V2 nodemcu cp2102
Подскажите пожалуйста купил платку nodemcu cp2102 nodemcu залил прошивку wifi видет но подключится не магу пишет пароль не верный, пробовал другую прошивку по ip заходит только пишет, erro
прошивку в студию
  syncwebserver.h - ESP3D sync functions file
  Copyright (c) 2014 Luc Lebosse. All rights reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#ifndef SYNCWEBSERVER_H
#define SYNCWEBSERVER_H
#include "config.h"
#define NODEBUG_WEBSOCKETS
#include <WebSocketsServer.h>
extern void handle_web_interface_root();
extern void handle_login();
extern void handleFileList();
extern void SPIFFSFileupload();
extern void handle_not_found();
extern void handle_web_command();
extern void handle_web_command_silent();
extern void handle_serial_SDFileList();
extern void SDFile_serial_upload();
extern WebSocketsServer * socket_server;
extern void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length);
#ifdef SSDP_FEATURE
extern void handle_SSDP ();
#endif
#ifdef WEB_UPDATE_FEATURE
extern void handleUpdate ();
extern void WebUpdateUpload ();
#include "config.h"
#ifdef SSDP_FEATURE
#endif
#endif
#endif
```cpp
  config.cpp- ESP3D configuration class
#include "config.h"
#include <EEPROM.h>
#ifndef FS_NO_GLOBALS
#define FS_NO_GLOBALS
#endif
#include <FS.h>
#include <WiFiUdp.h>
#include "wificonf.h"
#ifdef ARDUINO_ARCH_ESP8266
extern "C" {
#include "user_interface.h"
#endif
#ifdef ARDUINO_ARCH_ESP32
#include <esp_ota_ops.h>
#include "Update.h"
#include "esp_wifi.h"
#endif
#include "espcom.h"
#ifdef TIMESTAMP_FEATURE
#include <time.h>
#endif
#ifdef DHT_FEATURE
#include "DHTesp.h"
extern DHTesp dht;
#endif
#ifdef NOTIFICATION_FEATURE
#include "notifications_service.h"
#endif
uint8_t CONFIG::FirmwareTarget = UNKNOWN_FW;
byte CONFIG::output_flag = DEFAULT_OUTPUT_FLAG;
bool  CONFIG::is_com_enabled = false;
#ifdef DHT_FEATURE
byte CONFIG::DHT_type  = DEFAULT_DHT_TYPE;
int CONFIG::DHT_interval = DEFAULT_DHT_INTERVAL;
#endif
//Watchdog feeder
void  CONFIG::wdtFeed()
    ESP.wdtFeed();
#else
    void esp_task_wdt_feed();
#endif
void CONFIG::wait (uint32_t milliseconds)
#if defined(ASYNCWEBSERVER)
    uint32_t timeout = millis();
    while ( (millis() - timeout) < milliseconds) {
        wdtFeed();
#else
    delay(milliseconds);
#endif
bool CONFIG::SetFirmwareTarget (uint8_t fw)
    if ( fw <= MAX_FW_ID) {
        FirmwareTarget = fw;
        return true;
        return false;
uint8_t CONFIG::GetFirmwareTarget()
    return FirmwareTarget;
const char* CONFIG::GetFirmwareTargetName()
    static String response;
    if ( CONFIG::FirmwareTarget == REPETIER4DV) {
        response = F ("Repetier for Davinci");
    } else if ( CONFIG::FirmwareTarget == REPETIER) {
        response = F ("Repetier");
    } else if ( CONFIG::FirmwareTarget == MARLIN) {
        response = F ("Marlin");
    } else if ( CONFIG::FirmwareTarget == MARLINKIMBRA) {
        response = F ("MarlinKimbra");
    } else if ( CONFIG::FirmwareTarget == SMOOTHIEWARE) {
        response = F ("Smoothieware");
    } else if ( CONFIG::FirmwareTarget == GRBL) {
        response = F ("Grbl");
        response = F ("???");
    return response.c_str();
const char* CONFIG::GetFirmwareTargetShortName()
        response = F ("repetier4davinci");
        response = F ("repetier");
        response = F ("marlin");
        response = F ("marlinkimbra");
        response = F ("smoothieware");
        response = F ("grbl");
void CONFIG::InitFirmwareTarget()
    uint8_t b = UNKNOWN_FW;
    if (!CONFIG::read_byte (EP_TARGET_FW, &b ) ) {
        b = UNKNOWN_FW;
    if (!SetFirmwareTarget (b) ) {
        SetFirmwareTarget (UNKNOWN_FW) ;
void CONFIG::InitOutput()
    byte bflag = 0;
    if (!CONFIG::read_byte (EP_OUTPUT_FLAG, &bflag ) ) {
        bflag = 0;
    CONFIG::output_flag = bflag;
bool  CONFIG::is_locked(byte flag)
    return ((CONFIG::output_flag & flag) == flag);
void CONFIG::InitDirectSD()
    CONFIG::is_direct_sd = false;
bool CONFIG::DisableSerial()
#ifdef USE_SERIAL_0
Serial.end();
#endif
#ifdef USE_SERIAL_1
Serial1.end();
#endif
#ifdef USE_SERIAL_2
Serial2.end();
#endif
return true;
bool CONFIG::InitBaudrate(long value)
    long baud_rate = 0;
    if (value > 0) {
        baud_rate = value;
        if ( !CONFIG::read_buffer (EP_BAUD_RATE,  (byte *) &baud_rate, INTEGER_LENGTH) ) {
            return false;
    if ( ! (baud_rate == 9600 || baud_rate == 19200 || baud_rate == 38400 || baud_rate == 57600 || baud_rate == 115200 || baud_rate == 230400 || baud_rate == 250000 || baud_rate == 500000 || baud_rate == 921600 ) ) {
        return false;
    //setup serial
    //TODO define baudrate for each Serial
#ifdef USE_SERIAL_0
    if (Serial.baudRate() != baud_rate) {
        Serial.begin (baud_rate);
#else
        Serial.begin (baud_rate, ESP_SERIAL_PARAM, ESP_RX_PIN, ESP_TX_PIN);
#endif
#endif
#ifdef USE_SERIAL_1
    if (Serial1.baudRate() != baud_rate) {
