#include "si5351.h"
#include "Wire.h"
Si5351 si5351;
long long mnoj = 100;
long long freq = 20000000;
volatile bool change = false;
#include "utility.h"
#include "cat-usdx.h"
Serial.begin(57600);
bool i2c_found;
i2c_found = si5351.init(SI5351_CRYSTAL_LOAD_8PF, 0, 0);
si5351.set_freq(freq*mnoj, SI5351_CLK0);
si5351.update_status();
//Command_GETFreqA();
serialEvent();
if(change == true){
freqSetToSi(freq);
change = false;
// взял с проекта USDX, протокол CAT для ts480, используется в HDSDR
// не все функции используются в этом приёмнике
#define CATCMD_SIZE 32
#define CAT 1 // CAT-interface
volatile uint32_t rxend_event = 0;
void serialEvent();
void Command_UK(char k1, char k2);
void Command_UD();
void Command_UA(char en);
void Command_GETFreqA();
void Command_SETFreqA();
void Command_IF();
void Command_ID();
void Command_PS();
void Command_PS1();
void Command_AI();
void Command_AI0();
void Command_GetMD();
void Command_SetMD();
void Command_RX();
void Command_AG0();
void Command_XT1();
void Command_RT1();
void Command_TX0();
void Command_TX1();
void Command_TX2();
void Command_RC();
void Command_FL0();
void Command_RS();
void Command_VX(char mode);
char CATcmd[CATCMD_SIZE];
void analyseCATcmd()
if((CATcmd[0] == 'F') && (CATcmd[1] == 'A') && (CATcmd[2] == ';'))
Command_GETFreqA();
else if((CATcmd[0] == 'F') && (CATcmd[1] == 'A') && (CATcmd[13] == ';'))
Command_SETFreqA();
else if((CATcmd[0] == 'I') && (CATcmd[1] == 'F') && (CATcmd[2] == ';'))
Command_IF();
else if((CATcmd[0] == 'I') && (CATcmd[1] == 'D') && (CATcmd[2] == ';'))
Command_ID();
else if((CATcmd[0] == 'P') && (CATcmd[1] == 'S') && (CATcmd[2] == ';'))
Command_PS();
else if((CATcmd[0] == 'P') && (CATcmd[1] == 'S') && (CATcmd[2] == '1'))
Command_PS1();
else if((CATcmd[0] == 'A') && (CATcmd[1] == 'I') && (CATcmd[2] == ';'))
Command_AI();
else if((CATcmd[0] == 'A') && (CATcmd[1] == 'I') && (CATcmd[2] == '0'))
Command_AI0();
else if((CATcmd[0] == 'M') && (CATcmd[1] == 'D') && (CATcmd[2] == ';'))
Command_GetMD();
else if((CATcmd[0] == 'M') && (CATcmd[1] == 'D') && (CATcmd[3] == ';'))
Command_SetMD();
else if((CATcmd[0] == 'R') && (CATcmd[1] == 'X') && (CATcmd[2] == ';'))
Command_RX();
else if((CATcmd[0] == 'T') && (CATcmd[1] == 'X') && (CATcmd[2] == ';'))
Command_TX0();
else if((CATcmd[0] == 'T') && (CATcmd[1] == 'X') && (CATcmd[2] == '0'))
Command_TX0();
else if((CATcmd[0] == 'T') && (CATcmd[1] == 'X') && (CATcmd[2] == '1'))
Command_TX1();
else if((CATcmd[0] == 'T') && (CATcmd[1] == 'X') && (CATcmd[2] == '2'))
Command_TX2();
else if((CATcmd[0] == 'A') && (CATcmd[1] == 'G') && (CATcmd[2] == '0')) // add
Command_AG0();
else if((CATcmd[0] == 'X') && (CATcmd[1] == 'T') && (CATcmd[2] == '1')) // add
Command_XT1();
else if((CATcmd[0] == 'R') && (CATcmd[1] == 'T') && (CATcmd[2] == '1')) // add
Command_RT1();
else if((CATcmd[0] == 'R') && (CATcmd[1] == 'C') && (CATcmd[2] == ';')) // add
Command_RC();
else if((CATcmd[0] == 'F') && (CATcmd[1] == 'L') && (CATcmd[2] == '0')) // need?
