Проблема компиляции
Есть код радио TEA5767. При компиляции выдает ошибку:
Arduino: 1.8.19 (Windows 10), Плата:“Arduino Nano, ATmega328P (Old Bootloader)”
rradio-tea-2-final:66:22: error: ‘PULLUP’ was not declared in this scope
Button btn_forward(7,PULLUP);
C:\Users\Nestor\Documents\Arduino\rradio-tea-2-final\rradio-tea-2-final.ino:66:22: note: suggested alternative: ‘NULL’
NULL
rradio-tea-2-final:67:23: error: ‘PULLUP’ was not declared in this scope
Button btn_backward(6,PULLUP);
C:\Users\Nestor\Documents\Arduino\rradio-tea-2-final\rradio-tea-2-final.ino:67:23: note: suggested alternative: ‘NULL’
NULL
C:\Users\Nestor\Documents\Arduino\rradio-tea-2-final\rradio-tea-2-final.ino: In function ‘void loop()’:
rradio-tea-2-final:248:19: error: ‘class Button’ has no member named ‘isPressed’; did you mean ‘pressed’?
if (btn_forward.isPressed()) {
pressed
rradio-tea-2-final:256:20: error: ‘class Button’ has no member named ‘isPressed’; did you mean ‘pressed’?
if (btn_backward.isPressed()) {
pressed
exit status 1
А это код
// adapted sketch by niq_ro from http://nicuflorica.blogspot.ro
// version 3.0
//#include <SPI.h>
#include <Adafruit_GFX.h>
#include <SPI.h>
#include <TFT_ILI9163C.h>
//#include <radio.h>
#if defined(__SAM3X8E__)
#undef __FlashStringHelper::F(string_literal)
#define F(string_literal) string_literal
#endif
// Color definitions
#define  BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define ORANGE          0xFD20
#define GREENYELLOW     0xAFE5
#define DARKGREEN       0x03E0
uint8_t errorCode = 0;
char buffer[30];
unsigned int RDS[4];
char seg_RDS[8];
char seg_RDS1[64];
char indexRDS1;
 int mezcla;
//radio.debugEnable();
#define __CS 10
#define __DC 8
TFT_ILI9163C display = TFT_ILI9163C(__CS, __DC, 9);
#include <TEA5767.h>
// from https://github.com/andykarpov/TEA5767
#include <Wire.h>
#include <Button.h>
// from http://arduino-info.wikispaces.com/file/view/Button.zip/405390486/Button.zip
TEA5767 Radio;
double old_frequency;
double frequency;
int search_mode = 0;
int search_direction;
int mute =0;
unsigned long last_pressed;
Button btn_forward(7, PULLUP);
Button btn_backward(6, PULLUP);
//Button btn_mute(4, PULLUP);
byte f1, f2, f3, f4;  // number for each zone of frequency
double frecventa;
int frecventa10;      // frequency x 10
#include <EEPROM.h>
//http://tronixstuff.com/2011/03/16/tutorial-your-arduinos-inbuilt-eeprom/
void setup () {
// read value of last frequency
f1 = EEPROM.read(101);
f2 = EEPROM.read(102);
f3 = EEPROM.read(103);
f4 = EEPROM.read(104);
// recover number
frecventa = 100*f1 + 10*f2 + f3 + 0.1*f4;
  Wire.begin();
  Radio.init();
//  Radio.set_frequency(104.5);
   Radio.set_frequency(frecventa);
  display.begin();
  display.fillScreen();
  // Print a logo message to the LCD.
