WEB клиент Ethernet.h
А что, если в POST подсунуть “Connection: close”, разрыва не происходит?
RFC не диктует применение данного хидера исключительно с GET.
HTTP/1.1 defines the “close” connection option for the sender to signal that the connection will be closed after completion of the response. For example,
Connection: close
in either the request or the response header fields indicates that the connection SHOULD NOT be considered `persistent’ (section 8.1) after the current request/response is complete. HTTP/1.1 applications that do not support persistent connections MUST include the “close” connection option in every message.
Start
Status = 0
Status = 0
Status = 0
Status = 0
Status = 0
Status = 0
Status = 0
Status = 0
Status = 0
CONNECTION_FAILED
Status = 0
Status = 0
Status = 0
Status = 0
Status = 0
#include <SPI.h>
#include <Ethernet.h>
#include <avr/wdt.h>
#define PORT_NUMBER 80
const uint8_t mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
const uint8_t ip[] = {192, 168, 1, 88};
const uint8_t gateway[] = {192, 168, 1, 1};
const uint8_t subnet[] = {255, 255, 255, 0};
const uint8_t dns[] = {192, 168, 1, 1};
const uint8_t server[] = {192, 168, 1, 42};
EthernetClient client;
  wdt_disable();
  Ethernet.begin(mac, ip, dns, gateway, subnet);
  Serial.println("Start");
  wdt_enable(WDTO_8S);
//bool request_post = false;
//uint32_t request_post_tmr;
void http_request_post() {
  if (client.connect(server, PORT_NUMBER)) {
    client.print(F("POST /12.php HTTP/1.1\r\n"));
    client.print(F("User-Agent: ARDUINO\r\n"));
    client.print(F("Host: "));
    for (uint8_t i = 0; i < 4; i++) {
      client.print(server[i]);
      if (i < 3)client.print(".");
    client.print(F("\r\n"));
    client.print(F("Content-Type: application/x-www-form-urlencoded\r\n"));
    client.print(F("Content-Length: 9 \r\n"));
    client.print(F("text=1234"));
    client.print("Connection: close\r\n\r\n");
    //request_post = true;
   // request_post_tmr = millis();
    Serial.println("CONNECTION_FAILED");
    client.stop();
void get_response() {
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
    //request_post_tmr = millis();
  wdt_reset();
  get_response();
 // if (request_post && millis() - request_post_tmr >= 500) {
   // Serial.println("CLIENT_STOP");
   // request_post = false;
   // client.stop();
  static uint32_t timer_status;
  if (millis() - timer_status >= 500) {
    timer_status = millis();
    Serial.print("Status = ");
    Serial.print(client.connected());
    Serial.println("");
  static uint32_t timer;
  if (millis() - timer >= 5000) {
    timer = millis();
    http_request_post();
Зачем хидер в тело засунули?
Первая строка - метод, далее все хидеры, затем пустая строка и боди.
Сейчас этот хидер бессмысленнен.
    client.print(F("Host: 192.168.1.42\r\n"));
    client.print(F("Content-Length: 9 \r\n\r\n"));
    client.stop();
Ответ
Start
Status = 0
Status = 0
Status = 0
Status = 0
Status = 0
HTTP/1.1 200 OK
Date: Fri, 30 Dec 2022 15:39:15 GMT
Content-Type: text/html; charset=UTF-8
Content-LengtStatus = 1
h: 17
Connection: keep-alive
Keep-Alive: timeout=120
Server: Apache
X-Content-Type-Options: nosniff
Text_POST= 1234
HTTP/1.1 400 Bad Request
Server: nginx
Content-Length: 150
Connection: close
<html>
<head><title>400 Bad Request</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<hr><center>nginx</center>
</body>
</html>
Status = 0
Status = 0
Status = 0
Ох, беда-беда, огорчение
    client.print("Connection: close\r\n");
    client.print(F("Content-Length: 9 \r\n\"));
    client.stop();
tart
Status = 0
Status = 0
Status = 0
Status = 0
Status = 0
HTTP/1.1 200 OK
Date: Fri, 30 Dec 2022 16:07:12 GMT
Content-LengStatus = 1
th: 17
Connection: close
Server: Apache
Text_POST= 1234
Status = 0
Status = 0
Status = 0
Status = 0
Status = 0
HTTP/1.1 200 OK
Date: Fri, 30 Dec 2022 16:07:15 GMT
h: 17
Connection: close
Server: Apache
Text_POST= 1234
Status = 0
Status = 0
Status = 0
Т.е. работает?
