В коде ссылка на тему на arduino.cc, чтение аналогового пина стандартными средствами, не уж то?
// Sketch for Arduino magnetometer
// Measures strength of magnetic field with SS49E hall sensor on A0
// Displays values on I2C SSD1306 128x64 0.96" monochrome OLED display
// Connect SCK to pin A5 and SDA to pin A4
// Connect null-button between GND and A1 for setting output to zero
//https://forum.arduino.cc/t/magnetometro-ac-dc/1100262
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display(128,64,&Wire,-1);
#define HALL_PIN A0
#define NULL_PIN A1
#define nmeas 2000 // stay below 2048 to avoid overflow
#define cal 0.349*0.582 // calibration constant in mT per ADC count. nominal (5.0/1024)/0.014=0.349:
float offset=511.0; // nominal 511: halfway 0 and 1024
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.setTextColor(WHITE);
display.clearDisplay();
pinMode(HALL_PIN,INPUT); //pullup increases current and reduces noise
pinMode(NULL_PIN,INPUT_PULLUP); //avoids need for external pullup resistor
//perform the measurement. AnalogRead() takes ~100mus.
long unsigned int sum=0;
long unsigned int sumsq=0;
for (int imeas=0; imeas<nmeas; imeas++){
long int val= analogRead(A0);
sum=sum+val;
sumsq=sumsq+val*val;
//recalculate offset if null-button is pressed
if(digitalRead(NULL_PIN)==0)offset=float(sum)/nmeas;
//calculate DC and AC field strength. AC corresponds to RMS of the fluctuations
float B_DC=(float(sum)/nmeas-offset)*cal;
float B_ACsq=(float(sumsq)/nmeas-pow(float(sum)/nmeas,2))*pow(cal,2);
float B_AC=0.0;
if (B_ACsq>pow(0.005,2)) B_AC=pow(B_ACsq,0.5);
pow((float(sumsq)/nmeas-pow(float(sum)/nmeas,2)),0.5)*cal;
char txt[10]; //text buffer needed to print formatted float
// print DC value
display.setTextSize(1);
display.setCursor(0,2);
display.print("DC");
display.setCursor(0,18);
display.print("mT");
display.setTextSize(3);
dtostrf(B_DC,7,2,txt);
display.print(txt);
// print AC value
display.setCursor(0,34);
display.print("AC");
display.setCursor(0,50);
dtostrf(B_AC,7,2,txt);
display.print(txt);
display.display();
