STM32CubeIDE (вопросы и ответы)
накидал blink на CMSIS
получилось сильно меньше занятой flash
 * @file           : main.cpp
 * @author         : Auto-generated by STM32CubeIDE
 * @brief          : Main program body
 * @attention
 * Copyright (c) 2024 STMicroelectronics.
 * All rights reserved.
 * This software is licensed under terms that can be found in the LICENSE file
 * in the root directory of this software component.
 * If no LICENSE file comes with this software, it is provided AS-IS.
#include <stdint.h>
#include "stm32f4xx.h"
#include "f4base.h"
int main(void)
	SystemInit();
	STM32F411CEU6startHSErcc();
	SystemCoreClockUpdate();
	f4initPA0key();
	f4initTIM4();
    /* Loop forever */
	for(;;){
		//f4setPC13led(f4readPA0key());
		static unsigned long timerBlink = 0UL; if ((millis() - timerBlink) >= 1000UL) {timerBlink = millis();f4togPC13led();}
 * f4base.h
 *  Created on: Aug 29, 2024
 *      Author: seleznev_a
#ifndef F4BASE_H_
#define F4BASE_H_
int STM32F411CEU6startHSErcc(void);
void f4initPC13led(void);
void f4setPC13led(int AledONOFF);
void f4togPC13led(void);
unsigned long millis(void);
void delay_ms(unsigned long period_ms);
void f4initPA0key(void);
bool f4readPA0key(void);
void f4initTIM4(void);
#endif /* F4BASE_H_ */
 * f4base.cpp
#include "f4base.h"
volatile unsigned long msTicks = 0;
void TIM4_IRQHandler(void) {
    TIM4->SR &= ~TIM_SR_UIF;
	++msTicks;
void f4initTIM4(void) {
	RCC->APB1ENR |= RCC_APB1ENR_TIM4EN; // clock Timer4 ON
	TIM4->SR = 0;
	TIM4->CNT = 0;
	TIM4->PSC = (SystemCoreClock / 2 / 1000000) - 1; // делитель
	TIM4->ARR = 1999; // значение перезагрузки -> 1 msec
	TIM4->DIER |= TIM_DIER_UIE;
	NVIC_EnableIRQ (TIM4_IRQn);
	TIM4->CR1 |= TIM_CR1_CEN; // включаем счётчик
void delay_ms(unsigned long period_ms) {
	unsigned long startTimer = millis();
	while ((millis() - startTimer) < period_ms);
unsigned long millis(void) {
	return msTicks;
void f4setPC13led(int AledONOFF) {
	if (AledONOFF) GPIOC->BSRR |= GPIO_BSRR_BR13; // PC13 LOW
	else GPIOC->BSRR |= GPIO_BSRR_BS13; // PC13 HIGH
void f4togPC13led(void) {
    GPIOC->ODR ^= GPIO_ODR_OD13; // toggle LED
void f4initPA0key(void) {
	RCC->AHB1ENR |= RCC_AHB1ENR_GPIOAEN; // GPIO port A
	GPIOA->MODER &= ~GPIO_MODER_MODER0; // 00: Input mode (reset state)
	GPIOA->OSPEEDR &= ~GPIO_OSPEEDER_OSPEEDR0; // 00: Low speed
	GPIOA->PUPDR &= ~GPIO_PUPDR_PUPDR0; // No pull-up, pull-down
	GPIOA->PUPDR |= GPIO_PUPDR_PUPDR0_0; // pull-up 01
bool f4readPA0key(void) {
	return (GPIOA->IDR & GPIO_IDR_IDR_0);
void f4initPC13led(void) {
	RCC->AHB1ENR |= RCC_AHB1ENR_GPIOCEN; // GPIO port C
	GPIOC->MODER |= GPIO_MODER_MODE13_0; // 01: Output mode
	GPIOC->MODER &= ~GPIO_MODER_MODE13_1; // 01: Output mode
	GPIOC->OTYPER &= ~GPIO_OTYPER_OT_13; // 0: Output push-pull (reset state)
	GPIOC->OSPEEDR &= ~GPIO_OSPEEDER_OSPEEDR13; // 00: Low speed
	GPIOC->PUPDR &= ~GPIO_PUPDR_PUPDR13; // No pull-up, pull-down
int STM32F411CEU6startHSErcc(void) {
	f4initPC13led();
	f4setPC13led(0);
	FLASH->ACR |=FLASH_ACR_LATENCY_3WS; // VOS[1:0] = 0x11, the maximum value of fHCLK = 100 MHz. 3 WS (4 CPU cycles)
	RCC->CR |= RCC_CR_HSEON; // HSE ON
	int StartUpCounter; // wait counter
	for(StartUpCounter=0; ; StartUpCounter++) { // wait ON
	    if (RCC->CR & RCC_CR_HSERDY) break; // HSE is ON
	    if (StartUpCounter > 0x1000) { // timeout
	    	RCC->CR &= ~RCC_CR_HSEON; // HSE OFF
	    	return 1; // exit bad HSE
	RCC->PLLCFGR |= RCC_PLLCFGR_PLLSRC_HSE; // PLL source set HSE
	RCC->PLLCFGR &= ~RCC_PLLCFGR_PLLM; // PLLM=0
	RCC->PLLCFGR |= RCC_PLLCFGR_PLLM_2 | RCC_PLLCFGR_PLLM_3; // PLLM=12
	RCC->PLLCFGR &= ~RCC_PLLCFGR_PLLN; // PLLN=0
	RCC->PLLCFGR |= RCC_PLLCFGR_PLLN_5 | RCC_PLLCFGR_PLLN_6; // PLLN=96
	RCC->PLLCFGR &= ~RCC_PLLCFGR_PLLP; // PLLP=0 -> div 2
	RCC->CR |= RCC_CR_PLLON; // PLL ON // result = 25MHz / 12 * 96 / 2 = 100MHz
	    if (RCC->CR & RCC_CR_PLLRDY) break; // PLL is ON
	    	RCC->CR &= ~RCC_CR_PLLON; // PLL
	    	return 2; // exit bad PLL
	RCC->CFGR |= RCC_CFGR_SW_PLL; // 10: PLL selected as system clock
	//RCC->CFGR |= RCC_CFGR_HPRE_DIV1; // AHB -> 0xxx: system clock not divided
	RCC->CFGR |= RCC_CFGR_PPRE1_DIV2; // APB1 -> 100: AHB clock divided by 2 -> 50MHz
	//RCC->CFGR |= RCC_CFGR_PPRE2_DIV1; // APB2 -> 0xx: AHB clock not divided -> 100MHz
	f4setPC13led(1);
	return 0; // good
ну дальше, с нарастанием кода, эта разница будет не так сильна)
а еще, есть же LL вместо HAL (правда не все поддерживает), очень близко к CMSIS получится на выходе.
дык не из за размера же я не выбираю HAL и прочие “прокладки”, полноценной документации удобной я не нашел, какие то огрызки в интернете.
а с регистрами все гораздо понятнее, открыл книжку почитал что для чего.
Исчезает возможность переноса кода между МК, но мне это не надо, я из спортивного интереса программирую.
такой документации как у ST и Espressif, я больше не встречал ни у кого!
вот ты мне это расскажешь, когда например, до USB доберешься))
да мы тут все такие )) :handshake:
вряд ли)
ну хз, не удобный HAL, не нравится он мне и доки тоже :slight_smile:
На AVR более-менее за пару лет я освоил регистры.
А STM32 - это совершенно другое. Причем всё другое (и нет EEPROM, но это как я уже знаю решаемо и причем по разному).
Поэтому сначала HAL. Как мне уже объяснили, примерно тоже самое что и на ардуино.
Начинать надо с простого. Иначе на сложном в начале можно застрять ))
Из наблюдений - черные таблетки F411 - железобетонные платы. Перепутал
полярность питания, подключил плюс к минусу- и нифига страшного, заметил только потому, что прошиваться отказалась. Включил правильно - ожила, прошивается, работает.
Ардуино бы сгорела безвозвратно.
Не факт. Много раз путал питание на Atmega328P (правда в корпусе дип) всё нормально, продолжали работать в штатном режиме.
Более того, они еще прошивки чужие принимают. Не работают, правда, но проглатывают и не морщатся )))
Один раз сильно удивился и долго пытался разобраться, почему вдруг плата работать перестала - несколько раз прошивку заливал, а плата - ноль внимания, фунт презрения. Потом досмотрелся, что в IDE выбрана плата F401 ))
А я то думал, что прошивка в STM надёжно защищена, но ан нет
PS из статьи на Хабре
случайно наткнулся на твой пост, о блюпиле, что после однократной загрузки не шьётся, тут ответил
PS если я тебя правильно понял
иногда надо дочитывать до конца,чтоб потом не некрофилить!
я жеж не настоящий сталевар, STM для меня ещё рановато, а тут как в присказке лишний… )))
тут даже обновиться невозможно…кругом геноцид…
Полтора дня ковыряюсь в CubeIDE, среда конечно комфортней чем arduino IDE, в плане отладки пооперативней всё будет
Наверное тут спрошу:
Приехала плата STM32F401RET6:
Вчера в Cube по быстрому сварганил проект для поморгать светодиодом.