Command_FL0();
else if((CATcmd[0] == 'R') && (CATcmd[1] == 'S') && (CATcmd[2] == ';'))
Command_RS();
else if((CATcmd[0] == 'V') && (CATcmd[1] == 'X') && (CATcmd[2] != ';'))
Command_VX(CATcmd[2]);
else if((CATcmd[0] == 'U') && (CATcmd[1] == 'K') && (CATcmd[4] == ';')) // remote key press
Command_UK(CATcmd[2], CATcmd[3]);
else if((CATcmd[0] == 'U') && (CATcmd[1] == 'D') && (CATcmd[2] == ';')) // display contents
Command_UD();
else if((CATcmd[0] == 'U') && (CATcmd[1] == 'A') && (CATcmd[3] == ';')) // audio streaming enable/disable
Command_UA(CATcmd[2]);
//else {
//Serial.print("?;");
volatile uint8_t cat_ptr = 0;
void serialEvent(){
if(Serial.available()){
rxend_event = millis() + 10; // block display until this moment, to prevent CAT cmds that initiate display changes to interfere with the next CAT cmd e.g. Hamlib: FA00007071000;ID;
char data = Serial.read();
CATcmd[cat_ptr++] = data;
if(data == ';'){
CATcmd[cat_ptr] = '\0'; // terminate the array
cat_ptr = 0; // reset for next CAT command
analyseCATcmd();
delay(10);
} else if(cat_ptr > (CATCMD_SIZE - 1)){ Serial.print("E;"); cat_ptr = 0; } // overrun
void Command_UK(char k1, char k2){
// cat_key = ((k1 - '0') << 4) | (k2 - '0');
// if(cat_key & 0x40){ encoder_val--; cat_key &= 0x3f; }
// if(cat_key & 0x80){ encoder_val++; cat_key &= 0x3f; }
// char Catbuffer[16];
// sprintf(Catbuffer, "UK%c%c;", k1, k2);
// Serial.print(Catbuffer);
void Command_UD(){
// char Catbuffer[40];
// sprintf(Catbuffer, "UD%02u%s;", (lcd.curs) ? lcd.y*16+lcd.x : 16*2+1, lcd.text);
void Command_UA(char en){
// sprintf(Catbuffer, "UA%01u;", (_cat_streaming = (en == '1')));
// if(_cat_streaming){ Serial.print("US"); cat_streaming = true; }
void Command_GETFreqA(){
char Catbuffer[32];
unsigned int g,m,k,h;
uint32_t tf;
tf=freq;
g=(unsigned int)(tf/1000000000lu);
tf-=g*1000000000lu;
m=(unsigned int)(tf/1000000lu);
tf-=m*1000000lu;
k=(unsigned int)(tf/1000lu);
tf-=k*1000lu;
h=(unsigned int)tf;
sprintf(Catbuffer,"FA%02u%03u",g,m);
sprintf(Catbuffer,"%03u%03u;",k,h);
void Command_SETFreqA(){
char Catbuffer[16];
strncpy(Catbuffer,CATcmd+2,11);
Catbuffer[11]='\0';
//Serial.write(Catbuffer);
freq=(long long)atol(Catbuffer);
change=true;
void Command_IF(){
// char Catbuffer[32];
// unsigned int g,m,k,h;
// uint32_t tf=0;
// uint8_t mode =0;
// tf=freq;
// g=(unsigned int)(tf/1000000000lu);
// tf-=g*1000000000lu;
// m=(unsigned int)(tf/1000000lu);
// tf-=m*1000000lu;
// k=(unsigned int)(tf/1000lu);
// tf-=k*1000lu;
// h=(unsigned int)tf;
// sprintf(Catbuffer,"IF%02u%03u%03u%03u",g,m,k,h);
// sprintf(Catbuffer,"00000+000000");
// sprintf(Catbuffer,"0000");
// Serial.print(mode + 1);
// sprintf(Catbuffer,"0000000;");
void Command_AI(){
// Serial.print("AI0;");
void Command_AG0(){
// Serial.print("AG0;");
void Command_XT1(){
// Serial.print("XT1;");
void Command_RT1(){
// Serial.print("RT1;");
void Command_RC(){
// rit = 0;
// Serial.print("RC;");
void Command_FL0(){
// Serial.print("FL0;");
void Command_GetMD(){
// uint8_t mode =0;
// Serial.print("MD");
// Serial.print(';');
void Command_SetMD(){
// mode = CATcmd[2] - '1';
// vfomode[vfosel%2] = mode;
// change = true;
// si5351.iqmsa = 0; // enforce PLL reset
void Command_AI0(){
void Command_RX(){
// #ifdef TX_ENABLE
// switch_rxtx(0);
// semi_qsk_timeout = 0; // hack: fix for multiple RX cmds
// #endif
// Serial.print("RX0;");
void Command_TX0(){
// #ifdef TX_ENABLE
// switch_rxtx(1);
// #endif
void Command_TX1(){
// #ifdef TX_ENABLE
// switch_rxtx(1);
// #endif
void Command_TX2(){
// #ifdef TX_ENABLE
// switch_rxtx(1);
// #endif
void Command_RS(){
Serial.print("RS0;");
void Command_VX(char mode){
// sprintf(Catbuffer, "VX%c;",mode);
void Command_ID(){
Serial.print("ID020;");
void Command_PS(){
Serial.print("PS1;");
void Command_PS1(){
void freqSetToSi(long long freqShow){
if(freq > 4000){ // установить частоту только больше 1МГц
si5351.set_freq((freq*4)*mnoj, SI5351_CLK0);
change = false;
//Serial.write("OK");
Переделываю чужой код под свои нужды.
на входе через сериал строка ;FA00102000000; она разбирается на строку 00102000000 и преобразуется в long 32 битное 4 байтное число 102000000, через
freq=(long long)atol(Catbuffer); , далее умножается на 100 и поступает в функцию установки частоты на si5351
`si5351.set_freq((freq*4)*mnoj, SI5351_CLK0);`
где частота устанавливается так;
`si5351.set_freq(10200000000ULL, SI5351_CLK0); .`
Почему то частоты устанавливаются до ;FA00999999999; выше 100мгц не хотят.
в чем я не прав?
