Проблемы индикации 1602
Всем добрый, собираю нагрузку и з этого источника: Building a Constant Current/Constant Power Electronic Load – Kerry D. Wong, паять умею, програмировать нет. Вот код:
 * Electronic Load
 * <a href="http://www.kerrywong.com" title="http://www.kerrywong.com" rel="nofollow">http://www.kerrywong.com</a>
 * 10/2013
#include <SPI.h>
#include <LiquidCrystal.h>
#include <Encoder.h>
#include <SPI.h>
//LCD pins
const int pinRS = 2;
const int pinEn = 3;
const int pinD4 = 4;
const int pinD5 = 7;
const int pinD6 = 8;
const int pinD7 = 9;
//analog pin 5
const int pinLoadVoltage = 5;
//MCP4921 SPI
const int PIN_CS = 10;
const int BTN_RESET = 14;
const int BTN_RANGE_X2 = 15;
const int BTN_MODE = 16;
const int BTN_ENC = 17;
const int IDX_BTN_RESET = 0;
const int IDX_BTN_RANGE_X2 = 1;
const int IDX_BTN_MODE = 2;
const int IDX_BTN_ENC = 3;
const int LOOP_MAX_COUNT = 2000;
int DACGain = 1; //default gain 1xVref.
int loadMode = 0; // 0: Constant Current, 1: Constant Power
const float EXT_REF_VOLTAGE = 0.333;
LiquidCrystal lcd(pinRS, pinEn, pinD4, pinD5, pinD6, pinD7);
Encoder currentAdjEnc(5, 6);
int buttons[]={BTN_RESET, BTN_RANGE_X2, BTN_MODE, BTN_ENC};
int buttonReadings[3];
int lastButtonStates[]={HIGH, HIGH, HIGH, HIGH};
int currentButtonStates[]={HIGH, HIGH, HIGH, HIGH};
long lastDebounceTime[3];
long oldEncPosition = -999;
long curEncPosition = 0;
int DACSetStep = 1;
int encoderValue = 0;
int loopCounter = 0;
int DACSetValue = 0;
long ADSum = 0;
float vLoad = 0.0;
float setPower = 0.0;
float setCurrent = 0.0;
    for (int i = 0 ; i < 4 ; i++) {
        pinMode(buttons[i], INPUT);
        digitalWrite(buttons[i], HIGH);
    pinMode(PIN_CS, OUTPUT);
    SPI.begin();
    SPI.setClockDivider(SPI_CLOCK_DIV2);
    lcd.begin(16, 2);
void getCurrentEncPosition()
    curEncPosition = currentAdjEnc.read() / 4;
    if (curEncPosition != oldEncPosition) {
        if (curEncPosition > oldEncPosition) {
            encoderValue += DACSetStep;
            if (encoderValue > 4095) encoderValue = 4095;
            encoderValue -= DACSetStep;
            if (encoderValue < 0) encoderValue = 0;
        oldEncPosition = curEncPosition;
        if (loadMode == 0) //Constant Current mode
            setDACOutput(encoderValue);
        } else { //Constant Power mode
            setDACOutput(DACSetValue);
//Buffered DAC output
void setDACOutput(unsigned int val)
    byte lByte = val & 0xff;
    //                      SHDN     GA            BUF
    byte hByte = val >> 8 | 0x10 | DACGain << 5 | 1 << 6;
    PORTB &= 0xfb;
    SPI.transfer(hByte);
    SPI.transfer(lByte);
    PORTB |= 0x4;
void displayStatus()
    lcd.clear();
    //average load voltage
    vLoad = ADSum * 1.0 / (float) LOOP_MAX_COUNT / 1024.0 * 5.0  * (0.974 + 21.91) / 0.974;
        float vSense = 1.0 * encoderValue / 4096.0 * EXT_REF_VOLTAGE;
        float i = 3 * 10 * vSense; // 3 sets of MOSFET in parallel, 0.1 ohm
        if  (DACGain == 0) i *=2; // x2
        lcd.print("CI,I Set=");
        if (i < 1.0) {
            lcd.print(i * 1000,0);
            lcd.print(" mA");
            lcd.print(i ,2);
            lcd.print(" A");
        setPower = (float) encoderValue / 20.0; //approximately 0-200W
        lcd.print("CP, P Set=");
        if (vLoad > 0.5) {//minimum 0.5V
            setCurrent = setPower / (float) vLoad;
            //desired sense voltage. Since we have 3
            //sets of MOSFETS, the results are devided
            //by 3 and multipled by the value of the sense
            //resistor
            float vSense = setCurrent / 3.0 * 0.1;
            DACSetValue = (int) (vSense/EXT_REF_VOLTAGE * 4096.0 + 0.5);