Прошивка залетела прям через GB-сервер. Из чего я предполагаю, что чип то там стоит оригинальный?
Единственное что разочаровало…
Диод (синий) не моргает, а просто горит. Я в кубе указывал как и у синей таблетки PC13, может у этой платы другой?
Правда тактирование вообще не трогал, может быть проблема в этом…
НО! Самое смешное, что открыв пакет и подключив плату к ST-Link - я увидел тоже просто горящий синий светодиод, а не моргающий.
Я слил ту прошивку, вот её код:
HEX
D0 1A 00 20 AD 01 00 08 1F 19 00 08 35 17 00 08 1D 19 00 08 4F 03 00 08 F1 2F 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 59 19 00 08 85 03 00 08 00 00 00 00 2D 19 00 08 5B 19 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 00 00 00 00 C7 01 00 08 C7 01 00 08 C7 01 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C7 01 00 08 00 00 00 00 C7 01 00 08 C7 01 00 08 C7 01 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 21 19 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 C7 01 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C7 01 00 08 00 00 00 00 00 00 00 00 C7 01 00 08 C7 01 00 08 DF F8 0C D0 00 F0 9A F8 00 48 00 47 D9 33 00 08 D0 1A 00 20 06 48 80 47 06 48 00 47 FE E7 FE E7 FE E7 FE E7 FE E7 FE E7 FE E7 FE E7 FE E7 FE E7 55 1A 00 08 99 01 00 08 2D E9 F0 5F 05 46 00 20 92 46 9B 46 88 46 06 46 81 46 40 24 1B E0 28 46 41 46 47 46 22 46 00 F0 60 F8 53 46 5A 46 C0 1A 91 41 10 D3 11 46 18 46 22 46 00 F0 47 F8 2D 1A 67 EB 01 08 4F 46 22 46 01 20 00 21 00 F0 3E F8 17 EB 00 09 4E 41 20 1E A4 F1 01 04 DF DC 48 46 31 46 2A 46 43 46 BD E8 F0 9F 40 EA 01 03 9B 07 03 D0 09 E0 08 C9 12 1F 08 C0 04 2A FA D2 03 E0 11 F8 01 3B 00 F8 01 3B 52 1E F9 D2 70 47 D2 B2 01 E0 00 F8 01 2B 49 1E FB D2 70 47 00 22 F6 E7 10 B5 13 46 0A 46 04 46 19 46 FF F7 F0 FF 20 46 10 BD 30 B5 04 46 00 20 03 46 00 E0 5B 1C 93 42 03 D2 E0 5C CD 5C 40 1B F8 D0 30 BD 20 2A 04 DB 20 3A 00 FA 02 F1 00 20 70 47 91 40 C2 F1 20 03 20 FA 03 F3 19 43 90 40 70 47 20 2A 04 DB 20 3A 21 FA 02 F0 00 21 70 47 21 FA 02 F3 D0 40 C2 F1 20 02 91 40 08 43 19 46 70 47 00 00 06 4C 07 4D 06 E0 E0 68 40 F0 01 03 94 E8 07 00 98 47 10 34 AC 42 F6 D3 FF F7 58 FF 48 39 00 08 68 39 00 08 70 B5 8C 18 10 F8 01 5B 15 F0 07 03 01 D1 10 F8 01 3B 2A 11 06 D1 10 F8 01 2B 03 E0 10 F8 01 6B 01 F8 01 6B 5B 1E F9 D1 2B 07 05 D4 00 23 52 1E 0D D4 01 F8 01 3B FA E7 10 F8 01 3B CB 1A 92 1C 03 E0 13 F8 01 5B 01 F8 01 5B 52 1E F9 D5 A1 42 D8 D3 00 20 70 BD FE E7 00 20 70 47 00 20 70 47 07 48 08 4A D0 F8 90 02 00 21 40 29 03 D0 43 5C 53 54 01 31 F9 E7 04 48 01 21 01 70 00 20 70 47 00 04 00 20 7C 01 00 20 78 01 00 20 70 47 70 47 DE 4A 03 29 13 68 23 F4 40 73 13 60 4F F4 40 73 38 BF 0B 02 11 68 19 43 11 60 11 68 21 F0 F8 01 11 60 11 68 41 EA C0 00 40 F0 02 00 10 60 10 68 40 F4 80 30 10 60 70 47 13 48 01 68 89 05 0F D5 01 68 21 F4 00 71 01 60 01 68 41 F4 00 61 01 60 01 68 21 F4 00 61 01 60 01 68 41 F4 00 71 01 60 01 68 49 05 0F D5 01 68 21 F4 80 61 01 60 01 68 41 F4 80 51 01 60 01 68 21 F4 80 51 01 60 01 68 41 F4 80 61 01 60 70 47 00 3C 02 40 BB 49 0A 68 22 F4 40 72 0A 60 0A 68 42 F0 04 02 0A 60 0A 68 42 EA 00 20 40 F4 80 30 08 60 70 47 B3 4A 13 68 23 F4 40 73 13 60 13 68 13 60 13 68 43 F0 01 03 13 60 01 70 70 47 00 BF 10 B5 AC 49 0C 68 24 F4 40 74 0C 60 0C 68 44 F4 40 74 0C 60 0C 68 44 F0 01 04 0C 60 02 60 BF F3 6F 8F 43 60 10 BD 00 BF A2 4A 13 68 23 F4 40 73 13 60 13 68 43 F4 80 73 13 60 13 68 43 F0 01 03 13 60 01 80 70 47 00 BF 9A 4A 13 68 23 F4 40 73 13 60 13 68 43 F4 00 73 13 60 13 68 43 F0 01 03 13 60 01 60 70 47 00 BF 32 48 01 68 C9 06 06 D5 8F 49 CA 69 42 F0 10 02 CA 61 10 21 01 60 01 68 89 06 06 D5 8A 49 CA 69 42 F0 08 02 CA 61 20 21 01 60 01 68 49 06 06 D5 85 49 CA 69 42 F0 04 02 CA 61 40 21 01 60 01 68 09 06 06 D5 80 49 CA 69 42 F0 02 02 CA 61 80 21 01 60 01 68 C9 05 07 D5 7B 49 CA 69 42 F0 01 02 CA 61 4F F4 80 71 01 60 01 68 89 07 06 D5 76 49 CA 69 42 F0 20 02 CA 61 02 21 01 60 70 47 00 BF F8 B5 04 46 70 48 00 21 10 4E C1 61 00 F0 46 FA 05 46 67 1C 30 68 C0 03 09 D5 00 2F FA D0 24 B1 00 F0 3C FA 40 1B A0 42 F4 D9 03 20 F8 BD 30 68 C0 07 1C BF 01 20 30 60 30 68 10 F4 F9 7F 03 D0 FF F7 9E FF 01 20 F8 BD 00 20 F8 BD 0C 3C 02 40 80 B5 09 48 4F F0 FF 31 00 22 01 61 02 61 41 61 42 61 01 60 02 60 41 60 42 60 81 60 82 60 00 F0 5D FA 00 20 80 BD 00 BF 10 38 02 40 B0 B5 04 46 00 F0 0C FA 05 46 05 48 61 1C 00 78 18 BF 04 44 00 F0 04 FA 40 1B A0 42 FA D3 B0 BD 18 00 00 20 2D E9 F8 43 DF F8 20 81 05 46 98 F8 18 00 01 28 01 D1 02 26 3E E0 01 20 88 F8 18 00 4C F2 50 30 89 46 FF F7 9D FF 06 46 88 BB 4F F0 FF 30 C9 F8 00 00 28 68 3D 4C 01 28 0C D1 28 7C FF F7 FE FE 4C F2 50 30 FF F7 8C FF 06 46 20 68 20 F0 04 00 20 60 1A E0 A8 68 07 46 E9 68 08 44 87 42 10 D2 29 7C 38 46 FF F7 A4 FE 4C F2 50 30 FF F7 78 FF 06 46 20 68 20 F0 FA 00 20 60 26 B9 A8 68 01 37 EA E7 00 26 01 E0 C9 F8 00 70 FF F7 AD FE 00 20 88 F8 18 00 30 46 BD E8 F8 83 00 BF 23 48 01 68 