        Serial1.begin (baud_rate);
#else
        Serial1.begin (baud_rate, ESP_SERIAL_PARAM, ESP_RX_PIN, ESP_TX_PIN);
#endif
#endif
#ifdef USE_SERIAL_2
    if (Serial2.baudRate() != baud_rate) {
        Serial2.begin (baud_rate);
#else
        Serial2.begin (baud_rate, ESP_SERIAL_PARAM, ESP_RX_PIN, ESP_TX_PIN);
#endif
#endif
//only Serial for ESP8266
    Serial.setRxBufferSize (SERIAL_RX_BUFFER_SIZE);
#endif
    wifi_config.baud_rate = baud_rate;
    delay (100);
    CONFIG::is_com_enabled = true;
    return true;
bool CONFIG::InitExternalPorts()
    if (!CONFIG::read_buffer (EP_WEB_PORT,  (byte *) & (wifi_config.iweb_port), INTEGER_LENGTH) || !CONFIG::read_buffer (EP_DATA_PORT,  (byte *) & (wifi_config.idata_port), INTEGER_LENGTH) ) {
        return false;
    if (wifi_config.iweb_port < DEFAULT_MIN_WEB_PORT || wifi_config.iweb_port > DEFAULT_MAX_WEB_PORT || wifi_config.idata_port < DEFAULT_MIN_DATA_PORT || wifi_config.idata_port > DEFAULT_MAX_DATA_PORT) {
        return false;
    return true;
//warning if using from async function with async param
//restart will work but reason will be wrong
//better to use "web_interface->restartmodule = true;" instead
void CONFIG::esp_restart (bool async)
    LOG ("Restarting\r\n")
    ESPCOM::flush (DEFAULT_PRINTER_PIPE);
    SPIFFS.end();
    if (!async) {
        delay (1000);
    //ESP8266  has only serial
    Serial.swap();
#endif
    ESP.restart();
    while (1) {
        if (!async) {
            delay (1);
#ifdef DHT_FEATURE
void  CONFIG::InitDHT(bool refresh)
    if (!refresh) {
        byte bflag = DEFAULT_DHT_TYPE;
        int ibuf = DEFAULT_DHT_INTERVAL;
        if (!CONFIG::read_byte (EP_DHT_TYPE, &bflag ) ) {
        CONFIG::DHT_type = bflag;
        if (!CONFIG::read_buffer (EP_DHT_INTERVAL,  (byte *) &ibuf, INTEGER_LENGTH) ) {
        CONFIG::DHT_interval = ibuf;
    if (CONFIG::DHT_type != 255) {
        dht.setup(ESP_DHT_PIN,(DHTesp::DHT_MODEL_t)CONFIG::DHT_type);    // Connect DHT sensor to GPIO ESP_DHT_PIN
#endif
void  CONFIG::InitPins()
#ifdef RECOVERY_FEATURE
    pinMode (RESET_CONFIG_PIN, INPUT);
#endif
#ifdef DHT_FEATURE
    CONFIG::InitDHT();
#endif
#if defined(TIMESTAMP_FEATURE)
void CONFIG::init_time_client()
    String s1, s2, s3;
    int8_t t1;
    byte d1;
    if (!CONFIG::read_string (EP_TIME_SERVER1, s1, MAX_DATA_LENGTH) ) {
        s1 = FPSTR (DEFAULT_TIME_SERVER1);
    if (!CONFIG::read_string (EP_TIME_SERVER2, s2, MAX_DATA_LENGTH) ) {
        s2 = FPSTR (DEFAULT_TIME_SERVER2);
    if (!CONFIG::read_string (EP_TIME_SERVER3, s3, MAX_DATA_LENGTH) ) {
        s3 = FPSTR (DEFAULT_TIME_SERVER3);
    if (!CONFIG::read_byte (EP_TIMEZONE, (byte *) &t1 ) ) {
        t1 = DEFAULT_TIME_ZONE;
    if (!CONFIG::read_byte (EP_TIME_ISDST, &d1 ) ) {
        d1 = DEFAULT_TIME_DST;
    configTime (3600 * (t1), d1 * 3600, s1.c_str(), s2.c_str(), s3.c_str() );
    time_t now = time(nullptr);
    if (WiFi.getMode() == WIFI_STA) {
        int nb = 0;
        while ((now < 8 * 3600 * 2) && (nb < 6)) {
            wait(500);
            nb++;
#endif
bool CONFIG::is_direct_sd = false;
bool CONFIG::isHostnameValid (const char * hostname)
    //limited size
    char c;
    if (strlen (hostname) > MAX_HOSTNAME_LENGTH || strlen (hostname) < MIN_HOSTNAME_LENGTH) {
        return false;
    //only letter and digit
    for (uint i = 0; i < strlen (hostname); i++) {
        c = hostname[i];
        if (! (isdigit (c) || isalpha (c) || c == '_') ) {
            return false;
        if (c == ' ') {
            return false;
    return true;
bool CONFIG::isSSIDValid (const char * ssid)
    //limited size
    //char c;
    if (strlen (ssid) > MAX_SSID_LENGTH || strlen (ssid) < MIN_SSID_LENGTH) {
        return false;
    //only printable
    for (uint i = 0; i < strlen (ssid); i++) {
        if (!isPrintable (ssid[i]) ) {
            return false;
    return true;
bool CONFIG::isPasswordValid (const char * password)
    //limited size
    if (strlen (password) > MAX_PASSWORD_LENGTH) {
        return false;
#if MIN_PASSWORD_LENGTH > 0
    if (strlen (password) < MIN_PASSWORD_LENGTH) {
        ) return false;
#endif
    //no space allowed
    for (uint i = 0; i < strlen (password); i++)
        if (password[i] == ' ') {
            return false;
    return true;
bool CONFIG::isLocalPasswordValid (const char * password)
    char c;
    //limited size
    if ( (strlen (password) > MAX_LOCAL_PASSWORD_LENGTH) ||  (strlen (password) < MIN_LOCAL_PASSWORD_LENGTH) ) {
        return false;
    //no space allowed
    for (uint i = 0; i < strlen (password); i++) {
        c = password[i];
        if (c == ' ') {
            return false;
    return true;
bool CONFIG::isIPValid (const char * IP)
    //limited size
    int internalcount = 0;
    int dotcount = 0;
    bool previouswasdot = false;
    char c;
    if (strlen (IP) > 15 || strlen (IP) == 0) {
        return false;
    //cannot start with .