  display.setRotation(1);
  display.fillScreen(RED);
  display.fillScreen(GREEN);
  display.fillScreen(BLUE);
  display.setTextSize(1);
  display.setTextColor(WHITE,BLACK);
  display.setCursor(0,0);
  display.println("Adaptat Vlad Gheorghe");
  display.setTextSize(2);
  display.setCursor(1, 16);
  display.setTextColor(WHITE, BLACK);
  display.print("FM");
  display.setCursor(30, 20);
  display.print(" radio ");
  display.setCursor(0, 32);
  display.setTextColor(BLACK);
  display.print("with TEA5767");
  display.setCursor(0, 40);
  display.print("version ");
  display.print("versiunea 3.2");
display.setCursor(0, 55);
  display.print("cu afisare nume canal");
//  display.display();
  delay (3000);
  display.fillScreen(CYAN);
  display.fillScreen(MAGENTA);
  display.fillScreen(YELLOW);
 // display.fillScreen();
void loop () {
  unsigned char buf[5];
  int stereo;
  int signal_level;
  double current_freq;
  unsigned long current_millis = millis();
  if (Radio.read_status(buf) == 1) {
    current_freq =  floor (Radio.frequency_available (buf) / 100000 + .5) / 10;
    stereo = Radio.stereo(buf);
    signal_level = Radio.signal_level(buf);
    display.setTextColor(CYAN,BLACK);
    display.print("FM ");
    display.setCursor(30,5);
    display.print("Radio cu TEA5767");
    display.setTextColor(BLUE);
    display.setCursor(0,17);
    display.print("Adaptat Vlad Gheorghe");
   display.setTextSize(4);
   display.setTextColor(ORANGE,BLACK);
   display.setCursor(0,30);
   if (current_freq < 100) display.print(" ");
   display.print(current_freq,1);
 display.setCursor(91,63); display.setTextColor(RED,BLACK);
   display.print("MHz");
   display.setCursor(15,70);
   display.setTextColor(GREENYELLOW,BLACK);
   if (stereo) display.print("Stereo");  else display.print("Mono  ");
     display.setTextColor(BLACK,YELLOW);
   // display level of FM signal..
  display.setCursor(0,115);
   display.setTextColor(GREEN, BLACK);
   if (signal_level<10) display.print(" ");
    display.print("Level: ");
   display.print(signal_level);display.setTextColor(GREEN, BLACK);
   display.print("/15");
   printpost(current_freq);
   delay (50);
//display.fillScreen();
// draw a signal level triangle...
   display.drawLine(80, 30, 80, 45, BLACK);
   display.drawLine(80, 45, 50, 45, BLACK);
  display.drawLine(50, 45, 80, 30, BLACK);
int sl = signal_level;
   for (int x = 0; x < sl; x++)
    //display.clearScreen();
   display.drawLine(80+3*x, 120, 80+3*x, 120-x, GREEN);
show_signal_level(signal_level);
// draw an antenna
   display.drawLine(95, 82, 95, 95, YELLOW);
   display.drawLine(96, 82, 96, 95, YELLOW);
   display.drawLine(92, 82, 95, 86, YELLOW);
   display.drawLine(91, 82, 95, 87, YELLOW);
   display.drawLine(99, 82, 96, 86, YELLOW);
   display.drawLine(100, 82, 96, 87, YELLOW);
  if (search_mode == 1) {
      if (Radio.process_search (buf, search_direction) == 1) {
          search_mode = 0;
      frecventa =  floor (Radio.frequency_available (buf) / 100000 + .5) / 10;
      frecventa10 = 10*frecventa;
 f1 = frecventa10/1000;
 frecventa10 = frecventa10 - 1000*f1;
 f2 = frecventa10/100;
 frecventa10 = frecventa10 - 100*f2;
 f3 = frecventa10/10;
 f4 = frecventa10 - 10*f3;
EEPROM.write(101,f1);
EEPROM.write(102,f2);
EEPROM.write(103,f3);
EEPROM.write(104,f4);
    last_pressed = current_millis;
    search_mode = 1;
    search_direction = TEA5767_SEARCH_DIR_UP;
    Radio.search_up(buf);
    delay(500);
    search_mode = 1;
    search_direction = TEA5767_SEARCH_DIR_DOWN;
    Radio.search_down(buf);
    delay(500);
   delay(500);
void show_signal_level(int level){
  byte xs=98;
  byte ys=120;
  for(int i=0;i<15;i++){
    if(i%2!=0)display.drawLine(xs+i,ys,xs+i,ys-i,level>=i?WHITE:BLACK);
void printpost(double current_freq)
 // switch(current_freq)
    if (current_freq==101.1) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("Actualitati");}
    if (current_freq==103.1) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("Cultural   ");}
    if (current_freq==105.0) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("Viva       ");}
    if (current_freq==106.5) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("Europa FM  ");}
if (current_freq==88.4) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("Impact FM   ");}
   if (current_freq==91.1) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("Magic FM   ");}
   if (current_freq==91.9) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("KISS FM     ");}
   if (current_freq==94.9) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("Radio HIT   ");}
   if (current_freq==96.3) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("Radio Iasi  ");}
   if (current_freq==97.9) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("RFI          ");}
   if (current_freq==99.2) { display.setCursor(5,90);
   display.setTextColor(YELLOW,BLACK);display.print("DIGI FM      ");}
В строке 67 необъявленный идентификатор PULL-UP
Но код явно не тот, от которого приведены ошибки
Посмотрите, пожалуйста код!
