Error: section of 'st7302_wenting' conflicts with previous declaration
При проверке скетча возникает ошибка:
In file included from c:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay\src\OneBitDisplay.cpp:58:
c:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay\src\obd.inl:776:15: error: section of ‘st7302_wenting’ conflicts with previous declaration
776 | const uint8_t st7302_wenting PROGMEM PROGMEM = {
exit status 1
Compilation error: exit status 1
какого скетча?
Задавать вопрос про ошибки кода без самого кода - это как учится играть на гитаре без гитары
#include <SPI.h>
#include <Wire.h>
#include <BitBang_I2C.h>
#include <OneBitDisplay.h>
#include <AnimatedGIF.h>
#include "animation.h"
OBDISP obd;
AnimatedGIF gif;
static uint8_t ucOLED[4096]; // holds current frame for 128x64 OLED
// M5Atom Matrix ESP32
#define RESET_PIN -1
#define SDA_PIN -1
#define SCL_PIN -1
#define OLED_ADDR -1
#define MY_OLED OLED_128x64
#define USE_HW_I2C 1
#define FLIP180 0
#define INVERT 0
#define DISPLAY_WIDTH 128
#define DISPLAY_HEIGHT 64
// This doesn't have to be super efficient
void DrawPixel(int x, int y, uint8_t ucColor)
    uint8_t ucMask;
    int index;
    if (x >= DISPLAY_WIDTH || y >= DISPLAY_HEIGHT)
        return;
    ucMask = 1 << (y & 7);
    index = x + ((y >> 3) << 7);
    if (ucColor)
        ucOLED[index] |= ucMask;
        ucOLED[index] &= ~ucMask;
// Draw a line of image directly on the LCD
void GIFDraw(GIFDRAW* pDraw)
    uint8_t* s;
    int x, y, iWidth;
    static uint8_t ucPalette[4096]; // thresholded palette
    if (pDraw->y == 0) // first line, convert palette to 0/1
        for (x = 0; x < 256; x++)
            uint16_t usColor = pDraw->pPalette[x];
            int gray = (usColor & 0xf800) >> 8; // red
            gray += ((usColor & 0x7e0) >> 2); // plus green*2
            gray += ((usColor & 0x1f) << 3); // plus blue
            //ucPalette[x] = (gray >> 9); // 0->511 = 0, 512->1023 = 1
            if (gray>800) ucPalette[x]=1; else ucPalette[x]=0;
    y = pDraw->iY + pDraw->y; // current line
    iWidth = pDraw->iWidth;
    if (iWidth > DISPLAY_WIDTH)
        iWidth = DISPLAY_WIDTH;
    s = pDraw->pPixels;
    if (pDraw->ucDisposalMethod == 2) // restore to background color
        for (x = 0; x < iWidth; x++)
            if (s[x] == pDraw->ucTransparent)
                s[x] = pDraw->ucBackground;
        pDraw->ucHasTransparency = 0;
    // Apply the new pixels to the main image
    if (pDraw->ucHasTransparency) // if transparency used
        uint8_t c, ucTransparent = pDraw->ucTransparent;
        int x;
            c = *s++;
            if (c != ucTransparent)
                DrawPixel(pDraw->iX + x, y, ucPalette[c]);
        s = pDraw->pPixels;
        // Translate the 8-bit pixels through the RGB565 palette (already byte reversed)
        for (x = 0; x < pDraw->iWidth; x++)
            DrawPixel(pDraw->iX + x, y, ucPalette[*s++]);
    if (pDraw->y == pDraw->iHeight - 1) // last line, render it to the display
        obdDumpBuffer(&obd, ucOLED);
} /* GIFDraw() */
uint8_t last_animation = 0; // to prevent 2 animation loop after idle. just make it feels , more "random"??
