Снифер цифровых сигналов
этот более высокоэфективный но нету схемы
нашёл и к нему программу
компилируется?
И сам жеж отвечу, если библиотека TFT_eSPI версии 2.5.43
мои настройки дисплея
#define USER_SETUP_INFO "User_Setup"
#define ILI9341_DRIVER                            // Generic driver for common displays
// ###### EDIT THE PIN NUMBERS IN THE LINES FOLLOWING TO SUIT YOUR ESP32 SETUP   ######
// For ESP32 Dev board (only tested with ILI9341 display)
// The hardware SPI can be mapped to any pins
#define TFT_MISO 19
#define TFT_MOSI 23
#define TFT_SCLK 18
#define TFT_CS   15  // Chip select control pin
#define TFT_DC    2  // Data Command control pin
#define TFT_RST   4  // Reset pin (could connect to RST pin)
#define TFT_RST  -1  // Set TFT_RST to -1 if display RESET is connected to ESP32 board RST
#define TOUCH_CS 21     // Chip select pin (T_CS) of touch screen
// Comment out the #defines below with // to stop that font being loaded
// The ESP8366 and ESP32 have plenty of memory so commenting out fonts is not
// normally necessary. If all fonts are loaded the extra FLASH space required is
// about 17Kbytes. To save FLASH space only enable the fonts you need!
#define LOAD_GLCD   // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2  // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4  // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6  // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7  // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8  // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
//#define LOAD_FONT8N // Font 8. Alternative to Font 8 above, slightly narrower, so 3 digits fit a 160 pixel TFT
#define LOAD_GFXFF  // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
// Comment out the #define below to stop the SPIFFS filing system and smooth font code being loaded
// this will save ~20kbytes of FLASH
#define SMOOTH_FONT
// For the STM32 processor define the SPI port channel used (default 1 if undefined)
//#define TFT_SPI_PORT 2 // Set to 1 for SPI port 1, or 2 for SPI port 2
// Define the SPI clock frequency, this affects the graphics rendering speed. Too
// fast and the TFT driver will not keep up and display corruption appears.
// With an ILI9341 display 40MHz works OK, 80MHz sometimes fails
// With a ST7735 display more than 27MHz may not work (spurious pixels and lines)
// With an ILI9163 display 27 MHz works OK.
// #define SPI_FREQUENCY   1000000
// #define SPI_FREQUENCY   5000000
// #define SPI_FREQUENCY  10000000
// #define SPI_FREQUENCY  20000000
#define SPI_FREQUENCY  27000000
// #define SPI_FREQUENCY  40000000
// #define SPI_FREQUENCY  55000000 // STM32 SPI1 only (SPI2 maximum is 27MHz)
// #define SPI_FREQUENCY  80000000
// Optional reduced SPI frequency for reading TFT
#define SPI_READ_FREQUENCY  20000000
// The XPT2046 requires a lower SPI clock rate of 2.5MHz so we define that here:
#define SPI_TOUCH_FREQUENCY  2500000
// The ESP32 has 2 free SPI ports i.e. VSPI and HSPI, the VSPI is the default.
// If the VSPI port is in use and pins are not accessible (e.g. TTGO T-Beam)
// then uncomment the following line:
#define USE_HSPI_PORT
пока заказал нану без юсб разъёма и такой дисплей, приедит-проверю
я за эту более сложную ещё не брался, код то есть , а схемы то нет, у него на видео по моему радиомодуль зачем-то впаян и плата ,которую он показывает, вероятно, самодельная
какой-то он недоделанный - прокрутки нет, при заполнении экрана он просто стирает и начинает с нуля. Памяти тоже нет никакой, посмотреть строчки “назад” тоже нельзя.
В Нане очень мало памяти, лучше делать на ЕСП32, в ней хотя бы буфер текста можно сделать
А вообще я чаще просто ставлю пару модулей HC-12 или JDY-40 и делаю прозрачный канал на подключенный к УСБ контроллер
меня устраивает без прокрутки, вы в своём мультиметре часто прокрутку используете?
главное ,чтобы гальваническая развъязка была и мог тестить живое или мёртвое железо,далее компом
а зачем тебе схема если есть распиновка?
лучше развязки, через при передаче по радио - и быть не может :slight_smile:
Ну на телевизоре как-то поудобнее смотреть:
я ещё не на том уровне чтобы без названий компонент и схемы смог её собрать , я нахожу нечто похожее на алиекспресс но не уверен что соберу
Закажи в платном разделе
зачем? цель достингута и без денег
да я накосячил, думал в другой ветке пишу )))