Для начала приведите сообщение об ошибках для этого кода
Вот
NULL
NULL
pressed
pressed
exit status 1
Вы сначала сами его посмотрите. Вам же уже сказали, что сообщения об ошибках от другого кода.
Смотрим строку 67 приведенного выше кода
Видим, что строки не соответствуют. Вывод - сообщения об ошибках к выложенному коду отношения не имеют. Будете упорствовать дальше? Дело ваше
Могу только предположить, что вы используете не ту библиотеку Button.h, которую использовал автор кода
Я не упорствую!!! Я открываю этот код в Ардуино и при проверке выдается такая ошибка. А библиотеку попробую поменять.
Вот этот же код с другой библиотекой
NULL
NULL
exit status 1
ссылку на библиотеку дайте
По моему это просто тролль
Я реально живой человек и разыгрывать вас всех мне нет смысла!!!
Автор ссылается на эту библиотеку
http://arduino-info.wikispaces.com/file/view/Button.zip/405390486/Button.zip но она не открывается
Ставил вот эту https://www.arduino.cc/reference/en/libraries/button/
И? Стесняюсь спросить: она у тебя установлена?
Дорогая редакция! Спасибо вам за рецепт. Авокадо мы заменили отварным картофелем, а креветки — поджаренным салом, но в целом ваш рецепт салата из авокадо с креветками нам очень понравился. (с)
ТС! А почему ты решил, что замена эквивалентна?
Я пробовал разные, в том числе и эту GitHub - carlynorama/Arduino-Library-Button: This is a library for adding buttons to Arduino projects. It supports events like OnPress and OnRelease. и ниодна не хочет работать. Где взять библиотеку по ссылке автора я не знаю.
З.Ы. Умничать я тоже умею. Я обращался за помощью!
Если станешь тявкать в ответ, то получишь глум, насмешки и покинешь форум.
Ты не посмотрел на дату кода на ГитХабе? Ему 10 лет!!! С вероятность 99% ты его не соберешь сейчас. Отсутствующую библиотеку нужно заменить. То есть ПЕРЕПИСАТЬ код для работы с любой другой. Понимаешь ли? Не подставить другую. а пепеписать под неё. Библиотек для кнопок под Ардуино есть не одна сотня.
Если ты программист (или планируешь им стать), то начни с более простого кода, для изучения.
Если тебе просто нужен результат - обратись в коммерческий раздел форума “Ищу исполнителя” за разумные пару тысяч рублей тебе напишут код.
Отлаживать будет трудно без этой платы приемника. Ищи такого исполнителя, у которого есть плата или который живет близко к тебе.
Влад, я те умоляю… посмотри профиль ТС на старом форуме…
Типичный юзер из разряда “я ардуино пользуюсь один раз в пять лет” с соответствующим уровнем (отсутствием) знаний