void playWrapper(uint8_t* gifinput, int size)
    if (gif.open(gifinput, size, GIFDraw))
        //    Serial.printf("Successfully opened GIF; Canvas size = %d x %d\n", gif.getCanvasWidth(), gif.getCanvasHeight());
        while (gif.playFrame(true, NULL))
        gif.close();
struct Anime {
    uint8_t* ptr;
    int size;
#define NUMBEROFANIMATION 32
Anime anime;
int n = NUMBEROFANIMATION;
int r;
int debugRandom = 0;  //choose between random or i++ animation  (0 = random / 1 = i++)
int counter = 99;
    // sorry for ths long hard code, just to make simple I want to put the animation inside array , as the library fn is using ptr and size I cant just put the addresses I also need the size
  // as i dont know how to read sizeof a pointer .  bear with ths :(
    //anime[0].ptr = (uint8_t*)_1;
    //anime[0].size = sizeof(_1);
    anime[1].ptr = (uint8_t*)_2;
    anime[1].size = sizeof(_2);
    anime[2].ptr = (uint8_t*)_3;
    anime[2].size = sizeof(_3);
    anime[3].ptr = (uint8_t*)_4;
    anime[3].size = sizeof(_4);
    anime[4].ptr = (uint8_t*)_5;
    anime[4].size = sizeof(_5);
    anime[5].ptr = (uint8_t*)_6;
    anime[5].size = sizeof(_6);
    anime[6].ptr = (uint8_t*)_7;
    anime[6].size = sizeof(_7);
    anime[7].ptr = (uint8_t*)jojos;
    anime[7].size = sizeof(jojos);
    anime[8].ptr = (uint8_t*)_9;
    anime[8].size = sizeof(_9);
    anime[9].ptr = (uint8_t*)_10;
    anime[9].size = sizeof(_10);
    anime[10].ptr = (uint8_t*)_11;
    anime[10].size = sizeof(_11);
    anime[11].ptr = (uint8_t*)_12;
    anime[11].size = sizeof(_12);
    anime[12].ptr = (uint8_t*)_13;
    anime[12].size = sizeof(_13);
    anime[13].ptr = (uint8_t*)_14;
    anime[13].size = sizeof(_14);
    anime[14].ptr = (uint8_t*)_15;
    anime[14].size = sizeof(_15);
    anime[15].ptr = (uint8_t*)_16;
    anime[15].size = sizeof(_16);
    anime[16].ptr = (uint8_t*)_17;
    anime[16].size = sizeof(_17);
    anime[17].ptr = (uint8_t*)_18;
    anime[17].size = sizeof(_18);
    anime[18].ptr = (uint8_t*)_19;
    anime[18].size = sizeof(_19);
    anime[19].ptr = (uint8_t*)_20;
    anime[19].size = sizeof(_20);
    anime[20].ptr = (uint8_t*)_21;
    anime[20].size = sizeof(_21);
    anime[21].ptr = (uint8_t*)_22;
    anime[21].size = sizeof(_22);
    anime[22].ptr = (uint8_t*)_23;
    anime[22].size = sizeof(_23);
    anime[23].ptr = (uint8_t*)_24;
    anime[23].size = sizeof(_24);
    anime[24].ptr = (uint8_t*)_25;
    anime[24].size = sizeof(_25);
    anime[25].ptr = (uint8_t*)_26;
    anime[25].size = sizeof(_26);
    anime[26].ptr = (uint8_t*)_27;
    anime[26].size = sizeof(_27);
    anime[27].ptr = (uint8_t*)_28;
    anime[27].size = sizeof(_28);
    anime[28].ptr = (uint8_t*)_29;
    anime[28].size = sizeof(_29);
    anime[29].ptr = (uint8_t*)_30;
    anime[29].size = sizeof(_30);*/
    int rc = obdI2CInit(&obd, MY_OLED, OLED_ADDR, FLIP180, INVERT, USE_HW_I2C, SDA_PIN, SCL_PIN, RESET_PIN, 800000L); // use standard I2C bus at 400Khz
    Serial.print(rc);
    obdFill(&obd, 0, 1);
    gif.begin(LITTLE_ENDIAN_PIXELS);
// obdWriteString(&obd,0,0,0,(char *)"GIF Demo", FONT_NORMAL, 0, 1);
  //delay(1000);
if (gif.open((uint8_t*)_31, sizeof(_31), GIFDraw))
        gif.close();
    r = random(1, 3) * 10000;
    Serial.println(r);
    delay(r);
    if (debugRandom == 0)
        //randomSeed(esp_random());
        r = random(0, n)+1;
        Serial.println(r);
        while (r == last_animation) {
            delay(10);
            r = random(0, n)+1;
            if (r != last_animation)
                last_animation = r;
        Serial.println(r);
        counter++;
        if (counter > NUMBEROFANIMATION)
            counter = 1;
        r = counter;
    Serial.println(r);
    switch (r)
      case 0:
        anime.ptr = (uint8_t*)_1;
        anime.size = sizeof(_1);
      case 1:
        anime.ptr = (uint8_t*)_2;
        anime.size = sizeof(_2);
      case 2:
        anime.ptr = (uint8_t*)_3;
        anime.size = sizeof(_3);
      case 3:
        anime.ptr = (uint8_t*)_4;
        anime.size = sizeof(_4);
      case 4:
        anime.ptr = (uint8_t*)_5;