41 F0 00 41 01 60 00 20 70 47 00 BF 2D E9 F0 41 DF F8 74 80 07 46 98 F8 18 00 01 28 04 BF 02 20 BD E8 F0 81 01 20 88 F8 18 00 4C F2 50 30 1E 46 14 46 0D 46 FF F7 44 FF 08 BB 02 2F 07 D0 01 2F 0A D0 77 B9 E1 B2 28 46 FF F7 B8 FE 0E E0 28 46 21 46 FF F7 E5 FE 09 E0 A1 B2 28 46 FF F7 D0 FE 04 E0 28 46 22 46 33 46 FF F7 B6 FE 4C F2 50 30 FF F7 26 FF 05 49 0A 68 22 F0 01 02 0A 60 00 21 88 F8 18 10 BD E8 F0 81 A4 0A 00 20 10 3C 02 40 06 48 C1 68 B1 F1 FF 3F C4 BF 00 20 70 47 04 49 01 60 04 49 01 60 C0 68 C0 0F 70 47 04 3C 02 40 23 01 67 45 AB 89 EF CD 2D E9 F8 4F 94 4A 07 24 90 42 94 4A 08 BF 04 24 02 44 4F EA B2 23 04 2B 38 BF 4F EA B2 24 90 4A 00 94 4F F0 00 0A 01 23 0F 24 A2 F5 7E 7B 4F F0 00 09 00 27 10 2F 08 BF BD E8 F8 8F 03 FA 07 F2 0A 42 40 D0 0A F0 0C 0C 04 FA 0C F8 BC 08 5B F8 24 E0 00 9B 0E EA 08 05 03 FA 0C F6 D2 43 B5 42 13 D1 7F 4B 1D 68 15 40 1D 60 5D 68 15 40 5D 60 9D 68 15 40 9D 60 7B 4B 1D 68 15 40 1D 60 5B F8 24 50 25 EA 08 05 4B F8 24 50 03 23 05 68 03 FA 09 F4 A5 43 05 60 0A F0 1C 05 0F 23 03 FA 05 F5 6F F0 03 03 03 EA 57 06 06 44 33 6A AB 43 33 62 C3 68 A3 43 C3 60 43 68 1A 40 42 60 82 68 01 23 A2 43 0F 24 82 60 0A F1 04 0A 09 F1 02 09 01 37 B0 E7 00 BF 2D E9 FC 4F 5F 4A 07 24 90 42 5F 4A 08 BF 04 24 02 44 4F EA B2 23 04 2B 38 BF 4F EA B2 24 4F F0 01 0B 4F F0 00 08 4F F0 00 0E 00 22 00 94 BE F1 20 0F 08 BF BD E8 FC 8F 0F 68 0B FA 02 F6 37 42 00 F0 93 80 4F 68 12 2F 00 F2 95 80 0B FA 07 F4 14 F0 06 1F 00 F0 8F 80 03 23 03 FA 0E F4 83 68 CD 68 A3 43 05 FA 0E F5 2B 43 83 60 C7 F3 00 13 45 68 93 40 B5 43 2B 43 6F EA 04 0C 4F EA 42 0A 43 60 C4 68 8D 68 04 EA 0C 04 05 FA 0A F5 2C 43 C4 60 47 F0 10 04 12 2C 12 D1 08 F0 1C 04 0F 23 03 FA 04 F5 6F F0 03 03 03 EA 52 07 07 44 D7 F8 20 90 0B 69 29 EA 05 05 A3 40 2B 43 3B 62 4F 68 03 68 07 F0 03 04 03 EA 0C 03 04 FA 0A F4 23 43 03 60 FB 00 49 D5 00 23 01 93 2E 4B 2B 4F 1C 46 1B 68 22 F0 03 05 43 F4 80 43 23 60 23 68 BC 46 03 F4 80 43 01 93 3D 44 01 9F 27 4F 08 F0 0C 03 0F 24 B9 46 EF 59 9C 40 27 EA 04 04 00 9F 07 FA 03 F3 23 43 45 F8 09 30 DC F8 00 30 4D 68 43 EA 06 04 EF 03 58 BF 23 EA 06 04 CC F8 00 40 DC F8 04 30 AF 03 43 EA 06 04 58 BF 23 EA 06 04 CC F8 04 40 DC F8 08 30 EF 02 43 EA 06 04 58 BF 23 EA 06 04 0F 4B CC F8 08 40 1F 46 1B 68 AD 02 43 EA 06 04 58 BF 23 EA 06 04 3C 60 08 F1 04 08 0E F1 02 0E 01 32 5B E7 03 23 03 FA 0E F4 6F EA 04 0C F2 46 7E E7 00 10 02 40 00 00 FE BF 00 3C 01 40 0C 3C 01 40 44 38 02 40 08 FC FF FF 00 69 08 40 18 BF 01 20 70 47 42 69 0A 40 8A 42 08 BF 09 04 81 61 70 47 00 2A 08 BF 09 04 81 61 70 47 00 00 02 48 00 68 6F F3 1F 30 70 47 00 BF 00 20 04 E0 05 48 00 68 70 47 00 BF 1F 48 03 49 00 78 0A 68 10 44 08 60 70 47 00 BF C8 0E 00 20 80 B5 0B 48 01 68 41 F4 00 71 01 60 01 68 41 F4 80 61 01 60 01 68 41 F4 80 71 01 60 03 20 00 F0 83 F8 00 20 00 F0 06 F8 00 F0 26 F8 00 20 80 BD 00 3C 02 40 70 B5 0D 4E 04 46 30 78 4F F4 7A 71 B1 FB F0 F0 0A 49 09 68 B1 FB F0 F0 00 F0 68 FE 01 25 0F 2C 08 D8 38 B9 4F F0 FF 30 21 46 00 22 00 25 00 F0 45 F8 74 60 28 46 70 BD 18 00 00 20 50 00 00 20 70 47 00 00 82 B0 00 20 0B 49 01 90 4A 68 42 F4 80 42 4A 60 4A 68 02 F4 80 42 01 92 01 9A 00 90 08 68 40 F0 80 50 08 60 08 68 00 F0 80 50 00 90 00 98 02 B0 70 47 00 BF 40 38 02 40 00 28 0C D4 00 F0 1F 01 01 22 02 FA 01 F1 04 4A 40 09 42 F8 20 10 BF F3 4F 8F BF F3 6F 8F 70 47 80 E1 00 E0 00 28 08 D4 00 F0 1F 01 01 22 02 FA 01 F1 02 4A 40 09 42 F8 20 10 70 47 00 E1 00 E0 B0 B5 13 4B 4F F0 FF 35 1B 68 C3 F3 02 23 DC 1E 83 F0 07 03 38 BF 00 24 04 2B 28 BF 04 23 05 FA 03 F3 99 43 05 FA 04 F3 A1 40 9A 43 11 43 BD E8 B0 40 02 F0 6F BA 00 BF 05 49 4F F6 FF 03 0A 68 1A 40 60 F3 0A 22 03 48 10 43 08 60 70 47 00 BF 0C ED 00 E0 00 00 FA 05 02 F0 6E FA 70 47 00 68 41 62 00 20 70 47 B0 B5 00 68 43 6A B1 B1 84 6A 01 39 03 EB 14 43 00 24 E5 B2 A9 42 07 D9 00 EB 85 05 D5 F8 04 51 01 34 03 EB 15 43 F4 E7 00 EB 81 00 43 EA 02 41 C0 F8 04 11 02 E0 43 EA 02 41 81 62 00 20 B0 BD D0 F8 04 04 01 F0 75 BA C1 EB C1 02 00 EB 82 02 92 6C D0 F8 04 04 01 F0 C5 B9 C1 EB C1 02 00 EB 82 02 D2 F8 08 22 D0 F8 04 04 01 F0 1A BA 70 B1 10 B5 04 46 03 20 84 F8 BD 03 20 46 00 F0 6D FD 20 46 00 F0 BE FC 00 20 84 F8 BD 03 10 BD 01 20 70 47 D0 F8 04 04 01 F0 4E BA 10 B5 04 46 01 F0 0F 00 09 06 09 D4 C0 EB C0 01 04 EB 81 01 00 22 81 F8 FD 21 01 F5 FE 71 07 E0 C0 EB C0 01 04 EB 81 01 01 22 81 F8 3D 20 3C 31 08 70 94 F8 BC 03 01 28 04 BF 02 20 10 BD 01 20 84 F8 BC 03 20 68 01 F0 F3 FD 00 20 84 F8 BC 03 10 BD B0 B5 04 46 62 68 01 F0 0F 00 90 42 01 D9 01 25 24 E0 09 06 09 D4 C0 EB C0 01 04 EB 81 01 00 22 81 F8 FD 21 01 F5 FE 71 07 E0 C0 EB C0 01 04 EB 81 01 01 22 81 F8 3D 20 3C 31 00 25 08 70 8D 70 94 F8 BC 03 01 28 01 D1 02 25 07 E0 01 20 84 F8 BC 03 20 68 01 F0 91 FF 84 F8 BC 53 28 46 B0 BD B0 B5 04 46 01 F0 0F 00 09 06 09 D4 C0 EB C0 01 04 EB 81 01 00 25 81 F8 FD 51 01 F5 FE 71 07 E0 C0 EB C0 01 04 EB 81 01 01 25 81 F8 3D 50 3C 31 8A 60 CB 