    if (IP[0] == '.') {
        return false;
    for (uint i = 0; i < strlen (IP); i++) {
        c = IP[i];
        if (isdigit (c) ) {
            //only 3 digit at once
            internalcount++;
            if (internalcount > 3) {
                return false;
        } else if (c == '.') {
            //cannot have 2 dots side by side
            if (previouswasdot) {
                return false;
            previouswasdot = true;
            internalcount = 0;
            dotcount++;
        }//if not a dot neither a digit it is wrong
        else {
            return false;
    //if not 3 dots then it is wrong
    if (dotcount != 3) {
        return false;
    //cannot have the last dot as last char
    if (IP[strlen (IP) - 1] == '.') {
        return false;
    return true;
char * CONFIG::intTostr (int value)
    static char result [12];
    sprintf (result, "%d", value);
    return result;
String CONFIG::formatBytes (uint64_t bytes)
    if (bytes < 1024) {
        return String ((uint16_t)bytes) + " B";
    } else if (bytes < (1024 * 1024) ) {
        return String ((float)(bytes / 1024.0)) + " KB";
    } else if (bytes < (1024 * 1024 * 1024) ) {
        return String ((float)(bytes / 1024.0 / 1024.0)) + " MB";
        return String ((float)(bytes / 1024.0 / 1024.0 / 1024.0)) + " GB";
//helper to convert string to IP
//do not use IPAddress.fromString() because lack of check point and error result
//return number of parts
byte CONFIG::split_ip (const char * ptr, byte * part)
    if (strlen (ptr) > 15 || strlen (ptr) < 7) {
        part[0] = 0;
        part[1] = 0;
        part[2] = 0;
        part[3] = 0;
        return 0;
    char pstart [16];
    char * ptr2;
    strcpy (pstart, ptr);
    ptr2 = pstart;
    byte i = strlen (pstart);
    byte pos = 0;
    for (byte j = 0; j < i; j++) {
        if (pstart[j] == '.') {
            if (pos == 4) {
                part[0] = 0;
                part[1] = 0;
                part[2] = 0;
                part[3] = 0;
                return 0;
            pstart[j] = 0x0;
            part[pos] = atoi (ptr2);
            pos++;
            ptr2 = &pstart[j + 1];
    return pos + 1;
//just simple helper to convert mac address to string
char * CONFIG::mac2str (uint8_t mac [WL_MAC_ADDR_LENGTH])
    static char macstr [18];
    if (0 > sprintf (macstr, "%02X:%02X:%02X:%02X:%02X:%02X", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]) ) {
        strcpy (macstr, "00:00:00:00:00:00");
    return macstr;
bool CONFIG::set_EEPROM_version(uint8_t v)
    byte byte_buffer[6];
    byte_buffer[0]='E';
    byte_buffer[1]='S';
    byte_buffer[2]='P';
    byte_buffer[3]='3';
    byte_buffer[4]='D';
    byte_buffer[5]=v;
    return CONFIG::write_buffer (EP_EEPROM_VERSION, byte_buffer, 6);
uint8_t CONFIG::get_EEPROM_version()
    long baud_rate;
    if (!CONFIG::read_buffer (EP_EEPROM_VERSION, byte_buffer, 6)) {
        return EEPROM_V0;
    if ((byte_buffer[0]=='E') && (byte_buffer[1]=='S') && (byte_buffer[2]=='P')&& (byte_buffer[3]=='3') && (byte_buffer[4]=='D')) {
        return byte_buffer[5];
        return EEPROM_V0;
    if ((baud_rate == 9600 || baud_rate == 19200 || baud_rate == 38400 || baud_rate == 57600 || baud_rate == 115200 || baud_rate == 230400 || baud_rate == 250000 || baud_rate == 500000 || baud_rate == 921600 ) ) {
        return EEPROM_V1;
    return EEPROM_V0;
bool CONFIG::adjust_EEPROM_settings()
    uint8_t v = get_EEPROM_version();
    bool bdone =false;
    if (v == EEPROM_CURRENT_VERSION) {
        return true;
    if (v == 1) {
        bdone =true;
#ifdef SDCARD_FEATURE
        if (!CONFIG::write_byte (EP_SD_SPEED_DIV, DEFAULT_SDREADER_SPEED) ) {
            bdone =false;
#endif
#ifdef DHT_FEATURE
        if (!CONFIG::write_buffer (EP_DHT_INTERVAL, (const byte *) &DEFAULT_DHT_INTERVAL, INTEGER_LENGTH) ) {
            bdone =false;
        if (!CONFIG::write_byte (EP_DHT_TYPE, DEFAULT_DHT_TYPE) ) {
            bdone =false;
#endif
        if (!CONFIG::write_byte (EP_OUTPUT_FLAG, DEFAULT_OUTPUT_FLAG) ) {
            bdone =false;
    if (bdone) {
        set_EEPROM_version(EEPROM_CURRENT_VERSION);
    return bdone;
//read a string
//a string is multibyte + \0, this is won't work if 1 char is multibyte like chinese char
bool CONFIG::read_string (int pos, char byte_buffer[], int size_max)
    //check if parameters are acceptable
    if (size_max == 0 ||  pos + size_max + 1 > EEPROM_SIZE || byte_buffer == NULL) {
        LOG ("Error read string\r\n")
        return false;
    EEPROM.begin (EEPROM_SIZE);
    byte b = 13; // non zero for the while loop below
    int i = 0;
    //read until max size is reached or \0 is found
    while (i < size_max && b != 0) {
        b = EEPROM.read (pos + i);
        byte_buffer[i] = b;
        i++;
    // Be sure there is a 0 at the end.
