Missing braces around initializer [-Wmissing-braces]
zzz.h
 typedef struct
  uint8_t ConfigVersion;
  uint8_t XOutputMax_L;
  uint8_t XOutputMax_H;
  uint8_t YOutputMax_L;
  uint8_t YOutputMax_H;
  uint8_t TouchNumber;
  uint8_t ModuleSwitch[2];
  uint8_t ShakeCount;
  uint8_t Filter;
  uint8_t LargeTouch;
  uint8_t NoiseReduction;
  uint8_t ScreenTouchLvl;
  uint8_t ScreenLeaveLvl;
  uint8_t LowPowerControl;
  uint8_t RefreshRate;
  uint8_t xThreshold;
  uint8_t yThreshold;
	uint8_t xSpeedLimit;
	uint8_t ySpeedLimit;
  uint8_t Space[2];
  uint8_t MiniFilter;
  uint8_t StretchR0;
  uint8_t StretchR1;
  uint8_t StretchR2;
  uint8_t StretchRM;
  uint8_t DrvGroupAnum;
  uint8_t DrvGroupBnum;
  uint8_t SensorNum;
  uint8_t FreqAfactor;
  uint8_t FreqBfactor;
  uint8_t PannelBitFreq_L;
  uint8_t PannelBitFreq_H;
  uint8_t PannelSensorTime_L;
  uint8_t PannelSensorTime_H;
  uint8_t PannelTxGain;
  uint8_t PannelRxGain;
  uint8_t PannelDumpShift;
  uint8_t DrvFrameControl;
  uint8_t ChargingLvlUp;
  uint8_t ModuleSwitch3;
  uint8_t GestureDis;
  uint8_t GestureLongPressTime;
  uint8_t XorYSlopeAdjust;
  uint8_t GestureControl;
  uint8_t GestureSwitch1;
  uint8_t GestureSwitch2;
  uint8_t GestureRefreshRate;
  uint8_t GestureTouchLvl;
  uint8_t NewGreenWakeUpLvl;
  uint8_t FreqHoppStart;
  uint8_t FreqHoppEnd;
  uint8_t NoiseDetectTimes;
  uint8_t HoppingFlag;
  uint8_t HoppingThreshold;
  uint8_t NoiseThreshold;
  uint8_t NoiseMinThreshold;
  uint8_t reserved2;
  uint8_t HoppSensorGroup;
  uint8_t HoppSeg1Normalize;
  uint8_t HoppSeg1Factor;
  uint8_t MainClockAdjust;
  uint8_t HoppSeg2Normalize;
  uint8_t HoppSeg2Factor;
  uint8_t reserved3;
  uint8_t HoppSeg3Normalize;
  uint8_t HoppSeg3Factor;
  uint8_t reserved4;
  uint8_t HoppSeg4Normalize;
  uint8_t HoppSeg4Factor;
  uint8_t reserved5;
  uint8_t HoppSeg5Normalize;
  uint8_t HoppSeg5Factor;
  uint8_t reserved6;
  uint8_t HoppSeg6Normalize;
  uint8_t Key1;
  uint8_t Key2;
  uint8_t Key3;
  uint8_t Key4;
  uint8_t KeyArea;
  uint8_t KeyTouchLvl;
  uint8_t KeyLeaveLvl;
  uint8_t KeySens[2];
  uint8_t KeyRestrain;
  uint8_t KeyRestrainTime;
  uint8_t GestureLargeTouch;
  uint8_t reserved7[2];
  uint8_t HotKnotNoiseMap;
  uint8_t LinkThreshold;
  uint8_t PxyThreshold;
  uint8_t GHotDumpShift;
  uint8_t GHotRXGain;
  uint8_t FreqGain0;
  uint8_t FreqGain1;
  uint8_t FreqGain2;
  uint8_t FreqGain3;
  uint8_t reserved8[9];
  uint8_t CombineDis;
  uint8_t SplitSet;
  uint8_t reserved9[2];
  uint8_t SensorCH[14];
  uint8_t reserved10[16];
  uint8_t DriverCH[26];
  	  uint8_t reserved11[16];
  uint8_t ConfigChksum;
  uint8_t ConfigFresh;
  uint8_t Config0;
  uint8_t Config1;
} GT911ConfInfo_TypeDef;
xxx.c
GT911ConfInfo_TypeDef GT911ConfInfo  = {
			0x5b, 0xbc, 0x02, 0x58, 0x02, 0x0A, 0x3d, 0x00, 0x01, 0x0a, 0x28, 0x0f, 0x5a, // 0x8047 - 0x8053
			0x32, 0x03, 0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x16, 0x18, 0x1a, // 0x8054 - 0x8060
			0x14, 0x87, 0x28, 0x0a, 0x4d, 0x4f, 0xb2, 0x04, 0x00, 0x00, 0x01, 0x40, 0x03, // 0x8061 - 0x806D
			0x1d, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x32, // 0x806E - 0x807A
			0x78, 0x94, 0xd5, 0x02, 0x07, 0x00, 0x00, 0x04, 0xa2, 0x36, 0x00, 0x8e, 0x41, // 0x807B - 0x8087
			0x00, 0x80, 0x4d, 0x00, 0x73, 0x5c, 0x00, 0x69, 0x6e, 0x00, 0x69, 0x00, 0x00, // 0x8088	- 0x8094
			0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // 0x8095 - 0x80A1
			0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // 0x80A2 - 0x80AD
			0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x04, 0x06, 0x08, 0x0A, // 0x80AE - 0x80BA
			0x0C, 0x0E, 0x10, 0x12, 0x14, 0xff, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, // 0x80BB - 0x80C7
			0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x26, // 0x80C8 - 0x80D4
			0x24, 0x22, 0x21, 0x20, 0x1e, 0x1e, 0x1d, 0x0c, 0x0a, 0x08, 0x06, 0x04, 0x02, // 0x80D5 - 0x80E1
			0x00, 0xff, 0xff, 0xff, 0xff, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, // 0x80E2 - 0x80EE
			0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // 0x80EF - 0x80FB
			0x00, 0x00, 0x2D, 0x01,0xff,0xff }; // 0x80FC - 0x8100  */
Выдает предупреждение…
missing braces around initializer [-Wmissing-braces]
Почему ? у меня же линейный массив… ? и как убрать предупреждение?
или только обуть каждую строку в {},
Спасибо
С чего вы взяли?
А это?
Замечание не по делу:
Такая большая структура - это как процедура на тысячу строк - сразу показывает недостаток умения планировать структуры данных и их обмен.
Так и представляется, что у вас изменился один байт - а вы из-за него всю структуру по сети гоняете.
ну допустим … я иммел ввиду не ххх х[10],[20]
не понял по какой сети ?//
это конфигмассив в структуре чтобы было легко менять разные значения не лазя постоянно в даташит и не отсчитывая какой по счету байт поменять чтобы изменилась инициализация…
Но вобщемто это неважно … даже если структура из 5 строчек и массив из 5 строчек все равно такое предупреждение
Ай-я-яй! Код не полный, схемы нет!)))
Размер не важен. Если у вас в структуре есть вложенный массив - значит нужны дополнительные скобки.
я понял . спасибо