70 08 70 4A 78 02 B1 C8 80 02 2B 04 BF 00 20 08 71 94 F8 BC 03 01 28 04 BF 02 20 B0 BD 01 20 84 F8 BC 03 20 68 01 F0 E5 FC 00 20 84 F8 BC 03 B0 BD B0 B5 01 F0 0F 04 C4 EB C4 01 00 EB 81 05 00 21 C5 E9 84 31 C5 F8 08 22 85 F8 FD 11 85 F8 FC 41 03 69 05 F5 FE 71 01 2B 08 BF C5 F8 0C 22 00 68 DA B2 14 B1 01 F0 73 FF 01 E0 01 F0 9E FE 00 20 B0 BD B0 B5 04 46 40 68 01 F0 0F 05 85 42 84 BF 01 20 B0 BD 08 06 09 D4 C1 EB C1 00 04 EB 80 00 00 21 80 F8 FD 11 00 F5 FE 71 08 E0 C5 EB C5 00 04 EB 80 00 01 21 80 F8 3D 10 00 F1 3C 01 01 20 0D 70 88 70 94 F8 BC 23 01 2A 04 BF 02 20 B0 BD 84 F8 BC 03 20 68 01 F0 26 FF 2D B9 21 7C 20 68 04 F5 71 72 01 F0 DB FE 00 20 84 F8 BC 03 B0 BD 70 B5 01 F0 0F 04 C4 EB C4 01 00 EB 81 05 29 46 01 F8 3C 4F 00 26 C1 E9 05 36 01 23 CA 60 4B 70 03 69 01 2B 08 BF EA 64 00 68 DA B2 14 B1 01 F0 1E FF 01 E0 01 F0 49 FE 00 20 70 BD 00 00 2D E9 F0 4F 87 B0 81 46 00 68 05 90 01 F0 F0 FF 10 B1 07 B0 BD E8 F0 8F D9 F8 00 00 02 F0 14 F8 00 28 F6 D0 D9 F8 00 00 02 F0 0E F8 01 46 D9 F8 00 00 89 07 03 D5 41 69 01 F0 02 01 41 61 02 F0 03 F8 00 03 40 F1 D5 80 D9 F8 00 00 01 F0 DB FF 06 46 09 F5 05 7A 09 F5 71 70 4F F0 00 0B 4F F4 30 68 06 90 00 2E 00 F0 C4 80 F0 07 00 F0 B9 80 D9 F8 00 00 5F FA 8B F5 29 46 01 F0 DD FF 07 46 C0 07 5E D0 05 98 01 21 40 44 81 60 D9 F8 00 00 08 EB 00 04 01 6C A0 68 D9 F8 10 20 01 2A 28 D1 02 07 35 D4 82 06 4A D4 10 F0 28 0F 49 D1 E4 4A 91 42 02 D3 10 F4 00 40 3E D1 5A E9 04 01 01 44 4A F8 0C 1C 21 69 6F F3 DF 41 40 1A CA F8 00 00 48 46 29 46 FF F7 72 FE B8 F5 30 6F 31 D1 D9 F8 10 02 70 BB D9 F8 00 00 06 9A 01 21 01 F0 40 FE 27 E0 D3 4A FF 32 91 42 05 D1 01 04 1C D4 80 06 44 BF 20 20 A0 60 48 46 29 46 FF F7 57 FE 18 E0 CB 4A 91 42 05 D3 10 F4 00 40 1C BF 4F F4 00 40 A0 60 48 46 00 F0 A4 FB D9 F8 00 00 06 9A 01 21 01 F0 1E FE 08 20 03 E0 4F F4 00 40 00 E0 20 20 A0 60 38 07 30 D5 D9 F8 00 10 08 EB 01 00 0C 6C 81 68 D9 F8 10 20 01 2A 03 D1 B9 4A 94 42 04 D2 0D E0 B7 4A FF 32 94 42 09 D1 11 F4 00 41 06 D0 4F F4 00 41 81 60 48 46 00 F0 7A FB 06 E0 48 46 00 F0 76 FB AE 48 01 38 84 42 09 D9 D9 F8 10 00 01 28 05 D1 D9 F8 00 00 06 9A 01 21 01 F0 E8 FD 05 98 08 21 40 44 81 60 F8 06 03 D5 05 98 10 21 40 44 81 60 B8 06 0D D5 D9 F8 10 00 01 28 05 D1 D9 F8 00 00 06 9A 01 21 01 F0 D2 FD 05 98 20 21 40 44 81 60 B8 04 04 D5 05 98 4F F4 00 51 40 44 81 60 0A F1 1C 0A 08 F1 20 08 76 08 0B F1 01 0B 38 E7 D9 F8 00 00 01 F0 27 FF 40 03 40 F1 B8 80 D9 F8 00 00 01 F0 F8 FE 04 46 09 F5 71 70 01 90 05 98 00 27 00 F5 10 66 02 96 00 2C 00 F0 A8 80 E0 07 00 F0 A2 80 D9 F8 00 00 F9 B2 06 91 01 F0 F1 FE 05 46 C0 07 2D D0 05 99 07 F0 0F 00 01 23 0A 46 D1 F8 34 18 03 FA 00 F0 21 EA 00 00 C2 F8 34 08 06 EB 47 10 83 60 D9 F8 10 00 01 28 07 D1 C7 EB C7 00 09 EB 80 00 D0 E9 11 12 11 44 81 64 06 99 48 46 FF F7 99 FD 67 B9 D9 F8 10 00 01 28 08 D1 D9 F8 50 00 28 B9 D9 F8 00 00 01 9A 01 21 01 F0 6E FD 28 07 42 BF 06 EB 47 10 08 21 81 60 E8 06 42 BF 06 EB 47 10 10 21 81 60 68 06 42 BF 06 EB 47 10 40 21 81 60 A8 07 42 BF 06 EB 47 10 02 21 81 60 28 06 50 D5 C7 EB C7 00 09 EB 80 0A D3 46 5B F8 50 0F D8 46 58 F8 04 2F 90 42 44 D3 D9 F8 00 50 5A F8 44 1F 04 94 3B 46 84 1A 8C 42 88 BF 0C 46 05 EB 43 11 4F 46 01 F5 10 69 0A F1 04 06 03 93 17 E0 3C 7C DA F8 00 30 31 68 00 94 84 1A 9C 42 88 BF 1C 46 06 9A A3 B2 28 46 01 F0 65 FF 30 68 20 44 30 60 D8 F8 00 00 02 19 C8 F8 00 20 DB F8 00 00 D9 F8 18 30 E1 1C 9B B2 B3 EB 91 0F 28 BF 90 42 DE D8 B9 46 04 9C DD E9 02 67 90 42 0A D8 07 F0 0F 00 01 21 01 FA 00 F0 D5 F8 34 18 21 EA 00 00 C5 F8 34 08 64 08 01 37 54 E7 D9 F8 00 00 01 F0 68 FE 00 28 02 D4 D9 F8 00 00 1C E0 05 98 01 46 D0 F8 04 08 20 F0 01 00 C1 F8 04 08 99 F8 F4 03 01 28 07 D1 00 20 89 F8 F4 03 48 46 00 21 FF F7 D8 FC 02 E0 48 46 00 F0 44 FA D9 F8 00 00 41 69 01 F0 00 41 41 61 01 F0 44 FE 00 05 02 D4 D9 F8 00 00 0D E0 05 98 D0 F8 08 08 C0 07 02 D0 48 46 00 F0 8D FA D9 F8 00 00 41 69 01 F4 00 61 41 61 01 F0 2F FE C0 04 02 D4 D9 F8 00 00 54 E0 05 9C 10 21 D4 F8 04 08 20 F0 01 00 C4 F8 04 08 D9 F8 00 00 01 F0 D4 FD D9 F8 04 20 04 F5 10 61 04 F5 00 60 4F F6 7F 33 92 B1 8B 60 0C 68 01 3A 24 F4 00 14 0C 60 C1 F8 08 32 D1 F8 00 42 24 F4 00 14 C1 F8 00 42 20 31 EE E7 00 BF 0B 30 54 4F C1 69 41 F0 01 11 C1 61 D9 F8 30 10 41 B1 D0 F8 84 10 41 F0 0B 01 C0 F8 84 10 00 F1 44 01 06 E0 41 69 42 F2 2B 02 11 43 41 61 00 F1 10 01 0A 68 42 F0 0B 02 0A 60 01 68 09 F5 71 72 21 F4 FE 61 01 60 D9 F8 00 00 99 F8 10 10 01 F0 6F FC D9 F8 00 00 41 69 01 F4 80 51 41 61 01 F0 D3 FD 01 46 D9 F8 00 00 89 04 1A D5 01 F0 50 FA D9 F8 00 00 01 F0 8E FD C9 F8 0C 00 D9 F8 00 50 00 F0 30 FA 99 F8 0C 20 01 46 28 46 01 F0 F4 FD 48 46 00 F0 9F F9 D9 F8 00 00 41 69 01 F4 00 51 41 61 01 F0 B1 FD 01 46 D9 F8 00 00 C9 06 3F D5 81 69 21 F0 10 01 81 61 05 98 04 6A C4 F3 43 40 04 F0 0F 05 06 28 1C D0 02 28 2B D1 47 F6 F0 70 04 40 27 D0 C5 EB C5 00 09 EB 80 05 D5 F8 08 12 05 98 22 09 01 F0 94 FD D5 F8 08 02 D5 F8 14 