    if (b != 0) {
        byte_buffer[i - 1] = 0x00;
    EEPROM.end();
    return true;
bool CONFIG::read_string (int pos, String & sbuffer, int size_max)
    if (size_max == 0 ||  pos + size_max + 1 > EEPROM_SIZE ) {
        return false;
    int i = 0;
    sbuffer = "";
        if (b != 0) {
            sbuffer += char (b);
        i++;
    EEPROM.end();
    return true;
//read a buffer of size_buffer
bool CONFIG::read_buffer (int pos, byte byte_buffer[], int size_buffer)
    if (size_buffer == 0 ||  pos + size_buffer > EEPROM_SIZE || byte_buffer == NULL) {
        LOG ("Error read buffer\r\n")
        return false;
    int i = 0;
    while (i < size_buffer ) {
        byte_buffer[i] = EEPROM.read (pos + i);
        i++;
    EEPROM.end();
    return true;
//read a flag / byte
bool CONFIG::read_byte (int pos, byte * value)
    if (pos + 1 > EEPROM_SIZE) {
        LOG ("Error read byte\r\n")
        return false;
    value[0] = EEPROM.read (pos);
    EEPROM.end();
    return true;
bool CONFIG::write_string (int pos, const __FlashStringHelper *str)
    String stmp = str;
    return write_string (pos, stmp.c_str() );
//write a string (array of byte with a 0x00  at the end)
bool CONFIG::write_string (int pos, const char * byte_buffer)
    int size_buffer;
    int maxsize = EEPROM_SIZE;
    size_buffer = strlen (byte_buffer);
    switch (pos) {
    case EP_ADMIN_PWD:
    case EP_USER_PWD:
        maxsize = MAX_LOCAL_PASSWORD_LENGTH;
    case EP_AP_SSID:
    case EP_STA_SSID:
        maxsize = MAX_SSID_LENGTH;
    case EP_AP_PASSWORD:
    case EP_STA_PASSWORD:
        maxsize = MAX_PASSWORD_LENGTH;
    case EP_HOSTNAME:
        maxsize = MAX_HOSTNAME_LENGTH;
    case EP_TIME_SERVER1:
    case EP_TIME_SERVER2:
    case EP_TIME_SERVER3:
        maxsize = MAX_DATA_LENGTH;
    case ESP_NOTIFICATION_TOKEN1:
    case ESP_NOTIFICATION_TOKEN2:
        maxsize = MAX_NOTIFICATION_TOKEN_LENGTH;
    case ESP_NOTIFICATION_SETTINGS:
        maxsize = MAX_NOTIFICATION_SETTINGS_LENGTH;
    default:
    if ( pos + size_buffer + 1 > EEPROM_SIZE || size_buffer > maxsize  ) {
        LOG ("Error write string\r\n")
        return false;
    if (!((pos == EP_STA_PASSWORD) || (pos == EP_AP_PASSWORD))) {
        if((size_buffer == 0 ) || (byte_buffer == NULL )) {
            return false;
    //copy the value(s)
    for (int i = 0; i < size_buffer; i++) {
        EEPROM.write (pos + i, byte_buffer[i]);
    //0 terminal
    EEPROM.write (pos + size_buffer, 0x00);
    EEPROM.commit();
    EEPROM.end();
    return true;
//write a buffer
bool CONFIG::write_buffer (int pos, const byte * byte_buffer, int size_buffer)
        LOG ("Error write buffer\r\n")
        return false;
    //copy the value(s)
    EEPROM.commit();
    EEPROM.end();
    return true;
bool CONFIG::write_byte (int pos, const byte value)
        LOG ("Error write byte\r\n")
        return false;
    EEPROM.write (pos, value);
    EEPROM.commit();
    EEPROM.end();
    return true;
bool CONFIG::reset_config()
    if (!CONFIG::write_byte (EP_WIFI_MODE, DEFAULT_WIFI_MODE) ) {
        return false;
    if (!CONFIG::write_buffer (EP_BAUD_RATE, (const byte *) &DEFAULT_BAUD_RATE, INTEGER_LENGTH) ) {
        return false;
    if (!CONFIG::write_string (EP_AP_SSID, FPSTR (DEFAULT_AP_SSID) ) ) {
        return false;
    if (!CONFIG::write_string (EP_AP_PASSWORD, FPSTR (DEFAULT_AP_PASSWORD) ) ) {
        return false;
    if (!CONFIG::write_string (EP_STA_SSID, FPSTR (DEFAULT_STA_SSID) ) ) {
        return false;
    if (!CONFIG::write_string (EP_STA_PASSWORD, FPSTR (DEFAULT_STA_PASSWORD) ) ) {
        return false;
    if (!CONFIG::write_byte (EP_AP_IP_MODE, DEFAULT_AP_IP_MODE) ) {
        return false;
    if (!CONFIG::write_byte (EP_STA_IP_MODE, DEFAULT_STA_IP_MODE) ) {
        return false;
    if (!CONFIG::write_buffer (EP_STA_IP_VALUE, DEFAULT_IP_VALUE, IP_LENGTH) ) {
        return false;
    if (!CONFIG::write_buffer (EP_STA_MASK_VALUE, DEFAULT_MASK_VALUE, IP_LENGTH) ) {
        return false;
    if (!CONFIG::write_buffer (EP_STA_GATEWAY_VALUE, DEFAULT_GATEWAY_VALUE, IP_LENGTH) ) {
        return false;
    if (!CONFIG::write_byte (EP_STA_PHY_MODE, DEFAULT_PHY_MODE) ) {
        return false;
    if (!CONFIG::write_buffer (EP_AP_IP_VALUE, DEFAULT_IP_VALUE, IP_LENGTH) ) {
        return false;
    if (!CONFIG::write_buffer (EP_AP_MASK_VALUE, DEFAULT_MASK_VALUE, IP_LENGTH) ) {
        return false;
    if (!CONFIG::write_buffer (EP_AP_GATEWAY_VALUE, DEFAULT_GATEWAY_VALUE, IP_LENGTH) ) {
        return false;
    if (!CONFIG::write_byte (EP_AP_PHY_MODE, DEFAULT_PHY_MODE) ) {
        return false;
    if (!CONFIG::write_byte (EP_SLEEP_MODE, DEFAULT_SLEEP_MODE) ) {
        return false;
    if (!CONFIG::write_byte (EP_CHANNEL, DEFAULT_CHANNEL) ) {
        return false;
    if (!CONFIG::write_byte (EP_AUTH_TYPE, DEFAULT_AUTH_TYPE) ) {
        return false;
    if (!CONFIG::write_byte (EP_SSID_VISIBLE, DEFAULT_SSID_VISIBLE) ) {
        return false;
    if (!CONFIG::write_buffer (EP_WEB_PORT, (const byte *) &DEFAULT_WEB_PORT, INTEGER_LENGTH) ) {
        return false;
    if (!CONFIG::write_buffer (EP_DATA_PORT, (const byte *) &DEFAULT_DATA_PORT, INTEGER_LENGTH) ) {
        return false;
    if (!CONFIG::write_string (EP_HOSTNAME, wifi_config.get_default_hostname() ) ) {
        return false;