Да. Спасибо.
Здравствуйте. Помогайте)
#include <SPI.h>
#include <Wiegand.h>
//Отладка
#define DEBUG
#ifdef DEBUG
#define DEBUG
#define SERIAL_BEGIN Serial.begin(19200)
#define DEBUG_PRINT(x) Serial.print(x)
#define DEBUG_PRINTLN(x) Serial.println(x)
#else
#endif
//Отладка
WIEGAND wg;
uint32_t numcard = 0;
#include "W5500.h"
  wdt_disable();
  wg.begin();
  SERIAL_BEGIN;
  DEBUG_PRINTLN("Start");
  wdt_reset();
  w5500_read();
  if (wg.available()) {
    numcard = wg.getCode();
    Serial.println(numcard);
    if (numcard > 0) http_request_get();
W5500.h
//#include "W5500.h"
const uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
const uint8_t ip[] = { 192, 168, 0, 105 };
const uint8_t gateway[] = { 192, 168, 0, 1 };
const uint8_t subnet[] = { 255, 255, 255, 0 };
const uint8_t dns[] = { 192, 168, 0, 1 };
const uint8_t server[] = { 192, 168, 0, 25 };
const uint8_t port = 80;
const uint8_t max_buf = 100;
char buffers[max_buf];
uint8_t pos_buf;
void buf_clear() {
  memset(buffers, 0, max_buf);
  pos_buf = 0;
void w5500_read() {
    uint8_t temp = client.read();
    if (temp) {
      buffers[pos_buf] = temp;
      pos_buf++;
      if (pos_buf >= max_buf) {
        buf_clear();
        if (temp == '\n' && pos_buf > 1 && buffers[pos_buf - 2] == '\r') {
          if (strstr(buffers, "#") != NULL) {
            DEBUG_PRINTLN(buffers);
          buf_clear();
void http_request_get() {
  client.stop();
  delay(10);
  if (client.connect(server, port)) {
    DEBUG_PRINTLN("СONNECTED");
    client.print(F("GET /auto.php?numcard="));
    client.print(numcard);
    client.print(F(" HTTP/1.1\r\n"));
    client.print(F("User-Agent: Arduino\r\n"));
    client.print(F("Host: 192.168.0.25\r\n"));
    client.print(F("Connection: close\r\n\r\n"));
    DEBUG_PRINTLN("CONNECTION_FAILED");
auto.php
<?php
$numcard = preg_replace('/[^0-9]/', '', $_GET['numcard']);
$card_hex = dechex($numcard);
$serial_hex = substr($card_hex, 0, 2);
$number_hex = substr($card_hex, 2, 4);
$card_seria = hexdec($serial_hex);
$card_number = hexdec($number_hex);
echo $card_seria . "---" . $card_number . "#";
Прикладываю к считывателю разные карты, а в мониторе порта получаю следующее:
8637075
СONNECTED
131---51859#HTTP/1.1 200 OK
1103923
СONNECTED
Считыватель выдаёт верные номера карты, разные, а в ответе на запрос я получаю одну и туже информацию, но если приложить пропуск еще раз, все ок.