12 00 EB 14 10 C5 F8 08 02 01 EB 14 10 C5 F8 14 02 10 E0 05 98 09 F5 71 71 08 22 01 F0 81 FD C5 EB C5 00 09 EB 80 00 D0 F8 14 12 C4 F3 0A 12 11 44 C0 F8 14 12 D9 F8 00 00 81 69 41 F0 10 01 81 61 01 F0 6A FD 00 07 02 D4 D9 F8 00 00 08 E0 48 46 00 F0 5E F9 D9 F8 00 00 41 69 01 F0 08 01 41 61 01 F0 5A FD C0 02 02 D4 D9 F8 00 00 09 E0 48 46 00 21 00 F0 3A F8 D9 F8 00 00 41 69 01 F4 80 11 41 61 01 F0 49 FD 80 02 02 D4 D9 F8 00 00 09 E0 48 46 00 21 00 F0 2D F8 D9 F8 00 00 41 69 01 F4 00 11 41 61 01 F0 38 FD 40 00 02 D4 D9 F8 00 00 08 E0 48 46 FF F7 DD FB D9 F8 00 00 41 69 01 F0 80 41 41 61 01 F0 28 FD 40 07 7F F5 0A AD D9 F8 00 00 44 68 61 07 04 D5 48 46 FF F7 F3 FB D9 F8 00 00 41 68 21 43 41 60 FB E4 D0 F8 04 04 00 F0 87 BE D0 F8 04 04 00 F0 85 BE 2D E9 F0 4F 8B B0 00 28 00 F0 87 80 04 46 05 68 90 F8 BD 03 28 B9 00 20 84 F8 BC 03 20 46 00 F0 A4 F8 03 20 84 F8 BD 03 E8 6B C0 05 5C BF 00 20 20 61 20 68 01 F0 0F FB 20 68 04 F1 14 0E 0A 90 D4 E9 0C 50 04 F1 04 0B 9E E8 C0 50 04 F1 24 0A 9B E8 0E 08 9A E8 00 07 CD E9 08 50 02 A8 CD E9 00 B6 80 E8 80 50 05 A8 80 E8 00 07 0A 98 01 F0 76 F9 00 28 4E D1 20 68 00 21 00 25 01 F0 E0 FC 61 68 01 20 00 22 D3 B2 99 42 10 D9 C3 EB C3 06 04 EB 86 06 A6 F8 42 30 86 F8 3C 20 86 F8 3D 00 35 65 C6 E9 11 55 86 F8 3F 50 01 32 EB E7 00 20 00 22 D3 B2 99 42 0F D9 C3 EB C3 03 04 EB 83 03 C3 F8 10 02 C3 E9 81 00 83 F8 FF 01 83 F8 FC 21 83 F8 FD 01 01 32 EC E7 A0 68 04 F1 14 0E 0A 90 D4 E9 0C 50 D4 E9 03 3B 9E E8 C0 50 04 F1 24 0A 22 68 9A E8 00 07 CD E9 08 50 02 A8 CD E9 00 B6 80 E8 80 50 05 A8 80 E8 00 07 10 46 0A 9A 01 F0 CC F9 38 B1 02 20 84 F8 BD 03 01 25 28 46 0B B0 BD E8 F0 8F 00 25 01 20 84 F8 38 50 84 F8 BD 03 20 68 01 F0 AE F9 F1 E7 00 00 80 B5 00 68 B0 F1 A0 4F 18 BF 80 BD 07 48 01 68 21 F0 80 01 01 60 25 48 4F F4 C0 51 FF F7 E4 F8 43 20 BD E8 80 40 FF F7 97 BA 00 BF 34 38 02 40 B0 B5 86 B0 04 46 01 A8 14 21 FE F7 6F FE 20 68 B0 F1 A0 4F 2F D1 00 25 BC 4C 00 95 20 68 01 A9 40 F0 01 00 20 60 20 68 00 F0 01 00 00 90 0A 20 05 90 03 20 CD E9 03 50 02 20 02 90 4F F4 C0 50 01 90 00 98 0D 48 FF F7 21 F9 60 68 01 21 40 F0 80 00 60 60 00 95 60 69 00 22 40 F4 80 40 60 61 60 69 00 F4 80 40 00 90 00 98 43 20 FF F7 7C FA 43 20 FF F7 6B FA 06 B0 B0 BD 00 BF 00 00 02 40 10 B5 04 46 C0 68 02 28 18 BF FE F7 C0 FE D4 F8 04 04 01 21 00 F0 D5 FD D4 F8 04 04 BD E8 10 40 00 F0 95 BD D0 F8 04 04 00 F0 B9 BD D0 F8 04 04 00 F0 BB BD 10 B5 04 46 90 F8 BC 03 01 28 04 BF 02 20 10 BD 01 20 84 F8 38 10 84 F8 BC 03 20 68 01 F0 18 FC 00 20 84 F8 BC 03 10 BD D0 F8 04 24 00 F5 71 71 10 46 00 F0 B8 BD 10 B5 04 46 90 F8 BC 03 01 28 04 BF 02 20 10 BD 01 21 20 68 84 F8 BC 13 A1 6A 01 29 06 D1 A1 69 01 29 03 D0 81 6B 41 F4 80 31 81 63 01 F0 FB F8 20 68 01 F0 6C FB 00 20 84 F8 BC 03 10 BD B0 B5 04 46 90 F8 BC 03 01 28 01 D1 02 25 10 E0 01 25 84 F8 BC 53 20 68 01 F0 D4 F9 20 68 01 F0 65 FC 18 B9 20 68 01 F0 EB F8 00 25 00 20 84 F8 BC 03 28 46 B0 BD 00 00 10 B5 04 46 D0 F8 04 04 00 F0 BD FD 20 68 D0 F8 00 1E 41 F0 01 01 C0 F8 00 1E 20 6A 20 B1 03 48 01 68 41 F0 06 01 01 60 10 BD 00 BF 10 ED 00 E0 3D 48 00 68 70 47 00 BF 41 1E 00 20 B0 EB 11 6F 1C BF 01 20 70 47 21 4A F0 23 51 60 02 49 0B 70 07 21 90 60 11 60 70 47 23 ED 00 E0 FE E7 F0 B5 52 00 00 23 37 24 00 25 AA 42 08 BF F0 BD 04 EB 10 76 07 0F B0 F1 20 4F 38 BF 07 F1 30 06 4E 55 45 F0 01 06 8B 55 02 35 00 01 ED E7 18 B5 4F F4 7A 71 00 91 C1 68 49 06 15 D4 4F F0 FF 31 C1 60 C3 68 0A 4A 00 21 5B 06 00 9B 0D D4 63 B1 13 68 DB 03 02 D5 00 9B 01 3B 00 93 C3 68 00 9C 00 2C 08 BF 01 21 EF E7 00 21 C8 B2 18 BD 10 E0 00 E0 B0 B5 04 46 CA 20 60 62 53 20 60 62 20 46 0D 46 FF F7 D4 FF 01 28 01 D1 01 20 15 E0 07 CD A3 68 23 F0 40 03 18 43 A0 60 20 69 47 F6 FF 73 98 43 10 43 20 61 20 69 20 F4 FE 00 40 EA 01 40 20 61 6F F0 80 00 E0 60 00 20 FF 21 61 62 B0 BD 00 00 01 49 08 60 70 47 00 BF 50 00 00 20 F0 B5 87 B0 00 26 1E 48 06 96 01 96 01 68 1D 4C 41 F0 04 01 01 60 01 68 01 22 01 F0 04 01 01 91 01 99 01 96 01 68 4F F4 00 55 41 F0 80 01 01 60 01 68 01 27 01 F0 80 01 01 91 01 99 01 96 01 68 41 F0 01 01 01 60 00 68 4F F4 00 51 00 F0 01 00 01 90 01 98 20 46 FF F7 AD F8 CD E9 04 66 CD E9 02 57 02 AD 20 46 29 46 FE F7 CA FF A4 F5 00 60 29 46 04 97 CD E9 02 76 FE F7 C2 FF 07 B0 F0 BD 30 38 02 40 00 08 02 40 BF B5 0D 48 0D 4D 01 68 FF 24 41 F4 00 41 01 60 7F 20 02 90 00 20 01 90 A5 F1 10 00 01 A9 03 94 FF F7 7C FF 28 68 40 F4 FE 00 28 60 28 68 64 F3 0E 00 28 60 BF BD 00 BF 70 38 02 40 10 28 00 40 80 B5 0F 48 0F 49 00 22 00 F0 02 FB 08 B1 FE F7 54 FD 0B 48 0C 49 00 F0 D9 FC 08 B1 FE F7 4D FD 07 48 0A 49 00 F0 59 F9 08 B1 FE F7 46 FD 04 48 00 F0 E0 FC 18 B1 BD E8 80 40 FE F7 3E BD 80 BD 00 04 00 20 34 00 00 20 54 00 00 20 28 01 00 20 FE E7 70 47 01 48 FF F7 5F BA 00 BF 9C 06 00 20 70 47 00 00 07 49 08 4A 01 20 65 28 08 BF 70 47 51 F8 20 30 13 44 03 F1 78 43 41 F8 20 30 01 30 F3 E7 00 BF 04 C0 00 20 00 C0 00 20 70 47 FF F7 3F B8 00 00 