    if (!CONFIG::write_string (EP_ADMIN_PWD, FPSTR (DEFAULT_ADMIN_PWD) ) ) {
        return false;
    if (!CONFIG::write_string (EP_USER_PWD, FPSTR (DEFAULT_USER_PWD) ) ) {
        return false;
    if (!CONFIG::write_byte (EP_TARGET_FW, UNKNOWN_FW) ) {
        return false;
    if (!CONFIG::write_byte (EP_TIMEZONE, DEFAULT_TIME_ZONE) ) {
        return false;
    if (!CONFIG::write_byte (EP_TIME_ISDST, DEFAULT_TIME_DST) ) {
        return false;
    if (!CONFIG::write_string (EP_TIME_SERVER1, FPSTR (DEFAULT_TIME_SERVER1) ) ) {
        return false;
    if (!CONFIG::write_string (EP_TIME_SERVER2, FPSTR (DEFAULT_TIME_SERVER2) ) ) {
        return false;
    if (!CONFIG::write_string (EP_TIME_SERVER3, FPSTR (DEFAULT_TIME_SERVER3) ) ) {
        return false;
#endif
        return false;
#ifdef DHT_FEATURE
        return false;
        return false;
#endif
    if (!CONFIG::write_byte (ESP_NOTIFICATION_TYPE, DEFAULT_NOTIFICATION_TYPE) ) {
        return false;
    if (!CONFIG::write_string (ESP_NOTIFICATION_TOKEN1, DEFAULT_NOTIFICATION_TOKEN1 ) ) {
        return false;
    if (!CONFIG::write_string (ESP_NOTIFICATION_TOKEN2, DEFAULT_NOTIFICATION_TOKEN2 ) ) {
        return false;
    if (!CONFIG::write_string (ESP_NOTIFICATION_SETTINGS, DEFAULT_NOTIFICATION_SETTINGS ) ) {
        return false;
    if (!CONFIG::write_byte (ESP_AUTO_NOTIFICATION, DEFAULT_AUTO_NOTIFICATION_STATE) ) {
        return false;
#endif
    return set_EEPROM_version(EEPROM_CURRENT_VERSION);
void CONFIG::print_config (tpipe output, bool plaintext, ESPResponseStream  *espresponse)
    if (!plaintext) {
        ESPCOM::print (F ("{\"chip_id\":\""), output, espresponse);
        ESPCOM::print (F ("Chip ID: "), output, espresponse);
    ESPCOM::print (String (ESP.getChipId() ).c_str(), output, espresponse);
#else
    ESPCOM::print (String ( (uint16_t) (ESP.getEfuseMac() >> 32) ).c_str(), output, espresponse);
#endif
    if (!plaintext) {
        ESPCOM::print (F ("\","), output, espresponse);
        ESPCOM::print (F ("\n"), output, espresponse);
    if (!plaintext) {
        ESPCOM::print (F ("\"cpu\":\""), output, espresponse);
        ESPCOM::print (F ("CPU Frequency: "), output, espresponse);
    ESPCOM::print (String (ESP.getCpuFreqMHz() ).c_str(), output, espresponse);
    if (plaintext) {
        ESPCOM::print (F ("Mhz"), output, espresponse);
    if (!plaintext) {
    if (!plaintext) {
        ESPCOM::print (F ("\"cpu_temp\":\""), output, espresponse);
        ESPCOM::print (F ("CPU Temperature: "), output, espresponse);
    ESPCOM::print (String (temperatureRead(), 1).c_str(), output, espresponse);
    if (plaintext) {
        ESPCOM::print (F ("C"), output, espresponse);
    if (!plaintext) {
#endif
    if (!plaintext) {
        ESPCOM::print (F ("\"freemem\":\""), output, espresponse);
        ESPCOM::print (F ("Free memory: "), output, espresponse);
    ESPCOM::print (formatBytes (ESP.getFreeHeap() ).c_str(), output, espresponse);
    if (!plaintext) {
    if (!plaintext) {
        ESPCOM::print (F ("\""), output, espresponse);
    ESPCOM::print (F ("SDK"), output, espresponse);
    if (!plaintext) {
        ESPCOM::print (F ("\":\""), output, espresponse);
        ESPCOM::print (F (": "), output, espresponse);
    ESPCOM::print (ESP.getSdkVersion(), output, espresponse);
    if (!plaintext) {
    if (!plaintext) {
        ESPCOM::print (F ("\"flash_size\":\""), output, espresponse);
        ESPCOM::print (F ("Flash Size: "), output, espresponse);
    ESPCOM::print (formatBytes (ESP.getFlashChipSize() ).c_str(), output, espresponse);
    if (!plaintext) {
    if (!plaintext) {
        ESPCOM::print (F ("\"update_size\":\""), output, espresponse);
        ESPCOM::print (F ("Available Size for update: "), output, espresponse);
    uint32_t  flashsize = ESP.getFlashChipSize();
    fs::FSInfo info;
    SPIFFS.info (info);
    //if higher than 1MB take out SPIFFS
    if (flashsize > 1024 * 1024) {
        flashsize = (1024 * 1024)-ESP.getSketchSize()-1024;
        flashsize = flashsize - ESP.getSketchSize()-info.totalBytes-1024;
    ESPCOM::print(formatBytes(flashsize).c_str(), output, espresponse);
    if (!plaintext) {
        if (flashsize > ( ESP.getSketchSize())) {
            ESPCOM::println(F("(Ok)"), output, espresponse);
            ESPCOM::println(F ("(Not enough)"), output, espresponse);
    if (!plaintext) {
        ESPCOM::print (F ("\"spiffs_size\":\""), output, espresponse);
        ESPCOM::print (F ("Available Size for SPIFFS: "), output, espresponse);
    ESPCOM::print (formatBytes (info.totalBytes).c_str(), output, espresponse);
    if (!plaintext) {
#else
    if (!plaintext) {
     size_t flashsize = 0;
    if (esp_ota_get_running_partition()) {
        const esp_partition_t* partition = esp_ota_get_next_update_partition(NULL);
        if (partition) {
            flashsize = partition->size;
    ESPCOM::print (formatBytes (flashsize).c_str(), output, espresponse);
    if (!plaintext) {
        if (flashsize  > 0x0) {
            ESPCOM::println (F ("(Ok)"), output, espresponse);
            ESPCOM::print (F ("(Not enough)"), output, espresponse);
    if (!plaintext) {
    ESPCOM::print (formatBytes (SPIFFS.totalBytes() ).c_str(), output, espresponse);
    if (!plaintext) {
#endif
    if (!plaintext) {
        ESPCOM::print (F ("\"baud_rate\":\""), output, espresponse);
