Проблема с примером JoystickMouseControl.ino
Решил подключить к плате Arduino Uno двухосевый джойстик чтобы протестировать его работу в виде компьютерной мыши.
Нашёл схему на официальном сайте ардуино, всё подключил как надо.
Там же вытащил код и скопировал его в Arduino IDE и нажал Upload.
Выдаёт ошибку.
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino: In function 'void setup()':
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino:54:3: error: 'Mouse' was not declared in this scope
   Mouse.begin();
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino: In function 'void loop()':
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino:77:5: error: 'Mouse' was not declared in this scope
     Mouse.move(xReading, yReading, 0);
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino:84:10: error: 'Mouse' was not declared in this scope
     if (!Mouse.isPressed(MOUSE_LEFT)) {
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino:84:26: error: 'MOUSE_LEFT' was not declared in this scope
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino:84:26: note: suggested alternative: 'MOUSE_h'
                          MOUSE_h
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino:91:9: error: 'Mouse' was not declared in this scope
     if (Mouse.isPressed(MOUSE_LEFT)) {
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino:91:25: error: 'MOUSE_LEFT' was not declared in this scope
C:\Users\ScoolBoy\AppData\Local\Temp\.arduinoIDE-unsaved20221027-3740-ngbcqs.b1si9\sketch_nov27a\sketch_nov27a.ino:91:25: note: suggested alternative: 'MOUSE_h'
                         MOUSE_h
exit status 1
Compilation error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
Поди ещё одну библиотеку с официального сайта ардуино поставить надобно?
Переведи эту строку и получишь ответ
Перевести я успел уже давно.
проверил, строка #include “Mouse.h” в самом начале стоит
А сама маус? (прочти установка сторонних библиотек)
Всмысле, библиотека mouse?
Конечно. Мало ее прописать, она еще должна быть доступна компилятору
Тоесть сейчас она недоступна ему?
Компилятор так и пишет - недоступна.
Несколько библиотек найдено для "Mouse.h"
  Используется: C:\Users\ScoolBoy\Documents\Arduino\libraries\Mouse
  Не используется: C:\Users\ScoolBoy\AppData\Local\Arduino15\libraries\Mouse
Там написано про то, что библиотека mouse.h не найдена
Раз не может найти, значит недоступна. А не может найти, потому что ее нет
И что в этом непонятного?
Дак если я её заново установил, нашёл официальную.
Важно! необходимо, чтобы библиотека была именно ТА!!, которую инклюдил автор скетча, а не первая попавшаяся
Компилятор черным по белому пишет, что не найдена. Значит нужной библиотеки нет. Нужна именно та, которая использовалась для этого скетча, никакая другая, даже если в ее названии есть слово Mouse, не подойдет
Сам код и схему подключения я брал с официального сайта ардуино.
Там ни слова не говорится где и какую библиотеку устанавливать.
Вот даже ссылка на сайт с которого я брал всё.
https://docs.arduino.cc/built-in-examples/usb/JoystickMouseControl
Ссылку, где вы смотрели схему и скачали код - выложите
этот код только для Микро, Дуе и Тини.
На Уно работать не будет
Hardware Required
  • Arduino Leonardo, Micro, or Due board