        anime.size = sizeof(_5);
      case 5:
        anime.ptr = (uint8_t*)_6;
        anime.size = sizeof(_6);
      case 6:
        anime.ptr = (uint8_t*)_7;
        anime.size = sizeof(_7);
      case 7:
        //anime.ptr = (uint8_t*)jojos;
        //anime.size = sizeof(jojos);
      case 8:
        anime.ptr = (uint8_t*)_9;
        anime.size = sizeof(_9);
      case 9:
        anime.ptr = (uint8_t*)_10;
        anime.size = sizeof(_10);
      case 10:
        anime.ptr = (uint8_t*)_11;
        anime.size = sizeof(_11);
      case 11:
        anime.ptr = (uint8_t*)_12;
        anime.size = sizeof(_12);
      case 12:
        anime.ptr = (uint8_t*)_13;
        anime.size = sizeof(_13);
      case 13:
        anime.ptr = (uint8_t*)_14;
        anime.size = sizeof(_14);
      case 14:
        anime.ptr = (uint8_t*)_15;
        anime.size = sizeof(_15);
      case 15:
        anime.ptr = (uint8_t*)_16;
        anime.size = sizeof(_16);
      case 16:
        anime.ptr = (uint8_t*)_17;
        anime.size = sizeof(_17);
      case 17:
        anime.ptr = (uint8_t*)_18;
        anime.size = sizeof(_18);
      case 18:
        anime.ptr = (uint8_t*)_19;
        anime.size = sizeof(_19);
     case 19:
        anime.ptr = (uint8_t*)_20;
        anime.size = sizeof(_20);
     case 20:
        anime.ptr = (uint8_t*)_21;
        anime.size = sizeof(_21);
     case 21:
        anime.ptr = (uint8_t*)_22;
        anime.size = sizeof(_22);
     case 22:
        anime.ptr = (uint8_t*)_23;
        anime.size = sizeof(_23);
     case 23:
        anime.ptr = (uint8_t*)_24;
        anime.size = sizeof(_24);
    case 24:
        anime.ptr = (uint8_t*)_25;
        anime.size = sizeof(_25);
    case 25:
     //   anime.ptr = (uint8_t*)_26;
      //  anime.size = sizeof(_26);
    case 26:
      //  anime.ptr = (uint8_t*)_27;
       // anime.size = sizeof(_27);
    playWrapper(anime.ptr, anime.size);
switch (r)
  case 1:
  playWrapper((uint8_t*)_1, sizeof(_1));
  case 2:
  playWrapper((uint8_t*)_2, sizeof(_2));
  case 3:
  playWrapper((uint8_t*)_3, sizeof(_3));
  case 4:
  playWrapper((uint8_t*)_4, sizeof(_4));
    case 5:
  playWrapper((uint8_t*)_5, sizeof(_5));
    case 6:
  playWrapper((uint8_t*)_6, sizeof(_6));
    case 7:
  playWrapper((uint8_t*)_40, sizeof(_40));
    case 8:
  playWrapper((uint8_t*)_8, sizeof(_8));
    case 9:
  playWrapper((uint8_t*)_9, sizeof(_9));
    case 10:
  playWrapper((uint8_t*)_10, sizeof(_10));
    case 11:
  playWrapper((uint8_t*)_36, sizeof(_36));
    case 12:
  playWrapper((uint8_t*)_41, sizeof(_41));
    case 13:
  playWrapper((uint8_t*)_13, sizeof(_13));
    case 14:
  playWrapper((uint8_t*)_14, sizeof(_14));
    case 15:
  playWrapper((uint8_t*)_34, sizeof(_34));
    case 16:
  playWrapper((uint8_t*)_16, sizeof(_16));
    case 17:
  playWrapper((uint8_t*)_35, sizeof(_35));
    case 18:
  playWrapper((uint8_t*)_18, sizeof(_18));
    case 19:
  playWrapper((uint8_t*)_19, sizeof(_19));
    case 20:
  playWrapper((uint8_t*)_33, sizeof(_33));
  case 21:
  playWrapper((uint8_t*)_21, sizeof(_21));
  case 22:
  playWrapper((uint8_t*)_22, sizeof(_22));
  case 23:
  playWrapper((uint8_t*)_23, sizeof(_23));
  case 24:
  playWrapper((uint8_t*)_24, sizeof(_24));
  case 25:
  playWrapper((uint8_t*)_25, sizeof(_25));
  case 26:
  playWrapper((uint8_t*)_32, sizeof(_32));
  case 27:
  playWrapper((uint8_t*)_37, sizeof(_37));
  case 28:
  playWrapper((uint8_t*)_28, sizeof(_28));
  case 29:
  playWrapper((uint8_t*)_29, sizeof(_29));
  case 30:
  playWrapper((uint8_t*)_30, sizeof(_30));
  case 31:
  playWrapper((uint8_t*)_42, sizeof(_42));
  case 32:
  playWrapper((uint8_t*)_39, sizeof(_39));
спасибо
Еще сообщение об ошибке полностью скопируйте
exit status 1
Это все
в такой ошибке всегда есть отсылка на эту самую “прежнюю декларацию”, а у вас нет
Вы расширенный вывод в опциях Ардуино ИДЕ включили? - включите
FQBN: esp8266:esp8266:d1_mini
Using board 'd1_mini' from platform in folder: C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
Using core 'esp8266' from platform in folder: C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