10 B5 4C 4C 02 21 D4 F8 00 04 61 F3 03 00 C4 F8 00 04 D4 F8 00 04 32 48 01 68 41 F4 40 41 01 60 21 68 41 F4 80 31 21 60 21 68 89 03 FC D5 01 68 41 F4 80 71 01 60 20 6F 40 F4 80 30 20 67 20 6F 20 F4 80 30 20 67 20 6F 40 F0 01 00 20 67 20 6F 80 07 FC D5 20 6F 01 21 61 F3 09 20 20 67 20 6F 40 F4 00 40 20 67 1F 48 63 68 00 F1 70 62 1A 40 1D 4B 1A 43 62 60 62 68 61 F3 11 42 62 60 61 68 08 40 1A 49 08 43 60 60 20 68 40 F0 80 70 20 60 20 68 80 01 FC D5 A0 68 04 21 20 F0 F0 00 A0 60 A0 68 61 F3 8C 20 A0 60 A0 68 02 21 20 F4 60 40 A0 60 A0 68 61 F3 01 00 A0 60 A0 68 00 F0 0C 00 08 28 FA D1 0A 48 FF F7 E7 FE 00 20 FE F7 FA FF D4 F8 8C 00 20 F0 80 70 C4 F8 8C 00 10 BD 00 BF 00 70 00 40 00 80 BF F0 19 54 40 00 19 54 40 07 00 BD 01 05 10 B5 0E 48 0F 4C D0 F8 80 10 41 F4 70 01 C0 F8 80 10 0B 49 0A 68 42 F0 01 02 0A 60 00 22 8A 60 0B 68 23 40 0B 60 08 4B 4B 60 0B 68 23 F4 80 23 0B 60 CA 60 4F F0 00 61 01 60 10 BD 08 ED 00 E0 00 38 02 40 FF FF F6 FE 10 30 00 24 D0 F8 90 02 00 21 80 F8 50 10 00 20 70 47 B0 B5 D0 E9 A4 52 04 46 28 78 69 78 D2 68 90 47 20 46 01 21 2A 46 40 23 00 F0 35 FB 00 20 B0 BD B0 B5 81 21 04 46 00 F0 20 FA 00 25 20 46 01 21 E5 62 00 F0 1A FA C4 F8 58 51 D4 F8 90 02 48 B1 D4 F8 94 02 80 68 80 47 D4 F8 90 02 01 F0 C7 FE C4 F8 90 52 00 20 B0 BD 10 B5 D0 F8 90 42 E1 6C 01 29 08 D1 D0 F8 94 02 22 78 61 78 C3 68 10 46 98 47 00 20 E0 64 00 20 10 BD 0A 21 01 80 00 48 70 47 F0 00 00 20 29 21 01 80 00 48 70 47 8C 00 00 20 29 21 01 80 00 48 70 47 B8 00 00 20 29 21 01 80 00 48 70 47 FC 00 00 20 70 B5 81 21 03 22 40 23 05 46 00 F0 DB FA 01 24 28 46 01 21 03 22 40 23 EC 62 00 F0 D3 FA 54 20 C5 F8 58 41 01 F0 AE FE C5 F8 90 02 68 B1 00 24 80 F8 50 40 06 46 D5 F8 94 02 40 68 80 47 28 46 01 21 32 46 40 23 00 F0 C9 FA 20 46 70 BD 00 29 0E BF 02 20 C0 F8 94 12 00 20 70 47 B0 B5 13 46 0A 46 90 F8 74 12 03 29 0A D1 D0 F8 90 42 01 21 94 F8 50 50 2D B9 84 F8 50 10 81 21 00 F0 4C FB 00 21 08 46 B0 BD 00 00 1C B5 00 22 D0 F8 90 32 AD F8 06 20 0A 78 12 F0 60 02 0F D0 20 2A 38 D1 4A 78 02 3A 09 2A 34 D8 DF E8 02 F0 05 3E 33 33 33 33 33 37 45 48 03 F1 44 01 37 E0 4A 78 0B 2A 0C D0 06 2A 11 D0 0A 2A 1C D0 12 BB 90 F8 74 22 03 2A 1E D1 0D F1 06 01 02 22 28 E0 90 F8 74 22 03 2A 16 D1 88 78 98 64 23 E0 CA 78 21 2A 28 D0 22 2A 2C D1 CA 88 14 2A 28 BF 14 22 D0 F8 94 12 09 68 14 E0 90 F8 74 22 03 2A 02 D1 03 F1 48 01 0C E0 00 F0 38 F8 02 20 1C BD 01 22 DA 64 CA 88 19 46 00 F0 3B F8 04 E0 03 F1 40 01 01 22 00 F0 4D F8 00 20 1C BD C8 78 58 64 FA E7 88 78 18 64 F7 E7 CA 88 03 49 09 2A 28 BF 09 22 EF E7 00 22 00 21 EC E7 E4 00 00 20 80 B5 D0 F8 8C 22 52 68 90 47 00 20 80 BD 80 B5 13 46 0A 46 00 21 00 F0 35 FA 00 20 80 BD 80 B5 13 46 0A 46 00 21 00 F0 CB FA 00 20 80 BD 10 B5 80 21 04 46 00 F0 A0 FA 20 46 00 21 BD E8 10 40 00 F0 9A BA 80 B5 13 46 0A 46 03 21 C0 E9 52 33 C0 F8 6C 12 00 21 00 F0 15 FA 00 20 80 BD 80 B5 05 21 C0 F8 6C 12 00 21 00 22 00 23 00 F0 0A FA 00 20 80 BD 80 B5 13 46 0A 46 02 21 C0 E9 07 33 C0 F8 6C 12 00 21 00 F0 9B FA 00 20 80 BD 80 B5 04 21 C0 F8 6C 12 00 21 00 22 00 23 00 F0 90 FA 00 20 80 BD 10 B5 04 46 01 20 84 F8 74 02 D4 F8 8C 02 21 79 42 68 20 46 90 47 20 46 00 F0 6E FA 20 46 00 F0 78 F9 00 20 10 BD 00 00 10 B5 33 4C 0A 46 03 A0 21 46 00 F0 7D F8 20 46 10 BD 00 BF 53 54 4D 33 32 20 48 49 44 20 42 6F 6F 74 6C 6F 61 64 65 72 20 43 6F 6E 66 69 67 00 12 20 08 80 00 48 70 47 38 01 00 20 10 B5 24 4C 0A 46 03 A0 21 46 00 F0 5F F8 20 46 10 BD 00 BF 53 54 4D 33 32 20 48 49 44 20 42 6F 6F 74 6C 6F 61 64 65 72 20 49 6E 74 65 72 66 61 63 65 00 00 04 20 08 80 00 48 70 47 4C 01 00 20 10 B5 14 4C 0A 46 03 A0 21 46 00 F0 3F F8 20 46 10 BD 00 BF 57 65 41 63 74 20 53 74 75 64 69 6F 00 00 00 00 10 B5 0B 4C 0A 46 03 A0 21 46 00 F0 2D F8 20 46 10 BD 00 BF 57 65 41 63 74 20 53 74 75 64 69 6F 20 48 49 44 20 42 6F 6F 74 6C 6F 61 64 65 72 00 C0 01 00 20 B0 B5 1A 20 08 80 09 49 08 68 8A 68 80 18 0B D0 07 4D 4C 68 A9 1C 08 22 FF F7 65 FC 05 F1 12 01 20 46 04 22 FF F7 5F FC 01 48 B0 BD 10 7A FF 1F 50 01 00 20 B0 B5 D8 B1 00 23 04 46 25 78 15 B1 01 34 01 33 FA E7 DC B2 02 23 03 EB 44 04 14 80 0C 70 03 22 01 24 0A 55 02 78 4A B1 DC B2 0A 55 9D 1C 43 F0 01 02 01 30 D4 B2 00 22 2B 46 F2 E7 B0 BD 00 00 03 28 84 BF 02 20 70 47 02 49 C0 00 21 FA 00 F0 C0 B2 70 47 00 02 01 02 88 B1 80 B5 D0 F8 8C 32 13 B1 00 23 C0 F8 8C 32 09 B1 C0 F8 88 12 01 21 02 70 80 F8 74 12 00 F0 CB F8 00 20 80 BD 02 20 70 47 80 B5 D0 F8 98 02 FE F7 91 FE BD E8 80 40 FF F7 D6 BF 80 B5 D0 F8 98 02 FE F7 5F FE BD E8 80 40 FF F7 CD BF B0 B5 04 46 69 B1 D4 F8 8C 02 42 69 3A B1 94 F8 74 02 03 28 03 D1 20 46 90 47 00 20 B0 BD 02 20 B0 BD D4 F8 6C 02 80 B1 04 28 0E D0 02 28 3D D1 D4 E9 08 10 81 42 0D D9 08 1A 83 B2 20 62 20 46 11 46 1A 46 FF F7 AE FE 18 E0 20 46 80 21 00 F0 56 F9 2B E0 E1 69 81 42 17 D3 B1 FB F0 F2 02 FB 10 10 90 B9 D4 F8 70 02 81 42 0E D2 20 46 00 21 00 22 00 25 FF F7 96 FE C4 F8 70 52 20 46 00 21 00 22 00 23 