Ардуино нано не видит sd карту
Добрый день. Проблема в работоспособности Arduino nano + SD ридер + sd-карта. Ардуино не видит её,
перепробовал, на мой взгляд всё.
Подключение:
GRD – GRD
VCC – 5V
MISO – D12
MOSI – D11
SCK – D13
CS – D10
Скетч cardinfo с сайта https://www.arduino.cc/ без изменений:
  SD card test
 This example shows how use the utility libraries on which the'
 SD library is based in order to get info about your SD card.
 Very useful for testing a card when you're not sure whether its working or not.
 The circuit:
  * SD card attached to SPI bus as follows:
 ** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
 ** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
 ** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
 ** CS - depends on your SD card shield or module.
        Pin 4 used here for consistency with other Arduino examples
 created  28 Mar 2011
 by Limor Fried
 modified 16 Mar 2011
 by Tom Igoe
 // include the SD library:
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 4;
  Serial.print("\nInitializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
  pinMode(10, OUTPUT);     // change this to 53 on a mega
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card is inserted?");
    Serial.println("* Is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
   Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch(card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  Serial.println();
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
Пробовал карту на 2 Гб и на 8 Гб (новые). Форматировал в FAT32 со стандартным
и всеми возможными другими размерами кластера - не помогает, ответ один:
Initializing SD card…initialization failed. Things to check:
  • is a card is inserted?
  • Is your wiring correct?
  • did you change the chipSelect pin to match your shield or module?
При этом есть 8 Гб флешка из планшета, тоже fat32, которая отлично работает (использовать её не могу). Работает, если СS подключить
к D10 или к D4:
Initializing SD card…Wiring is correct and a card is present.
Card type: SDHC
Volume type is FAT32
Volume size (bytes): 3644850176
Volume size (Kbytes): 3559424
Volume size (Mbytes): 3476
LOST.DIR/ 2022-08-30 01:24:16
ANDROI~1/ 2023-12-31 20:35:26
ANDROID/ 2022-08-30 01:32:48
DATA/ 2024-04-06 15:20:02
NOMEDI~1 2022-08-30 01:24:16 0
COMGOO~1.MUS/ 2023-06-22 06:43:10
Если запитать ридер от 3V3 - не работает ни одна, в выводе:
Если СS отцепить совсем, то рабочая флешка планшета при питании 5В, скажет:
Card type: SDHC
Make sure you’ve formatted the card
Новая форматированная 8 Гб при тех же условиях скажет:
Иногда после Ардуины комп флешку не видит, лечится быстрым форматированием.
Впрочем, флешку на 2 Гб я все-таки запортачил так, что она не форматируется.
Подскажите, пожалуйста, если есть какие-нибудь мысли.
скорми эту цитату переводчику, вникни в суть вопроса (переведенного на русский язык), ответь на него сначала в уме, потом скорректируй свой говноскетч.
А зря, надо не только бездумно копировать но и иногда читать что скопировал
Я не эксперт и в принципе могу очень сильно ошибаться, т.к. до SD карт и шилдов еще недоучился, но хочется обратить внимание на строки с 30 по 34. Сдается мне, что пин в строке 34 должен не быть 4, так как по описанию это какой то Ethernet shield, а не SD… А исходя из описания ТС, должно быть значение 10
Я пробовал cs цеплять на D4, если речь об этом, я даже написал про это в посте, может и не совсем понятно. Но ардуино не видит её все равно.
Суть в том, что одна флешка работает цепляй её хоть к D4, хоть к D10 (в данном скетче). Другая - нет. Другие скетчи тоже пробовал.
прозвони, на какой пин с шилда у тебя выходит сигнал SD_CS
Честно говоря, не знаю как это сделать. С другой стороны, все выходы на плате sd-ридера подписаны.
Говоришь, флешка из планшета робит, а остальные нет, значит дело во флешке. Рекомендуют форматировать этой утилитой: SD Memory Card Formatter for Windows/Mac | SD Association
Недавно сам мучался. Сначала пихал карту 2GB - не видится (fat16), а потом перешел на 16GB и все запустилось.
На счет отвала флешки в винде. Было тоже самое, пока пользовался встроенным в ноут кардридером. Перешел на вншений формфактор usb-flash, отвал прекратился.
Может проще в exfat?
