На esp8266 или wemos не запуститься вот такой vs1053?
//как не извращался со сменой пинов не выходит запустить
// define the pins used
//#define CLK 14       // SPI Clock, shared with SD card
//#define MISO 12      // Input data, from VS1053/SD card
//#define MOSI 13      // Output data, to VS1053/SD card
// These are the pins used for the breakout example
#define BREAKOUT_RESET  D3      // VS1053 reset pin (output)
#define BREAKOUT_CS     D2     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    D1      // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET  D3      // VS1053 reset pin (unused!)
#define SHIELD_CS     D2      // VS1053 chip select pin (output)
#define SHIELD_DCS    D1      // VS1053 Data/command select pin (output)
#define CARDCS D8     // Card chip select pin
#define DREQ D0       // VS1053 Data request, ideally an Interrupt pin
такой же модуль без sd карты запускается, а вот с sd картой не хочет стартовать никак…
на ардуино уно вот так запускал…
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
//#define CLK 13       // SPI Clock, shared with SD card
//#define MOSI 11      // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
#define BREAKOUT_RESET  8      // VS1053 reset pin (output)
#define BREAKOUT_CS     6     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    7      // VS1053 Data/command select pin (output)
#define SHIELD_RESET  8      // VS1053 reset pin (unused!)
#define SHIELD_CS     6      // VS1053 chip select pin (output)
#define SHIELD_DCS    7      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 9     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 2       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  // create breakout-example object!
  Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  // create shield-example object!
  //Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
  Serial.println("Adafruit VS1053 Simple Test");
  if (! musicPlayer.begin()) { // initialise the music player
     Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
     while (1);
  Serial.println(F("VS1053 found"));
   if (!SD.begin(CARDCS)) {
    Serial.println(F("SD failed, or not present"));
    while (1);  // don't do anything more
  // list files
  printDirectory(SD.open("/"), 0);
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(20,20);
  // Timer interrupts are not suggested, better to use DREQ interrupt!
  //musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT); // timer int
  // If DREQ is on an interrupt pin (on uno, #2 or #3) we can do background
  // audio playing
  musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);  // DREQ int
  // Play one file, don't return until complete
  Serial.println(F("Playing track 001"));
musicPlayer.playFullFile("5.mp3");
  // Play another file in the background, REQUIRES interrupts!
  Serial.println(F("Playing track 002"));
  musicPlayer.startPlayingFile("5.mp3");
  // File is playing in the background
  if (musicPlayer.stopped()) {
    Serial.println("Done playing music");
    while (1) {
      delay(10);  // we're done! do nothing...
  if (Serial.available()) {
    char c = Serial.read();
    // if we get an 's' on the serial console, stop!
    if (c == 's') {
      musicPlayer.stopPlaying();
    // if we get an 'p' on the serial console, pause/unpause!
    if (c == 'p') {
      if (! musicPlayer.paused()) {
        Serial.println("Paused");
        musicPlayer.pausePlaying(true);
        Serial.println("Resumed");
        musicPlayer.pausePlaying(false);
  delay(100);
/// File listing helper
void printDirectory(File dir, int numTabs) {
   while(true) {
     File entry =  dir.openNextFile();
     if (! entry) {
       // no more files
       //Serial.println("**nomorefiles**");
     for (uint8_t i=0; i<numTabs; i++) {
       Serial.print('\t');
     Serial.print(entry.name());
     if (entry.isDirectory()) {
       Serial.println("/");
       printDirectory(entry, numTabs+1);
       // files have sizes, directories do not
       Serial.print("\t\t");
       Serial.println(entry.size(), DEC);
     entry.close();
мне бы пины правильные, или ответ незя запустить…
может некоторые пины требует шим, а на wemos или esp8266 их не хватает…
подсказка нужна)))
И SD карта, и VS1053b подключаются по SPI. Если там все правильно сделано, проблем быть не должно…
НО!
Китайцы как-то выпустили модуль SD карты, на котором что-то было неправильно (аппаратно) с преобразователем уровня. В общем, карта была постоянно подключена как активное устройство и не давала работать другим SPI устройствам.
Вполне вероятно, что такие неисправные модули выпускаются и продаются и поныне.
Рекомендую использовать модуль без преобразователя напряжения. Тем более, что у ESP на выходе 3.3В и преобразователь все равно не нужен.
И еще, что удалось вспомнить: VS1053b по умолчанию запускается на частоте 12.28МГц. В этом случае желательно, чтобы частота SPI не была выше 1 МГц. После того, как частота DSP будет повышена, можно поднять и частоту SPI.
спс но не помогло, бросил я это дело)))
