Вопрос по warning:
Пожалуй, подниму тему.
Внезапно наткнулся на странные предупреждения. Например, в этом скетче (пример к моей же библиотеке)
Получаю вот такую красоту:
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.h:52:7: warning: type 'struct shButton' violates the C++ One Definition Rule [-Wodr]
 class shButton
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.h:52:7: note: a different type is defined in another translation unit
 class shButton
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.h:88:22: note: the first difference of corresponding definitions is field 'btn_flag'
   uint8_t btn_flag = 0;
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.h:52:7: note: a type with different number of fields is defined in another translation unit
 class shButton
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.h:191:8: warning: 'setVirtualClickOn' violates the C++ One Definition Rule  [-Wodr]
   void setVirtualClickOn(bool virtualclick_on = true);
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:189:6: note: implicit this pointer type mismatch
 void shButton::setVirtualClickOn(bool virtualclick_on)
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.h:52:7: note: type 'struct shButton' itself violates the C++ One Definition Rule
 class shButton
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:189:6: note: 'setVirtualClickOn' was previously declared here
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:189:6: note: code may be misoptimized unless -fno-strict-aliasing is used
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.h:198:8: warning: 'setLongClickMode' violates the C++ One Definition Rule  [-Wodr]
   void setLongClickMode(uint8_t longclickmode);
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:194:6: note: implicit this pointer type mismatch
 void shButton::setLongClickMode(uint8_t longclickmode)
 class shButton
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:194:6: note: 'setLongClickMode' was previously declared here
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:194:6: note: code may be misoptimized unless -fno-strict-aliasing is used
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.h:111:11: warning: 'getButtonState' violates the C++ One Definition Rule  [-Wodr]
   uint8_t getButtonState();
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:120:9: note: implicit this pointer type mismatch
 uint8_t shButton::getButtonState()
 class shButton
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:120:9: note: 'getButtonState' was previously declared here
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:120:9: note: code may be misoptimized unless -fno-strict-aliasing is used
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.h:98:3: warning: '__comp_ctor ' violates the C++ One Definition Rule  [-Wodr]
   shButton(uint8_t pin, uint8_t inputtype = PULL_UP, uint8_t btntype = BTN_NO);
/home/vladimir/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_632476/UseButtonFlag.ino.elf /tmp/arduino_build_632476/UseButtonFlag.ino.eep/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:6:1: note: implicit this pointer type mismatch
 shButton::shButton(uint8_t pin, uint8_t inputtype, uint8_t btntype)
 class shButton
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:6:1: note: '__comp_ctor ' was previously declared here
/mnt/B6F0D77CF0D74173/_Documents/Vladimir/YandexDisk/Arduino/libraries/shButton/shButton.cpp:6:1: note: code may be misoptimized unless -fno-strict-aliasing is used
В других примерах к библиотеке ничего подобного нет, предупреждения начинают сыпать только если в скетче используется #define USE_BUTTON_FLAG
Что компилятор пытается мне донести?
Оно?
Что тебе без всех этих if defined мешало оставить все эти функции и переменную? Оно же всё равно если не используется - компилятором «выпилится»…
Оно. Только я в упор не вижу, где у меня там переопределения типов и тому подобного ))
Он не о том говорит, на сколько я понял…
#66 смотри.
Нет. С ним размер скетчей таки больше. Скетч, не использующий USE_BUTTON_FLAG
Сейчас:
Скетч использует 2878 байт (9%) памяти устройства. Всего доступно 30720 байт.
Глобальные переменные используют 258 байт (12%) динамической памяти, оставляя 1790 байт для локальных переменных. Максимум: 2048 байт.
Если я делаю эти методы доступными без всяких флагов, то получается:
Скетч использует 2882 байт (9%) памяти устройства. Всего доступно 30720 байт.
Глобальные переменные используют 259 байт (12%) динамической памяти, оставляя 1789 байт для локальных переменных. Максимум: 2048 байт.
Хотя они и не используются
Странно, это лучше Евгения Петровича подождать тогда и спросить у него - почему «не выпиливается»?
С другой стороны - 4 байта во флэш и 1 байт ОЗУ даже для attiny13 не сильно критично? Или это на каждую кнопку так?
Ну да, на каждый объект ))
Это всё потому, что не бывает ничего «универсального» :smiley: Всегда приходится чем-то жертвовать.
ЗЫ: Но вопрос про Почему «не выпиливается» - остаётся открытым.
В первую очередь строку №4 листинга
При компиляции у Вас компилируется два объектных файла. Один получен при компиляции фала .ino, а другой – при компиляции файла shButton.cpp.
В обоих объектных файла есть тип shButton. Причём, они (эти типы) существенно разные, т.к. в файле .ino определена константа USE_BUTTON_FLAG, а в файле shButton.cpp – нет. Разумеется, это приводит к разным вариантам типа shButton.
Вот он Вам и говорит, что, мол
Понятно?
Да. Примерно туда же и копал… Спасибо :raised_hand_with_fingers_splayed:
В общем, перенес все определения из файла shButton.cpp в конец файла shButton.h, сам файл shButton.cpp удалил, и ворнинги пропали. Вот ведь гадостный язык ))))
На брак с ворчливой женой похоже - терпишь и живешь…
Не понятно почему неиспользуемый код “не выпиливается”… (((
А кто Вам сказал, что он не выпиливается? Как Вы это определили?
@v258, а для чего Вы вообще стали использовать #if’ы в определении класса? У iarduino научились? Почему не пользоваться родными средствами ОПП? И проблем бы никаких не возникало. У Вас какие-то соображения были или просто не знаете как, и Вам надо показать?
Это не я сделал, а @v258
Если не трудно ))
Так разница всего 4 байта - как раз на входы таблицы методов. А сами методы выброшены.
Строго говоря я не говорил, что методы не выбрасываются, а имел в виду таки увеличение итогового размера прошивки. Вот против этого #if и использую - дабы ненужный код из компиляции исключить полностью