1103923
СONNECTED
16---55347#HTTP/1.1 200 OK
1103923
СONNECTED
1103923
СONNECTED
8637075
СONNECTED
8637075
СONNECTED
13-14-15 строки, приложила другую карту, 17-18-19 строки приложила эту же карту еще раз
помогло ?)))
if (numcard > 0) {
  http_request_get();
  numcard = 0;  // Сброс значения после отправки
И так пробовала, хотя считыватель каждый раз обновляет значение, в мониторе порта оно верное.
    client.print(F("&times="));
    client.print(millis());
И вот так делала
8637075 -- 1 карта (значение со считывателя)
СONNECTED
8637075---131---51859#HTTP/1.1 200 OK
СONNECTED
СONNECTED
1103923 -- 2 карта (значение со считывателя)
СONNECTED
СONNECTED
1103923---16---55347#HTTP/1.1 200 OK
Сделала такую проверку
  if (!flag && millis() - tims >= 3000) {
    flag = true;
    tims = millis();
    numcard = 1103923;
    http_request_get();
  if (flag && millis() - tims >= 3000) {
    flag = false;
    tims = millis();
    numcard = 8637075;
    http_request_get();
Что за бред? Почему так?
СONNECTED
card = 8637075
СONNECTED
card = 1103923
СONNECTED
card = 8637075
СONNECTED
card = 1103923
СONNECTED
card = 8637075
Изменила php
<?php
$chars = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPRQSTUVWXYZ0123456789";
$code = "";
$clen = strlen($chars) - 1;
while (strlen($code) < 9) {
    $code .= $chars[mt_rand(0, $clen)];
echo $_GET['numcard'] . "---" . $code ."#";
Получаю
СONNECTED
card = 8637075
1103923---EC2L7FIy4#HTTP/1.1 200 OK
СONNECTED
card = 1103923
8637075---R8ppMcbJb#HTTP/1.1 200 OK
СONNECTED
card = 8637075
1103923---JUmX8hT6Y#HTTP/1.1 200 OK
СONNECTED
card = 1103923
8637075---uzrxTdQ1a#HTTP/1.1 200 OK
wdt_reset();
w5500_read();
uint32_t currentCard = wg.getCode();  // Локальная переменная
if (currentCard != numcard) {         // Только если карта изменилась
numcard = currentCard;
DEBUG_PRINTLN(numcard);
http_request_get(); }
а что будет если везде насувать delay ?)))
  wdt_disable();
  wg.begin();
delay(100);
  SERIAL_BEGIN;
delay(100);
Наставила, не помогло(
СONNECTED
card = 8637075
8637075---8TpPbXBC4#HTTP/1.1 200 OK
СONNECTED
card = 8637075
8637075---Staa2EejR#HTTP/1.1 200 OK
СONNECTED
card = 1103923
8637075---qJjUoPlY1#HTTP/1.1 200 OK
СONNECTED
card = 1103923
1103923---IXVbpGUmv#HTTP/1.1 200 OK
Изменила код приёма
    Serial.print( c );
СONNECTED
numbers = 8637075
HTTP/1.1 200 OK
Date: Fri, 25 Jul 2025 11:01:36 GMT
Server: Apache
Content-Length: 8
Connection: close
8637075#
СONNECTED
numbers = 1103923
HTTP/1.1 200 OK
Date: Fri, 25 Jul 2025 11:01:47 GMT
Server: Apache
Content-Length: 8
Connection: close
1103923#
Всё стало правильно. В чём косяк?
uint8_t или uint32_t не вмещал данные ?)))
но скорее всего что то с символом \n было связанно, то ли он был толи наоборот не было))) но это не точно, а пальцем в небо
не понимаю код… он точно будет работать ? или он только первый символ проверяет ?)))
не поняла про что это
какой именно?
char c передает символ за символом ? а не 1 символ 1 раз… верно ?)))
и если так, то наверное что то символом конца строки связанно,(\n) передавая по 1 символу, условие срабатывает… пока нет вывода с символом конца строки
а вот если char “C” не передает символ за символом, а передает только 1 символ, будет срабатывать на похожую карту…
