Ошибка при компиляции проекта
Всем привет
Могу разобраться в чём ошибка. Установил библиотеку ESP32_ESP32S2_AnalogWrite, из этой библиотеки запускаю пример Servo_Sweep.ino
В итоге вываливается ошибка :
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'uint8_t Pwm::attach(int)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:55:9: error: 'ledcSetup' was not declared in this scope; did you mean 'ledc_stop'?
   55 |         ledcSetup(ch, mem[ch].frequency, mem[ch].resolution);
      |         ledc_stop
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:57:9: error: 'ledcAttachPin' was not declared in this scope; did you mean 'ledcAttach'?
   57 |         ledcAttachPin(pin, ch);
      |         ledcAttach
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'uint8_t Pwm::attach(int, int)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:68:5: error: 'ledcSetup' was not declared in this scope; did you mean 'ledc_stop'?
   68 |     ledcSetup(ch, mem[ch].frequency, mem[ch].resolution);
      |     ledc_stop
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:70:5: error: 'ledcAttachPin' was not declared in this scope; did you mean 'ledcAttach'?
   70 |     ledcAttachPin(pin, ch);
      |     ledcAttach
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'uint8_t Pwm::attachInvert(int)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:78:3: error: 'ledcSetup' was not declared in this scope; did you mean 'ledc_stop'?
   78 |   ledcSetup(ch, mem[ch].frequency, mem[ch].resolution);
      |   ledc_stop
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'uint8_t Pwm::attachInvert(int, int)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:87:5: error: 'ledcSetup' was not declared in this scope; did you mean 'ledc_stop'?
   87 |     ledcSetup(ch, mem[ch].frequency, mem[ch].resolution);
      |     ledc_stop
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'float Pwm::writeServo(int, float)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:180:9: error: 'ledcSetup' was not declared in this scope; did you mean 'ledc_stop'?
  180 |         ledcSetup(ch, mem[ch].frequency, mem[ch].resolution);
      |         ledc_stop
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:182:9: error: 'ledcAttachPin' was not declared in this scope; did you mean 'ledcAttach'?
  182 |         ledcAttachPin(pin, ch);
      |         ledcAttach
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'void Pwm::detach(int)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:253:5: error: 'ledcDetachPin' was not declared in this scope; did you mean 'ledcDetach'?
  253 |     ledcDetachPin(mem[ch].pin); // jitterless
      |     ledcDetach
In file included from C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/esp_common/include/esp_macros.h:13,
                 from C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos/portmacro.h:51,
                 from C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/freertos/FreeRTOS-Kernel/include/freertos/portable.h:57,
                 from C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/freertos/FreeRTOS-Kernel/include/freertos/FreeRTOS.h:69,
                 from C:\Users\30609\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32/Arduino.h:33,
                 from c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:7:
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:254:19: error: 'GPIO_PIN_MUX_REG' was not declared in this scope; did you mean 'GPIO_PIN19_REG'?
  254 |     REG_SET_FIELD(GPIO_PIN_MUX_REG[pin], MCU_SEL, GPIO_MODE_DEF_DISABLE);
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/esp_common/include/esp_assert.h:25:38: note: in definition of macro 'TRY_STATIC_ASSERT'
   25 |             if (__builtin_constant_p(CONDITION) && !(CONDITION)) {          \
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:35:57: note: in expansion of macro 'IS_DPORT_REG'
   35 | #define ASSERT_IF_DPORT_REG(_r, OP)  TRY_STATIC_ASSERT(!IS_DPORT_REG(_r), (Cannot use OP for DPORT registers use DPORT_##OP));
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:84:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
   84 |             ASSERT_IF_DPORT_REG((_r), REG_SET_FIELD);        \
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:254:5: note: in expansion of macro 'REG_SET_FIELD'
In file included from C:/Users/30609/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/xtensa-esp-elf/include/sys/reent.h:458,
                 from C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/newlib/platform_include/sys/reent.h:22,
                 from C:/Users/30609/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/xtensa-esp-elf/include/stdio.h:60,
                 from C:\Users\30609\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32/Arduino.h:27:
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:35:38: note: in expansion of macro 'TRY_STATIC_ASSERT'
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:42:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
   42 |             ASSERT_IF_DPORT_REG((_r), REG_WRITE);        \
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:85:13: note: in expansion of macro 'REG_WRITE'
   85 |             REG_WRITE((_r),((REG_READ(_r) & ~((_f##_V) << (_f##_S)))|(((_v) & (_f##_V))<<(_f##_S))));                  \
In file included from C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/esp_hw_support/include/esp_memory_utils.h:12,
                 from C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos/portmacro.h:54:
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:43:37: note: in definition of macro 'REG_WRITE'
   43 |             (*(volatile uint32_t *)(_r)) = (_v);        \
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:254:42: error: 'MCU_SEL_V' was not declared in this scope
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:43:45: note: in definition of macro 'REG_WRITE'
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:254:42: error: 'MCU_SEL_S' was not declared in this scope
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'bool Pwm::detached(int)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:259:22: error: 'GPIO_PIN_MUX_REG' was not declared in this scope; did you mean 'GPIO_PIN19_REG'?