        ESPCOM::print (F ("Baud rate: "), output, espresponse);
    uint32_t br = ESPCOM::baudRate(DEFAULT_PRINTER_PIPE);
    ESPCOM::print (String (br).c_str(), output, espresponse);
    if (!plaintext) {
    if (!plaintext) {
        ESPCOM::print (F ("\"sleep_mode\":\""), output, espresponse);
        ESPCOM::print (F ("Sleep mode: "), output, espresponse);
    wifi_ps_type_t ps_type;
    esp_wifi_get_ps (&ps_type);
#else
    WiFiSleepType_t ps_type;
    ps_type = WiFi.getSleepMode();
#endif
    if (ps_type == WIFI_NONE_SLEEP) {
        ESPCOM::print (F ("None"), output, espresponse);
    } else if (ps_type == WIFI_LIGHT_SLEEP) {
        ESPCOM::print (F ("Light"), output, espresponse);
    } else if (ps_type == WIFI_MODEM_SLEEP) {
        ESPCOM::print (F ("Modem"), output, espresponse);
        ESPCOM::print (F ("???"), output, espresponse);
    if (!plaintext) {
    if (!plaintext) {
        ESPCOM::print (F ("\"channel\":\""), output, espresponse);
        ESPCOM::print (F ("Channel: "), output, espresponse);
    ESPCOM::print (String (WiFi.channel() ).c_str(), output, espresponse);
    if (!plaintext) {
    uint8_t PhyMode;
        esp_wifi_get_protocol (WIFI_IF_STA, &PhyMode);
        esp_wifi_get_protocol (WIFI_IF_AP, &PhyMode);
#else
    WiFiPhyMode_t PhyMode = WiFi.getPhyMode();
#endif
    if (!plaintext) {
        ESPCOM::print (F ("\"phy_mode\":\""), output, espresponse);
        ESPCOM::print (F ("Phy Mode: "), output, espresponse);
    if (PhyMode == (WIFI_PHY_MODE_11G) ) {
        ESPCOM::print (F ("11g"), output, espresponse);
    } else if (PhyMode == (WIFI_PHY_MODE_11B) ) {
        ESPCOM::print (F ("11b"), output, espresponse);
    } else if (PhyMode == (WIFI_PHY_MODE_11N) ) {
        ESPCOM::print (F ("11n"), output, espresponse);
    if (!plaintext) {
    if (!plaintext) {
        ESPCOM::print (F ("\"web_port\":\""), output, espresponse);
        ESPCOM::print (F ("Web port: "), output, espresponse);
    ESPCOM::print (String (wifi_config.iweb_port).c_str(), output, espresponse);
    if (!plaintext) {
    if (!plaintext) {
        ESPCOM::print (F ("\"data_port\":\""), output, espresponse);
        ESPCOM::print (F ("Data port: "), output, espresponse);
#ifdef TCP_IP_DATA_FEATURE
    ESPCOM::print (String (wifi_config.idata_port).c_str(), output, espresponse);
#else
    ESPCOM::print (F ("Disabled"), output, espresponse);
#endif
    if (!plaintext) {
    if (WiFi.getMode() == WIFI_STA || WiFi.getMode() == WIFI_AP_STA) {
        if (!plaintext) {
            ESPCOM::print (F ("\"hostname\":\""), output, espresponse);
            ESPCOM::print (F ("Hostname: "), output, espresponse);
        ESPCOM::print (WiFi.getHostname(), output, espresponse);
#else
        ESPCOM::print (WiFi.hostname().c_str(), output, espresponse);
#endif
        if (!plaintext) {
    if (!plaintext) {
        ESPCOM::print (F ("\"active_mode\":\""), output, espresponse);
        ESPCOM::print (F ("Active Mode: "), output, espresponse);
        ESPCOM::print (F ("STA ("), output, espresponse);
        ESPCOM::print (WiFi.macAddress().c_str(), output, espresponse);
        ESPCOM::print (F (")"), output, espresponse);
        if (!plaintext) {
        if (WiFi.isConnected() ) {
            if (!plaintext) {
                ESPCOM::print (F ("\"connected_ssid\":\""), output, espresponse);
                ESPCOM::print (F ("Connected to: "), output, espresponse);
            ESPCOM::print (WiFi.SSID().c_str(), output, espresponse);
            if (!plaintext) {
            if (!plaintext) {
                ESPCOM::print (F ("\"connected_signal\":\""), output, espresponse);
                ESPCOM::print (F ("Signal: "), output, espresponse);
            ESPCOM::print (String (wifi_config.getSignal (WiFi.RSSI() ) ).c_str(), output, espresponse);
            ESPCOM::print (F ("%"), output, espresponse);
            if (!plaintext) {
            if (!plaintext) {
                ESPCOM::print (F ("\"connection_status\":\""), output, espresponse);
                ESPCOM::print (F ("Connection Status: "), output, espresponse);
            if (WiFi.status() == WL_DISCONNECTED) {
                ESPCOM::print (F ("Disconnected"), output, espresponse);
            } else if (WiFi.status() == WL_CONNECTION_LOST) {
                ESPCOM::print (F ("Connection lost"), output, espresponse);
            } else if (WiFi.status() == WL_CONNECT_FAILED) {
                ESPCOM::print (F ("Connection failed"), output, espresponse);
            } else if (WiFi.status() == WL_NO_SSID_AVAIL) {
                ESPCOM::print (F ("No connection"), output, espresponse);
            } else if (WiFi.status() == WL_IDLE_STATUS   ) {
                ESPCOM::print (F ("Idle"), output, espresponse);
                ESPCOM::print (F ("Unknown"), output, espresponse);
            if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"ip_mode\":\""), output, espresponse);
            ESPCOM::print (F ("IP Mode: "), output, espresponse);
        tcpip_adapter_dhcp_status_t dhcp_status;
        tcpip_adapter_dhcpc_get_status (TCPIP_ADAPTER_IF_STA, &dhcp_status);
        if (dhcp_status == TCPIP_ADAPTER_DHCP_STARTED)
#else
        if (wifi_station_dhcpc_status() == DHCP_STARTED)
#endif
            ESPCOM::print (F ("DHCP"), output, espresponse);