            if (setCurrent < 10.0) {
                DACGain = 1;
                DACGain = 0;
                DACSetValue = (int) ((float) DACSetValue / 2.0 + 0.5);
            if (setPower >= 100.0) {
                lcd.print(setPower, 1);
            else {
               lcd.print(setPower, 2);
            setPower = 0;
        lcd.print("W");
    lcd.setCursor(0, 1);
    lcd.print("LOAD V=");
    lcd.print(vLoad, 2);
    lcd.print(" V");
    int idx = 0;
    for (int i = 0 ; i < 4; i++) {
        buttonReadings[i] = digitalRead(buttons[i]);
        if (buttonReadings[i] != lastButtonStates[i]) lastDebounceTime[i] = millis();
        if (millis() - lastDebounceTime[i] > 50) { //debouncing the buttons
            if (currentButtonStates[i] != buttonReadings[i]) {
                currentButtonStates[i] = buttonReadings[i];
                //actions
                if (currentButtonStates[i] == LOW) {
                    switch (i) {
                        case IDX_BTN_RESET:
                        //reset output current to 0
                           encoderValue = 0;
                           DACSetValue = 0;
                        case IDX_BTN_RANGE_X2:
                        //switch between 100W/200W maximum power mode
                            DACGain = DACGain == 1? 0 : 1;
                            if (loadMode == 0) {
                        case IDX_BTN_MODE:
                        //switch between constant current and constant power
                            loadMode = loadMode == 1? 0 : 1;
                        case IDX_BTN_ENC:
                        //cycle through different encoder steps: 1/10/100
                            DACSetStep *= 10;
                            if (DACSetStep > 100) DACSetStep = 1;
        lastButtonStates[i] = buttonReadings[i];
    getCurrentEncPosition();
    loopCounter++;
    // used to smooth out the analogRead results
    ADSum += analogRead(pinLoadVoltage);
    if (loopCounter == LOOP_MAX_COUNT) {
        displayStatus();
        loopCounter = 0;
        ADSum = 0;
Проблема в том, что при компиляции скетча появляются какие-то предупреждения:
D:\arduino-1.8.19\ElectronicLoad\ElectronicLoad.ino: In function ‘loop’:
D:\arduino-1.8.19\ElectronicLoad\ElectronicLoad.ino:225:47: warning: iteration 3 invokes undefined behavior [-Waggressive-loop-optimizations]
D:\arduino-1.8.19\ElectronicLoad\ElectronicLoad.ino:185:24: note: within this loop
D:\arduino-1.8.19\hardware\arduino\avr\cores\arduino\main.cpp: In function ‘main’:
После загрузки скетча появляются еле заметные промаргивания экрана, но изображения нет, контрастность в норме, пример hello world заливается отлично, изображение есть. Помогите кто чем может, пишу первый раз, не ругайте если что.
Массив состоит из трех элементов
а цикл пробегает его 4 раза
так что это хоть и предупреждение, но на самом деле предупреждает оно о очень грубой ошибке - выход за границы массива.
Кстати, ровно то же самое относится и к массиву
Так что в итоге нужно в коде изменить?
Для начала я бы привел в соответвие размерность обозначенных массивов числу пинов и посмотрел, что изменится.
PS
Если вы совсем ничего не понимаете в коде - просто увеличьте эти массивы до 4х элементов
Т.е. там где 3 в указанных вами строках напишу 4. Спасибо, попробую.
Спасибо огромное, завелось!!! Спасибо
Если вы получили ответ на вопрос, пометьте ветку как решенную. Это поможет другим участникам, кто будет читать форум после вас
А как это сделать, как пометить как решенную?
Посмотрел… никак
Сорри, оказывается на этом форуме такого нет. Так я зря вас дернул
Не беда, спасибо ещё раз.