"C:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/mkbuildoptglobals.py" "C:\\Program Files\\Arduino IDE\\resources\\app\\lib\\backend\\resources" 10607 "C:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B" "C:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt" "C:\\Users\\REWORK\\Desktop\\dasai\\2\\DasaiOled/DasaiOled.ino.globals.h" "C:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266/CommonHFile.h"
default_encoding:       cp1251
Assume aggressive 'core.a' caching enabled.
Note: optional global include file 'C:\Users\REWORK\Desktop\dasai\2\DasaiOled\DasaiOled.ino.globals.h' does not exist.
  Read more at https://arduino-esp8266.readthedocs.io/en/latest/faq/a06-global-build-options.html
Detecting libraries used...
C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core -c @C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\sketch\DasaiOled.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core -c @C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\sketch\DasaiOled.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core -c @C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\sketch\DasaiOled.ino.cpp -o nul
Alternatives for BitBang_I2C.h: [BitBang_I2C@2.2.1]
ResolveLibrary(BitBang_I2C.h)
  -> candidates: [BitBang_I2C@2.2.1]
C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core -c @C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -Ic:\Users\REWORK\Documents\Arduino\libraries\BitBang_I2C\src C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\sketch\DasaiOled.ino.cpp -o nul
Alternatives for OneBitDisplay.h: [OneBitDisplay@2.3.1]
ResolveLibrary(OneBitDisplay.h)
  -> candidates: [OneBitDisplay@2.3.1]
C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core -c @C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -Ic:\Users\REWORK\Documents\Arduino\libraries\BitBang_I2C\src -Ic:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay\src C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\sketch\DasaiOled.ino.cpp -o nul
Alternatives for AnimatedGIF.h: [AnimatedGIF@2.1.0]
ResolveLibrary(AnimatedGIF.h)
  -> candidates: [AnimatedGIF@2.1.0]
C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core -c @C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -Ic:\Users\REWORK\Documents\Arduino\libraries\BitBang_I2C\src -Ic:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay\src -Ic:\Users\REWORK\Documents\Arduino\libraries\AnimatedGIF\src C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\sketch\DasaiOled.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire\Wire.cpp
Using cached library dependencies for file: c:\Users\REWORK\Documents\Arduino\libraries\BitBang_I2C\src\BitBang_I2C.cpp
C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core -c @C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -Ic:\Users\REWORK\Documents\Arduino\libraries\BitBang_I2C\src -Ic:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay\src -Ic:\Users\REWORK\Documents\Arduino\libraries\AnimatedGIF\src c:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay\src\OneBitDisplay.cpp -o nul
C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core -c @C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -Ic:\Users\REWORK\Documents\Arduino\libraries\BitBang_I2C\src -Ic:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay\src -Ic:\Users\REWORK\Documents\Arduino\libraries\AnimatedGIF\src c:\Users\REWORK\Documents\Arduino\libraries\AnimatedGIF\src\AnimatedGIF.cpp -o nul
Generating function prototypes...
C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B/core -c @C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -Ic:\Users\REWORK\Documents\Arduino\libraries\BitBang_I2C\src -Ic:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay\src -Ic:\Users\REWORK\Documents\Arduino\libraries\AnimatedGIF\src C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\sketch\DasaiOled.ino.cpp -o C:\Users\REWORK\AppData\Local\Temp\342987715\sketch_merged.cpp
C:\Users\REWORK\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\REWORK\AppData\Local\Temp\342987715\sketch_merged.cpp
Компиляция скетча...
