Потенциометр вместо кнопок
Здравствуйте. Помогите пожалуйста подправить код. Нужно вместо кнопок встроить потенциометр. Не справился, знаний не хватает. Буду весьма признателен за помошь. Спасибо.
/*********** Powerwheels Sabertooth (Altonate) Version777  *********************
  NOTE: Fun revision. Identical to Powerwheels Sabertooth
        but revised to use code suggestions of Arduino
        Forum guru, Alto777.
        Tested on equipment described below, working well
        as expected.
    !!!!!!!!!!!!!!!  IMPORTANT  !!!!!!!!!!!!!!!
  THIS CODE WILL ALLOW OVERRIDING OF KID'S RIDE ON TOYS
  SUCH AS THOSE MADE BY POWERWHEELS AND PEG PEREGO
  IT IS UNTESTED CODE IN ACTUAL RIDE ON WITH RIDER.
      USE AT YOUR OWN RISK!
  DO NOT, I MEAN DO NOT USE ON RIDE ON TOY WITH ANY
  RIDER UNTIL IT HAS BEEN CALIBRATED AND THOROUGHLY
  TESTED TO THE SATISFACTION OF A COMPETENT ADULT
  CARE PROVIDER FOR THE RIDER IF THE RIDER IS NOT AN
  ADULT.
  THIS CODE CONTAINS NO EMERGENCY OVERRIDE AND THE TOY
  SHOULD ONLY BE OPERATED WITHIN THE REACH OF A
  COMPETENT ADULT CARE PROVIDER WHERE A MECHANICALLY
  OPERATED EMERGENCY STOP OVERRIDE DEVICE HAS BEEN INSTALLED,
  EFFECTIVELY REMOVING ALL BATTERY POWER TO THE MOTORS.
  END OF IMPORTANT NOTE
   ---------  INSTRUCTIONS TO BUILDER  ------------
        Requires changes to code depending on your hardware
        if using two position button type pedal, activate
        the line
        pinMode(sensorPin, INPUT_PULLUP);
        by uncommenting it.
        if using typical potentiometer, leave that line
        commented out.
        Also, in function void checkSpeedPot(){}
        have a read through and there's some stuff to set there
        Defaults to testing (printing data to PC over Serial)
        and assumes pushbutton type "all-or-nothing"
        throttle input. These can be adjusted according to
        the notes above and the comments found throughout
        this sketch.
        Also, select the instance of Sabertooth class that suits you
        (default is for Arduino Mega or other with Serial1 UART)
  The circuit:
  - potentiomenter to analog input 0
  OR if you use a switch type pedal
  - switch pin A0 to GND
  - forward switch to D3 to GND
  - reverse switch to D4 to GND
  - LED on digital pin 13 to GND
  - view values in Serial monitor, 9600 baud
  - Arduino TX to Sabertooth S1 (Uno) if selected
  - Arduino RX to Sabertooth S2 (Uno) if selected
    DEFAULT:
  - Arduino TX1 to Sabertooth S1 (Mega)
  - Arduino RX1 to Sabertooth S2 (Mega)
  Tested with 2 x Razor E300 scooter brushed motors @12V, no load
  and seems to be working as expected.
  Test motor specs:
  MY1016-B 24V 350W 2750 RPM electric scooter motor
  Sabertooth DIP switch settings for this Packetized Serial Mode:
   - 1: D for Packetized Serial address 128
   - 2: D
   - 3: D for LiPo, U for all other chemistries (battery cutoff switch)
   - 4: U for 9600 baud, reverse this for 19200 baud: baud select pin 1 U for autobaud
   - 5: U for 9600 baud, reverse this for 19200 baud: baud select pin 2
   - 6: U for Standard Simplified Serial
     I mean, I'm pretty sure. Google "Sabertooth DIP switch wizard" to be sure.
  by Hallowed31
  2024-07-27
  most excellent code revisions
  by Alto777
  2024-07-28
  Library copyright Dimension Engineering, 2012
    "Copyright (c) 2012 Dimension Engineering LLC
    See license.txt for license details."
#include <Sabertooth.h>
// add a library
#include <ezButton.h>
/* choose your version, normal or Mega. Use one only.