00 F0 C1 F8 10 E0 D4 F8 8C 02 C1 68 29 B1 94 F8 74 02 03 28 01 D1 20 46 88 47 20 46 80 21 00 F0 2C F9 20 46 FF F7 9C FE 94 F8 78 12 00 20 01 29 04 BF 84 F8 78 02 B0 BD B0 BD B0 B5 04 46 61 B1 D4 F8 8C 02 82 69 32 B1 94 F8 74 02 03 28 02 D1 20 46 90 47 2D E0 02 25 2C E0 D4 F8 6C 02 00 25 05 28 12 D0 03 28 25 D1 D4 E9 53 10 81 42 13 D9 09 1A C4 F8 4C 11 81 42 38 BF 08 46 83 B2 20 46 11 46 1A 46 FF F7 44 FE 13 E0 20 46 00 21 C4 F8 6C 52 00 F0 F2 F8 0D E0 D4 F8 8C 02 01 69 29 B1 94 F8 74 02 03 28 01 D1 20 46 88 47 20 46 FF F7 6F FE 00 25 28 46 B0 BD 80 B5 D0 F8 98 02 FE F7 A2 FD BD E8 80 40 FF F7 26 BF 00 20 70 47 80 B5 01 21 80 F8 74 12 D0 F8 8C 22 01 79 52 68 90 47 00 20 80 BD 00 00 10 B5 01 78 41 BB 15 49 02 22 C0 F8 98 12 C1 F8 04 04 00 20 C1 E9 0B 00 C1 E9 06 20 C1 E9 08 00 C1 E9 03 20 04 20 4F F0 A0 42 C1 E9 00 20 08 46 FF F7 A3 F9 08 B1 FE F7 5C F9 08 4C 80 21 20 46 FE F7 33 FD 20 46 00 21 40 22 FE F7 32 FD 20 46 01 21 80 22 FE F7 2D FD 00 20 10 BD 9C 06 00 20 D0 F8 98 02 01 F0 7F 02 C2 EB C2 02 00 EB 82 00 00 F1 3E 02 09 06 58 BF 00 F5 FF 72 10 78 70 47 00 20 70 47 00 20 70 47 10 B5 14 46 D0 F8 98 02 1A 46 23 46 FE F7 B3 FD BD E8 10 40 FF F7 C8 BE 80 B5 D0 F8 98 02 FE F7 DC FD BD E8 80 40 FF F7 BF BE F8 B5 00 21 00 22 40 23 04 46 00 25 40 26 FF F7 E2 FF 01 27 20 46 80 21 00 22 40 23 C4 F8 50 61 C4 F8 44 71 FF F7 D7 FF 84 F8 74 72 66 62 A7 61 C4 F8 6C 52 C4 F8 7C 52 65 60 D4 F8 90 02 28 B1 D4 F8 8C 02 00 21 42 68 20 46 90 47 00 20 F8 BD 90 F8 75 12 80 F8 74 12 00 20 70 47 80 B5 90 F8 74 12 03 29 04 D1 D0 F8 8C 12 C9 69 01 B1 88 47 00 20 80 BD 01 74 00 20 70 47 80 B5 D0 F8 98 02 FF F7 31 FA BD E8 80 40 FF F7 79 BE B0 B5 00 F5 20 75 04 46 28 46 00 F0 51 F8 B4 F8 86 12 01 20 C4 E9 9B 01 94 F8 80 02 00 F0 1F 01 02 29 07 D0 01 29 0A D0 71 B9 20 46 29 46 00 F0 64 F8 0E E0 20 46 29 46 00 F0 8F F9 09 E0 20 46 29 46 00 F0 29 FA 04 E0 00 F0 80 01 20 46 00 F0 02 F8 00 20 B0 BD 80 B5 D0 F8 98 02 FE F7 83 FD BD E8 80 40 FF F7 45 BE 80 B5 D0 F8 98 02 FF F7 0F FA BD E8 80 40 FF F7 3C BE 80 B5 D0 F8 98 02 FF F7 25 FA BD E8 80 40 FF F7 33 BE 90 F8 74 12 80 F8 75 12 04 21 80 F8 74 12 00 20 70 47 80 B5 D0 F8 98 02 FE F7 96 FD BD E8 80 40 FF F7 21 BE 0A 78 02 70 4A 78 42 70 4A 88 42 80 8A 88 82 80 C9 88 C1 80 70 47 00 29 0E BF 02 20 C0 F8 8C 12 00 20 70 47 80 B5 D0 F8 8C 22 32 B1 12 68 90 47 00 28 18 BF 01 20 40 00 80 BD 02 20 80 BD 80 B5 FF F7 BA FF 00 20 80 BD 00 00 BC B5 04 46 08 78 0D 46 10 F0 60 00 0B D0 40 28 02 D0 20 28 40 F0 DE 80 D4 F8 8C 02 29 46 82 68 20 46 90 47 D9 E0 68 78 09 28 00 F2 D3 80 DF E8 00 F0 05 1B D1 27 D1 52 75 D1 2F 3D 94 F8 74 02 01 38 02 28 00 F2 C6 80 E8 88 02 28 40 F0 C2 80 D4 F8 7C 02 03 22 00 28 08 BF 01 22 21 46 41 F8 0C 2F 20 46 02 22 74 E0 94 F8 74 02 01 38 02 28 00 F2 B0 80 68 88 01 28 40 F0 AF 80 00 20 04 E0 68 88 01 28 40 F0 A9 80 01 20 C4 F8 7C 02 C8 E0 E8 88 01 28 40 F0 9E 80 94 F8 74 02 41 1E 02 29 52 D2 00 20 21 46 41 F8 08 0F 50 E0 68 88 6B 4D C1 B2 02 29 28 70 80 F0 8D 80 94 F8 74 02 03 28 4A D0 02 28 40 F0 66 80 00 29 00 F0 AA 80 03 20 84 F8 74 02 4A E0 A8 88 00 28 40 F0 7B 80 E8 88 00 28 40 F0 77 80 68 88 7F 28 00 F2 73 80 94 F8 74 12 03 29 00 F0 6E 80 00 F0 7F 05 20 46 29 46 84 F8 76 52 FF F7 F6 FE 20 46 FF F7 B2 FC 00 2D 0C BF 01 20 02 20 84 F8 74 02 5E E0 68 88 4F F0 FF 31 01 EB 10 21 06 29 54 D8 DF E8 01 F0 04 3B 26 53 53 48 51 00 D4 F8 88 12 20 7C 0A 68 0D F1 06 01 90 47 01 46 5C E0 03 28 43 D1 21 1D 20 46 01 22 FF F7 81 FC 40 E0 00 29 40 D0 60 68 88 42 5F D0 C1 B2 20 46 FF F7 3D FC 29 78 20 46 61 60 FF F7 33 FF 02 28 2D D0 53 E0 C0 B2 05 28 29 D8 DF E8 00 F0 03 53 58 5D 62 67 D4 F8 88 12 20 7C 4A 68 D4 E7 20 46 FF F7 3C FC 29 78 20 46 FF F7 21 FC 1A E0 21 7C D4 F8 8C 02 00 29 0C BF 81 6A C1 6A 0D F1 06 00 88 47 01 46 02 20 20 E0 20 7C 40 B9 D4 F8 8C 02 41 6B 0D F1 06 00 88 47 B9 E7 20 7C 68 B1 20 46 FF F7 1C FC 00 20 BC BD 00 20 60 60 02 20 84 F8 74 02 20 46 FF F7 FB FB 18 E0 D4 F8 8C 02 01 6B 0D F1 06 00 88 47 01 46 07 20 48 70 BD F8 06 00 48 B1 EA 88 3A B1 90 42 38 BF 02 46 20 46 AD F8 06 20 FF F7 1E FC E8 88 00 28 DB D1 20 46 FF F7 25 FC D7 E7 D4 F8 88 12 20 7C 8A 68 84 E7 D4 F8 88 12 20 7C CA 68 7F E7 D4 F8 88 12 20 7C 0A 69 7A E7 D4 F8 88 12 20 7C 4A 69 75 E7 D4 F8 88 12 20 7C 8A 69 70 E7 BC 01 00 20 B0 B5 04 46 08 78 0A 46 10 F0 60 00 0A D0 40 28 01 D0 20 28 75 D1 D4 F8 8C 02 11 46 83 68 20 46 98 47 71 E0 20 28 07 D1 D4 F8 8C 02 11 46 83 68 20 46 BD E8 B0 40 18 47 50 78 11 79 A8 B1 01 28 2E D0 03 28 5D D1 94 F8 74 02 03 28 2C D1 50 88 00 28 63 D1 41 F0 80 00 80 28 5F D0 D0 88 00 28 5C D1 20 46 FF F7 4A FE 58 E0 94 F8 74 02 03 28 28 D0 02 28 45 D1 41 F0 80 00 80 28 41 D1 01 F0 7F 00 00 EB 80 00 04 EB 80 00 00 F1 14 02 09 06 58 BF 00 F5 A0 72 00 20 10 60 20 46 11 46 4A E0 94 F8 74 02 03 28 31 D0 02 28 2A D1 41 F0 80 00 80 28 26 D0 20 46 FF F7 21 FE 20 46 80 21 FF F7 1D FE 21 E0 01 F0 0F 02 02 EB 82 02 04 EB 82 