  259 |   if ((REG_GET_FIELD(GPIO_PIN_MUX_REG[pin], MCU_SEL)) == 0) return true;
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:78:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
   78 |             ASSERT_IF_DPORT_REG((_r), REG_GET_FIELD);        \
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:259:8: note: in expansion of macro 'REG_GET_FIELD'
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:48:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
   48 |             ASSERT_IF_DPORT_REG((_r), REG_READ);        \
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:79:15: note: in expansion of macro 'REG_READ'
   79 |             ((REG_READ(_r) >> (_f##_S)) & (_f##_V));        \
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:49:37: note: in definition of macro 'REG_READ'
   49 |             (*(volatile uint32_t *)(_r));        \
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:259:45: error: 'MCU_SEL_S' was not declared in this scope
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:79:32: note: in definition of macro 'REG_GET_FIELD'
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:259:45: error: 'MCU_SEL_V' was not declared in this scope
C:\Users\30609\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/soc/esp32/include/soc/soc.h:79:44: note: in definition of macro 'REG_GET_FIELD'
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:259:55: error: invalid operands of types 'void' and 'int' to binary 'operator=='
      |                                                          int
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'float Pwm::setFrequency(int, uint32_t)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:283:7: error: 'ledcSetup' was not declared in this scope; did you mean 'ledc_stop'?
  283 |       ledcSetup(ch, frequency, mem[ch].resolution);
      |       ledc_stop
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'uint8_t Pwm::setResolution(int, uint8_t)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:297:7: error: 'ledcSetup' was not declared in this scope; did you mean 'ledc_stop'?
  297 |       ledcSetup(ch, mem[ch].frequency, resolution);
      |       ledc_stop
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'void Pwm::wr_servo(int, float, double, double)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:376:9: error: 'ledcSetup' was not declared in this scope; did you mean 'ledc_stop'?
  376 |         ledcSetup(ch, mem[ch].frequency, mem[ch].resolution);
      |         ledc_stop
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:378:9: error: 'ledcAttachPin' was not declared in this scope; did you mean 'ledcAttach'?
  378 |         ledcAttachPin(pin, ch);
      |         ledcAttach
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'void Pwm::wr_freq_res(int, uint32_t, uint8_t)':
c:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:451:5: error: 'ledcSetup' was not declared in this scope; did you mean 'ledc_stop'?
  451 |     ledcSetup(ch, frequency, resolution);
      |     ledc_stop
Multiple libraries were found for "Servo.h"
  Used: C:\Users\30609\Documents\Arduino\libraries\ESP32_ESP32S2_AnalogWrite
  Not used: C:\Users\30609\AppData\Local\Arduino15\libraries\Servo
exit status 1
Compilation error: exit status 1
Уже и переустанавливал программу. Ничего не помогает и не могу скомпилировать скетч. В чем может быть причина?
Причём, не важно какое устройство выбираешь, ошибка всё та же.
Вот код из примера:
  Controls servo position from 0-180 degrees and back
  https://wokwi.com/projects/350037178957431378
  by dlloydev, December 2022.
#include <Servo.h>
Servo myservo = Servo();
const int servoPin = 5;
  for (int pos = 0; pos <= 180; pos++) {  // go from 0-180 degrees
    myservo.write(servoPin, pos);        // set the servo position (degrees)
    delay(15);
  for (int pos = 180; pos >= 0; pos--) {  // go from 180-0 degrees
    delay(15);
Мы только приветствуем, как разберётесь, расскажите нам.
Пакет кода ЕСП32 обновился и несовместим со старыми скетчами.
У вас ведь стоит ядро ЕСП версии 3 , верно?
Откатите ядро ЕСП32 до версии 2.0.х - и пробуйте
А разве в третьей версии ядра для ESP32 нет функции analogWrite()?
А как это сделать ?
там нет ни одной ошибки, связанной непосредственно с `analogWrite()
Потому что там ее и нету. Она только в третьей версии появилась
Если у вас Ардуино ИДЕ 1.х, то открываете Tools → Boards → Board manager
находите среди установленных пакетов ESP32 от Espressif и видите рядом с названием версию - см картинку
Если я угадал и установленная версия - третья, то выбираете другую версию (обведено красным) - и нажимаете установить
После установки лучше перезапустить ИДЕ
Спасибо большое МММ, поставил 2-ю версию и всё заработало.
МММ, спасибо !!!
Можно отметить как “решение” пост, который вам помог.
Готово, спасибо!