  (or roll your own changing 2nd argument in the Sabertooth instance) */
// use line below for Uno Serial on pins 0 and 1
//Sabertooth ST = Sabertooth(128); // address 128
// use line below for Mega, Leonardo, any with a Serial1
Sabertooth ST = Sabertooth(128); // address 128, port Serial1
const int maximum = 1023; // throttle max as calibrated with analogRead();
const int minimum = 0;   // throttle min as calibrated with analogRead();
const byte speedPot = A0;
const byte heartbeatLED = 13;
const byte backwardSwitch = 5;
const byte forwardSwitch = 4;
// make some buttons
ezButton aForwardButton(forwardSwitch);
ezButton aBackwardButton(backwardSwitch);
enum { REVERSE = -1,
       NEUTRAL = 0,
       FORWARD = 1
int directionFlag = NEUTRAL;
int speed = 0;
int m1 = 0; // signal to motor 1
int m2 = 0; // signal to motor 2
unsigned long heartbeatTime;
unsigned long checkSSpeedPotTime;
  SabertoothTXPinSerial.begin(9600);
  Sabertooth::autobaud(SabertoothTXPinSerial);
  // the line below is for a button type pedal
  // comment this out if using potentiometer
  pinMode(speedPot, INPUT_PULLUP);
  pinMode(forwardSwitch, INPUT_PULLUP);
  pinMode(backwardSwitch, INPUT_PULLUP);
  pinMode(heartbeatLED, OUTPUT);
  // set the debounce time
  aForwardButton.setDebounceTime(25);
  aBackwardButton.setDebounceTime(25);
  Serial.println("Powerwheels Sabertooth ver.777");
  delay(1000); // a second to read sketch name
  checkSwitches();
  if (millis() - heartbeatTime >= 500ul) { //500ms
    heartbeatTime = millis();
    digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
  if (millis() - checkSSpeedPotTime >= 100ul) { //100ms
    checkSSpeedPotTime = millis();
    checkSpeedPot();
    Other non blocking code goes here.
    That means no while(), no delay();
void checkSwitches() {
  aForwardButton.loop();
  aBackwardButton.loop();
  // forward switch
  if (aForwardButton.isPressed()) directionFlag = FORWARD;
  if (aForwardButton.isReleased()) directionFlag = NEUTRAL;
  // backward switch
  if (aBackwardButton.isPressed()) directionFlag = REVERSE;
  if (aBackwardButton.isReleased()) directionFlag = NEUTRAL;
void checkSpeedPot() {
  speed = analogRead(speedPot);
  // uncomment for testing, comment out for final install
   printRawData();
  /* IMPORTANT - use only ONE of these speed = map(etc) functions at at time */
  // for potentiometer type throttle
  // speed = (map(speed, minimum, maximum, 0, 1023)) / 8;  //for speed 0 to ±127
  // for pushbutton type throttle, map is reversed because INPUT_PULLUP
  speed = (map(speed, minimum, maximum, 1023, 0)) / 8;  //for speed 0 to ±127
    printMappedData();
  speed = constrain(speed, 0, 127);  //for speed 0 to ±127
  speed = directionFlag * speed;
  m1 = speed;
  m2 = speed;
   printFinalDriveSignal();
  ST.motor(1, m1); // motor 1, speed cast to m1
  ST.motor(2, m2); // notor 2, speed cast to m2
void printRawData() {
  Serial.print("Throttle Input: ");
  Serial.print(speed);
  Serial.print(" ");
void printMappedData() {
  Serial.print("Throttle Mapped To: ");
  Serial.print(" ");
void printFinalDriveSignal() {
  Serial.print("  Final Drive Signal M1: ");
  Serial.print(m1);
  Serial.print("  Final Drive Signal M2: ");
  Serial.println(m2);
  Serial.println();
ИИ спросите …
Не нужно ничего встраивать, код предусматривает оба варианта. Внимательно прочтите комментарии в начале.
Они точно знают
Спросил, уже использую…
P.S. По ходу программистам создали конкурента, причем на солидном уровне. Возможно будут меньше вас доставать подобными запросами. Слышал про ИИ, но впервые воспользовался его услугой только сейчас. Удовлетворен полностью.
Серьезного конкурента создали художникам.
С программированием ИИ не справляется. В любой задаче сложнее мигания светодиодами. Это уже успели выяснить.
Мне вот интересно, сейчас интеллектуальная собственность в искусстве охраняется намного дольше, чем в технике. Не приведет ли развитие ИИ к тому прямо противоположному, а именно, что произведения искусства вообще перестанут считаться интеллектуальной собственностью.
вот даже интересно, чем именно ИИ помог, если в коде уже есть потенциометр?
Видимо вот эту цитату показал:
:smiley:
ты не понял, тебе досталась скромная роль … ИИ
:slight_smile:
Надо раздел делать:
ИИ-помогиии!..
Я все жду, когда запретят входить в раздел с кодом из под ИИ.
так это надо подключить ИИ чтобы он смог отслеживать свой код )))
Следует сделать оговорку, что в пятницу - можно.