02 11 F0 80 00 14 BF 92 69 D2 F8 44 21 8A B1 01 F0 7F 02 02 EB 82 02 04 EB 82 02 02 F5 A0 75 00 28 41 F0 80 00 18 BF 02 F1 14 05 80 28 12 D1 00 20 16 E0 20 46 FF F7 55 FB 00 20 B0 BD 50 88 00 28 FA D1 48 06 02 D0 20 46 FF F7 5F FC 20 46 FF F7 78 FB F1 E7 20 46 FF F7 4F FD 00 28 E7 D0 01 20 28 60 20 46 29 46 02 22 FF F7 5E FB E4 E7 B0 B5 04 46 08 78 0D 46 10 F0 60 00 18 BF 40 28 15 D1 94 F8 74 02 01 38 02 28 12 D8 A8 88 10 F0 FE 0F 0E D1 D4 F8 8C 02 29 46 82 68 20 46 90 47 50 B9 E8 88 40 B9 20 46 FF F7 4C FB 04 E0 20 28 E7 D0 20 46 FF F7 16 FB 00 20 B0 BD 00 00 B0 B5 0A 78 4C 78 02 F0 0F 03 01 25 05 FA 03 F3 01 2C 18 D1 D0 F8 1C 48 23 43 C0 F8 1C 38 53 01 00 F5 10 60 C4 58 24 04 24 D4 1C 58 8D 68 C9 78 6F F3 DF 25 45 EA 82 52 22 43 42 EA 81 41 0E 4A 11 43 19 50 16 E0 D0 F8 1C 48 52 01 44 EA 03 43 C0 F8 1C 38 00 F5 30 60 83 58 1B 04 0A D4 13 58 8C 68 C9 78 6F F3 DF 24 23 43 43 EA 81 41 02 4B 19 43 11 50 00 20 B0 BD 00 80 00 10 D0 F8 00 19 40 F2 FF 72 91 43 C0 F8 00 19 D0 F8 08 18 01 F0 06 01 04 29 05 D1 D0 F8 00 19 41 F0 03 01 C0 F8 00 19 D0 F8 04 18 41 F4 80 71 C0 F8 04 18 00 20 70 47 00 00 70 B5 04 46 06 98 04 9D 01 28 16 D1 A1 6B 18 4A 21 F4 80 31 A1 63 E1 68 0D 98 11 40 E1 60 E1 68 01 28 21 F4 40 11 E1 60 03 D1 E0 68 40 F4 80 10 E0 60 20 46 00 F0 1E F8 0F E0 E0 68 0A 9E 40 F0 40 00 E0 60 20 46 00 F0 15 F8 A1 6B 00 2E 14 BF 21 F4 80 31 41 F4 80 31 A1 63 01 2D 07 D1 A1 68 41 F0 06 01 A1 60 A1 68 41 F0 20 01 A1 60 70 BD BF FF BD FF 0A 49 0A 46 01 3A 0F D0 03 69 B3 F1 FF 3F F9 DC 02 69 42 F0 01 02 02 61 01 39 05 D0 02 69 D2 07 04 BF 00 20 70 47 F7 E7 03 20 70 47 41 0D 03 00 B0 B5 0A 78 4D 78 02 F0 0F 04 01 21 01 FA 04 F3 17 49 01 2D 11 D1 D0 F8 3C 48 9C 43 C0 F8 3C 48 14 4C 64 EA 03 03 D0 F8 1C 48 23 40 C0 F8 1C 38 00 EB 42 10 00 F5 10 60 14 E0 D0 F8 3C 58 01 F1 70 71 25 EA 03 43 C0 F8 3C 38 4F F4 80 33 A3 40 D0 F8 1C 48 24 EA 03 03 C0 F8 1C 38 00 EB 42 10 00 F5 30 60 02 68 11 40 01 60 00 20 B0 BD 00 BF 00 78 33 EC 00 00 FF FF 80 B5 D0 F8 04 18 21 F0 02 01 C0 F8 04 18 03 20 FD F7 8C FE 00 20 80 BD 80 B5 D0 F8 04 18 41 F0 02 01 C0 F8 04 18 03 20 FD F7 80 FE 00 20 80 BD 2D E9 F8 4F 83 46 DD F8 44 90 DD E9 0C 08 DD F8 28 A0 0D 46 41 21 00 22 50 29 03 D0 4B F8 21 20 01 31 F9 E7 B9 F1 00 0F 0A D0 DB F8 00 10 21 F4 00 11 CB F8 00 10 DB F8 38 10 41 F4 00 21 0F E0 DB F8 38 10 41 F4 00 11 CB F8 38 10 DB F8 38 10 21 F4 00 21 CB F8 38 10 DB F8 38 10 21 F4 80 21 CB F8 38 10 00 21 CB F8 00 1E DB F8 00 18 01 28 CB F8 00 18 06 D1 DB F8 00 08 00 2B 18 BF 40 F0 01 00 03 E0 DB F8 00 08 40 F0 03 00 CB F8 00 08 58 46 10 21 00 F0 24 FA 06 46 58 46 00 F0 12 FA 00 21 30 43 0B F5 10 62 4F F6 7F 33 00 26 CB F8 10 18 CB F8 14 18 CB F8 1C 18 B5 42 0E D0 4F F0 90 47 00 2E 08 BF 4F F0 00 67 14 68 01 36 07 EA E4 74 14 60 11 61 93 60 20 32 EE E7 0B F5 30 61 00 22 4F F6 7F 33 00 26 00 28 18 BF 01 20 B5 42 0E D0 4F F0 90 44 00 2E 08 BF 4F F0 00 64 0F 68 01 36 04 EA E7 74 0C 60 0A 61 8B 60 20 31 EE E7 DB F8 10 18 BA F1 01 0F 21 F4 80 71 CB F8 10 18 10 D1 1E 49 1E 4A CB F8 30 18 DB F8 30 18 11 43 CB F8 30 18 00 21 4B F8 18 1F 6F F0 80 41 4B F8 04 1C 0F E0 00 21 4B F8 18 1F 6F F0 80 41 BA F1 00 0F 4B F8 04 1C 05 D1 DB F8 00 10 41 F0 10 01 CB F8 00 10 DB F8 00 10 0E 4A B8 F1 00 0F 41 EA 02 01 CB F8 00 10 05 D0 DB F8 00 10 41 F0 08 01 CB F8 00 10 B9 F1 01 0F 05 D1 DB F8 00 10 06 4A 11 43 CB F8 00 10 BD E8 F8 8F 00 BF 00 01 80 00 03 00 01 00 00 38 3C 80 04 00 00 40 81 68 21 F0 01 01 81 60 00 20 70 47 F0 B5 4B 78 91 F8 00 E0 01 2B 1D D1 00 EB 4E 13 D3 F8 10 69 4D 69 31 4F 31 4C 03 F5 10 63 BD B3 26 40 1E 61 1E 69 3E 40 1E 61 8E 68 B5 42 84 BF 4E 61 35 46 1E 69 46 F4 00 26 1E 61 07 F1 00 56 1F 69 2E 40 3E 43 2E E0 00 EB 4E 10 D0 F8 10 3B 22 4C 6F F3 12 03 C0 F8 10 3B D0 F8 10 3B 6F F3 DC 43 C0 F8 10 3B 4D 69 00 F5 30 63 88 68 05 B1 48 61 1D 69 04 F1 00 54 45 F4 00 25 1D 61 20 40 1C 69 01 2A 40 EA 04 00 18 61 12 D1 C8 68 0E E0 06 EA 07 05 1D 61 1D 69 45 F4 00 25 1D 61 1D 69 05 EA 04 06 00 25 01 2A 1E 61 09 D1 08 69 00 B1 58 61 4F F0 04 41 18 68 08 43 18 60 00 20 F0 BD 19 68 00 2D 41 F0 04 41 19 60 F7 D0 0E F0 0F 01 01 22 02 FA 01 F1 00 F6 34 03 EC E7 FF FF 07 E0 00 00 F8 FF 10 B5 03 6C 13 4C A3 42 03 D3 D0 F8 00 3B 00 2B 1E D4 00 23 C0 F8 10 3B D0 F8 10 3B 01 29 43 F4 00 23 C0 F8
На самой плате написано PC13
Вот и странно. Стираю чип - тухнет синий светодиод.
Загружаю блинк - просто горит. С тактовой проблема?
  while (1)  {
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
	  HAL_GPIO_WritePin(LED13_GPIO_Port, LED13_Pin, GPIO_PIN_RESET);
	  HAL_Delay(1000);
	  HAL_GPIO_WritePin(LED13_GPIO_Port, LED13_Pin, GPIO_PIN_SET);
	  HAL_Delay(1000);
Какой кварц на плате?
где?
это не код.
и картинку показать как тактирование настроено, из CubeIDE/
А макросы LED13_GPIO_Port и LED13_Pin точно определены?
Может лучше для начала так?
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, GPIO_PIN_SET);