            ESPCOM::print (F ("Static"), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"ip\":\""), output, espresponse);
            ESPCOM::print (F ("IP: "), output, espresponse);
        ESPCOM::print (WiFi.localIP().toString().c_str(), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"gw\":\""), output, espresponse);
            ESPCOM::print (F ("Gateway: "), output, espresponse);
        ESPCOM::print (WiFi.gatewayIP().toString().c_str(), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"msk\":\""), output, espresponse);
            ESPCOM::print (F ("Mask: "), output, espresponse);
        ESPCOM::print (WiFi.subnetMask().toString().c_str(), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"dns\":\""), output, espresponse);
            ESPCOM::print (F ("DNS: "), output, espresponse);
        ESPCOM::print (WiFi.dnsIP().toString().c_str(), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"disabled_mode\":\""), output, espresponse);
            ESPCOM::print (F ("Disabled Mode: "), output, espresponse);
        ESPCOM::print (F ("AP ("), output, espresponse);
        ESPCOM::print (WiFi.softAPmacAddress().c_str(), output, espresponse);
        if (!plaintext) {
    } else if (WiFi.getMode() == WIFI_AP) {
        if (!plaintext) {
        //get current config
        wifi_ap_config_t apconfig;
        wifi_config_t conf;
        esp_wifi_get_config (WIFI_IF_AP, &conf);
        apconfig.ssid_hidden = conf.ap.ssid_hidden;
        apconfig.authmode = conf.ap.authmode;
        apconfig.max_connection = conf.ap.max_connection;
#else
        struct softap_config apconfig;
        wifi_softap_get_config (&apconfig);
#endif
        if (!plaintext) {
            ESPCOM::print (F ("\"ap_ssid\":\""), output, espresponse);
            ESPCOM::print (F ("SSID: "), output, espresponse);
        ESPCOM::print ( (const char*) conf.ap.ssid, output, espresponse);
#else
        ESPCOM::print ( (const char*) apconfig.ssid, output, espresponse);
#endif
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"ssid_visible\":\""), output, espresponse);
            ESPCOM::print (F ("Visible: "), output, espresponse);
        ESPCOM::print ( (apconfig.ssid_hidden == 0) ? F ("Yes") : F ("No"), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"ssid_authentication\":\""), output, espresponse);
            ESPCOM::print (F ("Authentication: "), output, espresponse);
        if (apconfig.authmode == AUTH_OPEN) {
        } else if (apconfig.authmode == AUTH_WEP) {
            ESPCOM::print (F ("WEP"), output, espresponse);
        } else if (apconfig.authmode == AUTH_WPA_PSK) {
            ESPCOM::print (F ("WPA"), output, espresponse);
        } else if (apconfig.authmode == AUTH_WPA2_PSK) {
            ESPCOM::print (F ("WPA2"), output, espresponse);
            ESPCOM::print (F ("WPA/WPA2"), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"ssid_max_connections\":\""), output, espresponse);
            ESPCOM::print (F ("Max Connections: "), output, espresponse);
        ESPCOM::print (String (apconfig.max_connection).c_str(), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"ssid_dhcp\":\""), output, espresponse);
            ESPCOM::print (F ("DHCP Server: "), output, espresponse);
        tcpip_adapter_dhcps_get_status (TCPIP_ADAPTER_IF_AP, &dhcp_status);
#else
        if (wifi_softap_dhcps_status() == DHCP_STARTED)
#endif
            ESPCOM::print (F ("Started"), output, espresponse);
            ESPCOM::print (F ("Stopped"), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
        ESPCOM::print (WiFi.softAPIP().toString().c_str(), output, espresponse);
        if (!plaintext) {
        tcpip_adapter_ip_info_t ip;
        tcpip_adapter_get_ip_info (TCPIP_ADAPTER_IF_AP, &ip);
#else
        struct ip_info ip;
        wifi_get_ip_info (SOFTAP_IF, &ip);
#endif
        if (!plaintext) {
        ESPCOM::print (IPAddress (ip.gw.addr).toString().c_str(), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
        ESPCOM::print (IPAddress (ip.netmask.addr).toString().c_str(), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
            ESPCOM::print (F ("\"connected_clients\":["), output, espresponse);
            ESPCOM::print (F ("Connected clients: "), output, espresponse);
        int client_counter = 0;
        wifi_sta_list_t station;
        tcpip_adapter_sta_list_t tcpip_sta_list;
        esp_wifi_ap_get_sta_list (&station);
        tcpip_adapter_get_sta_list (&station, &tcpip_sta_list);
#else
        struct station_info * station;
        station = wifi_softap_get_station_info();
#endif
        String stmp = "";
        for (int i = 0; i < station.num; i++) {
#else
        while (station) {
#endif
            if (stmp.length() > 0) {
                if (!plaintext) {
                    stmp += F (",");
                    stmp += F ("\n");
            if (!plaintext) {
                stmp += F ("{\"bssid\":\"");
            //BSSID
            stmp += CONFIG::mac2str (tcpip_sta_list.sta[i].mac);
#else
            stmp += CONFIG::mac2str (station->bssid);
#endif
            if (!plaintext) {
                stmp += F ("\",\"ip\":\"");
                stmp += F (" ");
            //IP
            stmp += IPAddress (tcpip_sta_list.sta[i].ip.addr).toString().c_str();
#else
            stmp += IPAddress ( (const uint8_t *) &station->ip).toString().c_str();
