Управление шаговыми моторами с помощью flysky
Пытался сделать ездящую коробку с Arduino Mega и 4 биполярными шаговиками, управляемую с помощью контроллера flysky i6. Вот код:
#include <IBusBM.h>
IBusBM ibusRc;
HardwareSerial& ibusRcSerial = Serial1;
HardwareSerial& debugSerial = Serial;
#include <GyverStepper.h>
GStepper<STEPPER4WIRE> stepperLF(2048, 22, 24, 26, 28);
GStepper<STEPPER4WIRE> stepperRF(2048, 7, 6, 5, 4);
GStepper<STEPPER4WIRE> stepperRB(2048, 23, 25, 27, 29);
GStepper<STEPPER4WIRE> stepperLB(2048, 30, 31, 32, 33);
int spws;
int spad;
 debugSerial.begin(74880);
 ibusRc.begin(ibusRcSerial);
 stepperLF.setRunMode(KEEP_SPEED);
   stepperRF.setRunMode(KEEP_SPEED);
   stepperLB.setRunMode(KEEP_SPEED);
   stepperRB.setRunMode(KEEP_SPEED);
   stepperLF.stop();
 stepperRF.stop();
 stepperLB.stop();
 stepperRB.stop();
// Read the number of a given channel and convert to the range provided.
// If the channel is off, return the default value
int readChannel(byte channelInput, int minLimit, int maxLimit, int defaultValue){
 uint16_t ch = ibusRc.readChannel(channelInput);
 if (ch < 100) return defaultValue;
 return map(ch, 1000, 2000, minLimit, maxLimit);
// Red the channel and return a boolean value
bool redSwitch(byte channelInput, bool defaultValue){
 int intDefaultValue = (defaultValue)? 100: 0;
 int ch = readChannel(channelInput, 0, 100, intDefaultValue);
 return (ch > 50);
 for (byte i = 0; i<4; i++){
   int value = readChannel(i, -400, 400, 0);
   debugSerial.print("Ch");
   debugSerial.print(i + 1);
   debugSerial.print(": ");
   debugSerial.print(value);
   debugSerial.print(" ");
 debugSerial.print("Ch5: ");
 debugSerial.print(redSwitch(4, false));
 debugSerial.println();
   spws = readChannel(2, -400, 400, 0);
   spad = readChannel(3, -400, 400, 0);
   Serial.print("5");
   Serial.print(": ");
   Serial.print(spws);
   Serial.print("    ");
   Serial.print("6");
   Serial.print(": ");
   Serial.print(spad);
   Serial.print("    ");
   stepperLF.setSpeed(spws);
   stepperRF.setSpeed(spws);
   stepperLB.setSpeed(spws);
   stepperRB.setSpeed(spws);
    stepperLF.tick();
    stepperRF.tick();
    stepperLB.tick();
    stepperRB.tick();
В мониторе порта изменения отображаются, то есть значения от пульта принимает, но вот движки не крутятся. Может, кто, подсказать в чем проблема?
Например - они не подключены, вот и не крутятся.
Примеры к библиотеке запустите без всяких флайскаев.
Простите, я плохо объяснил. Двигатели успешно работают при включении примеров из библиотеки GyverStepper, но при работе этого кода шаговики стоят на месте и фиксируют положение (это прописано в сетапе).
Ну, перенесите setspeed пока в setup с константой. Может ему не нравится вызов такой частый.
это конечно же решит проблему не работающих двигателей, но не даст мне управлять роботом с помощью пульта, а значит и лишит мой проект всякого смысла
Вы всегда можете взять более другую библиотеку, которой не мешает смена скорости на ходу.
Или свои функции хода наколотить. Даже методом индусского программирования.
я думаю будет лучше управлять движком устанавливая относительную цель в шагах/градусах
как насчет совместимости библиотек? внутри смотрели?
и библиотека откуда
IBusBM.h
Закомментируй вывод в сериал, библиотека гайвера смотрит микрос()
