Как на Adafruit_ST7735 развернуть изображение на 180 градусов?
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
#include <SPI.h>
#define TFT_CS 10
#define TFT_RST A1
#define TFT_DC A0
#define TFT_Mosi 11
#define TFT_Sclk 13
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// Кнопки
#define BTN_UP 2
#define BTN_DOWN 3
#define BTN_SEL 4
// Выход сигнала
#define SIGNAL_PIN 5
// Типы сигналов
enum WaveType {
SINE, // синус
SQUARE,
TRIANGLE,
SAW
WaveType currentWave = SINE;
int frequency = 1000;
int dutyCycle = 50;
bool menuMode = true;
int menuItem = 0;
unsigned long lastMicros = 0;
int phase = 0;
// Таблица синуса
const uint8_t sineTable[64] = {
128,140,153,165,177,188,199,209,
218,226,234,240,245,249,252,254,
255,254,252,249,245,240,234,226,
218,209,199,188,177,165,153,140,
128,115,102,90,78,67,56,46,
37,29,21,15,10,6,3,1,
0,1,3,6,10,15,21,29,
37,46,56,67,78,90,102,115
pinMode(BTN_UP, INPUT_PULLUP);
pinMode(BTN_DOWN, INPUT_PULLUP);
pinMode(BTN_SEL, INPUT_PULLUP);
pinMode(SIGNAL_PIN, OUTPUT);
tft.initR(INITR_BLACKTAB); // инициализация дисплея
tft.fillScreen(ST77XX_BLACK);
analogWrite(SIGNAL_PIN, 127);
drawUI();
handleButtons();
generateSignal();
drawOscilloscope();
void handleButtons() {
if (!digitalRead(BTN_UP)) {
delay(150);
if (menuItem == 0) {
  currentWave = (WaveType)((currentWave + 1) % 4);
if (menuItem == 1) {
  frequency += 100;
if (menuItem == 2) {
  dutyCycle += 5;
  if (dutyCycle > 95) dutyCycle = 95;
drawUI();
if (!digitalRead(BTN_DOWN)) {
delay(150);
  currentWave = (WaveType)((currentWave + 3) % 4);
  frequency -= 100;
  if (frequency < 100) frequency = 100;
  dutyCycle -= 5;
  if (dutyCycle < 5) dutyCycle = 5;
drawUI();
if (!digitalRead(BTN_SEL)) {
delay(150);
menuItem++;
if (menuItem > 2) menuItem = 0;
drawUI();
void generateSignal() {
unsigned long period = 1000000UL / frequency;
if (micros() - lastMicros >= period / 64) {
lastMicros = micros();
uint8_t value = 0;
switch (currentWave) {
  case SINE:
    value = sineTable[phase];
  case SQUARE:
    value = (phase < (64 * dutyCycle / 100)) ? 255 : 0;
  case TRIANGLE:
    if (phase < 32)
      value = phase * 8;
      value = 255 - ((phase - 32) * 8);
  case SAW:
    value = phase * 4;
analogWrite(SIGNAL_PIN, value);
phase++;
if (phase >= 64) phase = 0;
void drawUI() {
tft.setTextColor(ST77XX_GREEN);
tft.setTextSize(2);
tft.setCursor(5, 5);
tft.print(“GENERATOR”);
tft.setTextSize(1);
tft.setCursor(5, 40);
tft.print(menuItem == 0 ? “>” : " ");
tft.print("Wave: ");
switch(currentWave) {
case SINE: tft.print(“SINE”); break;
case SQUARE: tft.print(“SQUARE”); break;
case TRIANGLE: tft.print(“TRIANGLE”); break;
case SAW: tft.print(“SAW”); break;
tft.setCursor(5, 60);
tft.print(menuItem == 1 ? “>” : " ");
tft.print(“Freq: “);
tft.print(frequency);
tft.print(” Hz”);
tft.setCursor(5, 80);
tft.print(menuItem == 2 ? “>” : " ");
tft.print(“Duty: “);
tft.print(dutyCycle);
tft.print(”%”);
tft.drawRect(5, 105, 118, 50, ST77XX_WHITE);
void drawOscilloscope() {
static int x = 6;
tft.drawFastVLine(x, 106, 48, ST77XX_BLACK);
int y = 130;
case SINE:
  y = 130 + sin(x * 0.2) * 15;
case SQUARE:
  y = (x % 20 < 10) ? 115 : 145;
case TRIANGLE:
  y = 115 + abs((x % 20) - 10) * 3;
case SAW:
  y = 145 - (x % 20) * 3;
tft.drawPixel(x, y, ST77XX_YELLOW);
x++;
if (x > 120)
x = 6;
как в этом скетче развернуть изображение на 180 градусов
Если загуглить вас же вопрос добавив название библиотеки, то вам тут же выдадут решение. Останется только прочитать, а с этим, похоже, проблемы(судя по выложенному скетчу).
Понятно попробую
Что-то мне кажется тут вместо сигнала на экране будет сплошная каша
В каком?
Хорошо ещё, если родная каша, а не какой-нибудь гламурный «смузи-боул», как сейчас в московских забегаловках называют обычную овсяную, гречневую или пшенную кашу с добавлением ягод. С родной кашей-то можно разобраться :slight_smile:
стандартно - tft.setRotation(3);
Код бы, сначала , вставить нормально
а зачем тебе код )))
Чтобы мир стал немного лучше
Хм.. :roll_eyes:
  • tft.setRotation();Rotating the screen. Can take values of 0 for 0 degrees, 1 for 90 degrees, 2 for 180 degrees and 3 for 270 degrees.
Впрочем, стандартно :slightly_smiling_face:
эх ты, не умеешь учить…главное задать направление…кстати у меня дисплей понимает аж 8 положений от 0 до 7 догадайся с трёх раз - зачем )))
Пять баллов!:+1:
а если бы setRotation() можно было бы задавать в лупе, можно было бы определить 8 дополнительных значений одной картинкой!)))
интересно можно ли менять… хотя бы с перерисовкой изображения… а если да, то можно ли задавать все 360 градусов ?)))
Первая попытка: чтобы было чем потроллить толстого. Правильно?
Можно с помощью ИИ написать функцию вращения относительно центра к примеру на любой угол. Можно отзеркаливать изображение, но в библиотеках это не пишут, не видят смысла :slight_smile:
нет, речь идёт именно о ST7735 - вот зачем там аж 8 значений поворота
различные направления развертки изображения.
