
     strip.show();
     POL = false;
     lcd4();
  if (cm<55 && cm>0) {
     strip.clear();
     strip.setPixelColor(3, 255, 0, 0);
     strip.show();
    lcd.home();
      lcd.print("                ");
    lcd.setCursor(0,1);
    lcd.print("    ");
     lcd.setCursor(4, 1);
     lcd.print("Net mesta");
     POL = true;
     stopschet=true;
  if (leftButtonPressed) {
    resetConfirmationStartTime = millis();
  leftbuttonconfirmation = true;
    for (int i = 10; i > 0; i--) {
      lcd.clear();
      lcd.print("Sbros?");
      lcd.setCursor(14, 1);
      lcd.print(i);
        lcd.setCursor(10, 0);
        lcd.print(rightButtonCounter);
        lcd.setCursor(12, 0);
        lcd.print("iz 3");
      if(rightButtonCounter>2)
  if (leftbuttonconfirmation && millis() - resetConfirmationStartTime >= 10000 && rightButtonCounter <= 2) {
  if (leftbuttonconfirmation && rightButtonCounter == 3) {
      lcd4();
  if (forceValue == 1023) {
         servo.write(0);
  if (forceValue <= 1022) {
    if (!POL) {
      if (forceValue >= 800 && forceValue <= 1000 && forceSensorZero) {
        accumulatedMoney = accumulatedMoney + 1;
         servo.write(180);
          delay(2000);
          servo.write(0);
        forceSensorZero = false;
      if (forceValue >= 315 && forceValue <= 357 && forceSensorZero) {
        accumulatedMoney = accumulatedMoney + 2;
        servo.write(180);
          delay(2000);
          servo.write(0);
      if (forceValue >= 141 && forceValue <= 185 && forceSensorZero) {
        accumulatedMoney = accumulatedMoney + 5;
          servo.write(180);
          delay(2000);
          servo.write(0);
          lcd4();
      if (forceValue >= 109 && forceValue <= 126 && forceSensorZero) {
        accumulatedMoney = accumulatedMoney + 10;
        servo.write(180);
          delay(2000);
          servo.write(0);
    else {
  delay(100);
void lcd4() {
  lcd.home();
  lcd.clear();
  lcd.print("vkopilke:");
  lcd.setCursor(0, 1);
  lcd.print(accumulatedMoney);
  lcd.print(" rub        ");
void leftButtonISR() {
  leftButtonPressed = true;
void rightButtonISR() {
  rightButtonCounter++;
Вся ошибки в том, что экран всегда мерцает, а должен быть статичен.
А чего с чего бы ему быть статичным, если в каждом цикле вызывается функция lcd4() внутри которой всегда вызывается метод lcd.clear() ?
ну вот в том и суть, я не знаю как без clear в lcd4 сделать, пытался чистить его не в функции lcd4 результат тот же
А от нас чего ждёте? Можете объяснить?
У тебя там меняется пара-тройка символов на дисплее, нафига его чистить полностью ?
Зачем его вообще чистить ?
Просто новое значение(без очистки) выводи на месте старого и ничего мерцать не будет.
Надеюсь на вашу помочь
Это в функции lcd4 сделать?
Ответьте на вопрос, чего Вы ожидаете от нас конкретно. В чём помощь должна выражаться? Например:
  1. сделать вместо Вас;
  2. пожелать Вам удачи;
  3. пинать Вас ногами и сечь плетью пока не сделаете сами;
  4. покрутить пальцем у виска и отойти в сторону.
Что из этого (или ещё что-то другое) Вас бы устроило в качестве помощи?
в идеале 1 вариант, но сомневаюсь, что такое возможно
Почему же? Возможно!
Запостите запрос в коммерческом разделе, договоритесь о цене и, с довольно высокой вероятностью, Вам всё сделают.
Спасибо Евгений
Не за что.