"C:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/signing.py" --mode header --publickey "C:\\Users\\REWORK\\Desktop\\dasai\\2\\DasaiOled/public.key" --out "C:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B/core/Updater_Signing.h"
"C:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B/core" -c "@C:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/extra-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini\"" -DFLASHMODE_DIO "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\d1_mini" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "-Ic:\\Users\\REWORK\\Documents\\Arduino\\libraries\\BitBang_I2C\\src" "-Ic:\\Users\\REWORK\\Documents\\Arduino\\libraries\\OneBitDisplay\\src" "-Ic:\\Users\\REWORK\\Documents\\Arduino\\libraries\\AnimatedGIF\\src" "C:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B\\sketch\\DasaiOled.ino.cpp" -o "C:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B\\sketch\\DasaiOled.ino.cpp.o"
In file included from C:\Users\REWORK\Desktop\dasai\2\DasaiOled\DasaiOled.ino:5:
c:\Users\REWORK\Documents\Arduino\libraries\AnimatedGIF\src/AnimatedGIF.h: In member function 'void AnimatedGIF::begin(int, unsigned char)':
c:\Users\REWORK\Documents\Arduino\libraries\AnimatedGIF\src/AnimatedGIF.h:216:20: warning: unused parameter 'iEndian' [-Wunused-parameter]
  216 |     void begin(int iEndian, unsigned char ucPaletteType) { begin(ucPaletteType); };
Compiling libraries...
Compiling library "SPI"
Используем предварительно скомпилированный файл: C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\libraries\SPI\SPI.cpp.o
Compiling library "Wire"
Используем предварительно скомпилированный файл: C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\libraries\Wire\Wire.cpp.o
Compiling library "BitBang_I2C"
Используем предварительно скомпилированный файл: C:\Users\REWORK\AppData\Local\Temp\arduino\sketches\BBA32F3D127C0B40BC30ACD9C3943E9B\libraries\BitBang_I2C\BitBang_I2C.cpp.o
Compiling library "OneBitDisplay"
"C:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B/core/build.opt" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B/core" -c "@C:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/extra-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini\"" -DFLASHMODE_DIO "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\d1_mini" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IC:\\Users\\REWORK\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "-Ic:\\Users\\REWORK\\Documents\\Arduino\\libraries\\BitBang_I2C\\src" "-Ic:\\Users\\REWORK\\Documents\\Arduino\\libraries\\OneBitDisplay\\src" "-Ic:\\Users\\REWORK\\Documents\\Arduino\\libraries\\AnimatedGIF\\src" "c:\\Users\\REWORK\\Documents\\Arduino\\libraries\\OneBitDisplay\\src\\OneBitDisplay.cpp" -o "C:\\Users\\REWORK\\AppData\\Local\\Temp\\arduino\\sketches\\BBA32F3D127C0B40BC30ACD9C3943E9B\\libraries\\OneBitDisplay\\OneBitDisplay.cpp.o"
c:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay\src\obd.inl:776:15: error: section of 'st7302_wenting' conflicts with previous declaration
  776 | const uint8_t st7302_wenting[] PROGMEM PROGMEM = {
Используем библиотеку SPI версии 1.0 из папки: C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI
Используем библиотеку Wire версии 1.0 из папки: C:\Users\REWORK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire
Используем библиотеку BitBang_I2C версии 2.2.1 из папки: C:\Users\REWORK\Documents\Arduino\libraries\BitBang_I2C
Используем библиотеку OneBitDisplay версии 2.3.1 из папки: C:\Users\REWORK\Documents\Arduino\libraries\OneBitDisplay
Используем библиотеку AnimatedGIF версии 2.1.0 из папки: C:\Users\REWORK\Documents\Arduino\libraries\AnimatedGIF
exit status 1
Вот теперь вроде все
Сорри, не знаю почему оно дважды декларируется.
Попробуйте написать автору, репозиторий свежий, автор его, наверно, не забросил еще
Нашел ошибку в библиотеке
#ifndef WIMPY_MCU
заменил на
#ifndef WIMPY_MCU
const uint8_t st7302_wenting[] PROGMEM = {
так тебе про неё 707 сказал жеж
не, я ничего не говорил
ему “так запомнилось”.
молодец
так это ты не о том что PROGMEM два разА?
Нет, на два прогмема не обратил внимание