#endif
            if (!plaintext) {
                stmp += F ("\"}");
            //increment counter
            client_counter++;
#else
            //go next record
            station = STAILQ_NEXT (station, next);
        wifi_softap_free_station_info();
#endif
        if (!plaintext) {
            ESPCOM::print (stmp.c_str(), output, espresponse);
            ESPCOM::print (F ("],"), output, espresponse);
            //display number of client
            ESPCOM::println (String (client_counter).c_str(), output, espresponse);
            //display list if any
                ESPCOM::println (stmp.c_str(), output, espresponse);
        if (!plaintext) {
        ESPCOM::print (F (") is disabled"), output, espresponse);
        if (!plaintext) {
    } else if (WiFi.getMode() == WIFI_AP_STA)
        ESPCOM::print (F ("Mixed"), output, espresponse);
        if (!plaintext) {
        if (!plaintext) {
        ESPCOM::println (F (")"), output, espresponse);
        if (!plaintext) {
    } else
        ESPCOM::print ("Wifi Off", output, espresponse);
        if (!plaintext) {
    if (!plaintext)
        ESPCOM::print (F ("\"captive_portal\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("Captive portal: "), output, espresponse);
#ifdef CAPTIVE_PORTAL_FEATURE
    ESPCOM::print (F ("Enabled"), output, espresponse);
#else
#endif
    if (!plaintext)
    } else
    if (!plaintext)
        ESPCOM::print (F ("\"ssdp\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("SSDP: "), output, espresponse);
#ifdef SSDP_FEATURE
#else
#endif
    if (!plaintext)
    } else
    if (!plaintext)
        ESPCOM::print (F ("\"netbios\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("NetBios: "), output, espresponse);
#ifdef NETBIOS_FEATURE
#else
#endif
    if (!plaintext)
    } else
    if (!plaintext)
        ESPCOM::print (F ("\"mdns\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("mDNS: "), output, espresponse);
#ifdef MDNS_FEATURE
#else
#endif
    if (!plaintext)
    } else
    if (!plaintext)
        ESPCOM::print (F ("\"web_update\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("Web Update: "), output, espresponse);
#else
#endif
    if (!plaintext)
    } else
    if (!plaintext)
        ESPCOM::print (F ("\"pin recovery\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("Pin Recovery: "), output, espresponse);
#else
#endif
    if (!plaintext)
    } else
    if (!plaintext)
        ESPCOM::print (F ("\"autentication\":\""), output, espresponse);
    } else
#ifdef AUTHENTICATION_FEATURE
#else
#endif
    if (!plaintext)
    } else
    if (!plaintext)
        ESPCOM::print (F ("\"target_fw\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("Target Firmware: "), output, espresponse);
    ESPCOM::print (CONFIG::GetFirmwareTargetName(), output, espresponse);
    if (!plaintext)
    } else
    //flag M117
    if (!plaintext)
        ESPCOM::print (F ("\"M117_output\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("M117 output: "), output, espresponse);
    if (!CONFIG::is_locked(FLAG_BLOCK_M117))
    } else
    if (!plaintext)
    } else
    if (!plaintext)
        ESPCOM::print (F ("\"Notifications\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("Notifications: "), output, espresponse);
    if (notificationsservice.started())
        ESPCOM::print (notificationsservice.getTypeString(), output, espresponse);
    } else
    if (!plaintext)
    } else
#endif
    //Flag Oled
#ifdef ESP_OLED_FEATURE
    if (!plaintext)
        ESPCOM::print (F ("\"Oled_output\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("Oled output: "), output, espresponse);
    if (!CONFIG::is_locked(FLAG_BLOCK_OLED))
    } else
    if (!plaintext)
    } else
#endif
    //flag serial
    if (!plaintext)
        ESPCOM::print (F ("\"Serial_output\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("Serial output: "), output, espresponse);
    if (!CONFIG::is_locked(FLAG_BLOCK_SERIAL))
    } else
    if (!plaintext)
    } else
#ifdef WS_DATA_FEATURE
    //flag websocket
    if (!plaintext)
        ESPCOM::print (F ("\"Websocket_output\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("Web socket  output: "), output, espresponse);
    if (!CONFIG::is_locked(FLAG_BLOCK_WSOCKET))
    } else
    if (!plaintext)
    } else
#endif
    //flag tcp
    if (!plaintext)
        ESPCOM::print (F ("\"TCP_output\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("TCP output: "), output, espresponse);
    if (!CONFIG::is_locked(FLAG_BLOCK_TCP))
    } else
    if (!plaintext)
    } else
#endif
#ifdef DEBUG_ESP3D
    if (!plaintext)
        ESPCOM::print (F ("\"debug\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("Debug: "), output, espresponse);
    ESPCOM::print (F ("Debug Enabled :"), output, espresponse);
#ifdef DEBUG_OUTPUT_SPIFFS
    ESPCOM::print (F ("SPIFFS"), output, espresponse);
#endif
#ifdef DEBUG_OUTPUT_SD
    ESPCOM::print (F ("SD"), output, espresponse);
#endif
#ifdef DEBUG_OUTPUT_SERIAL
    ESPCOM::print (F ("serial"), output, espresponse);
#endif
#ifdef DEBUG_OUTPUT_TCP
    ESPCOM::print (F ("TCP"), output, espresponse);
#endif
    if (!plaintext)
    } else
#endif
    if (!plaintext)
        ESPCOM::print (F ("\"fw\":\""), output, espresponse);
    } else
        ESPCOM::print (F ("FW version: "), output, espresponse);
    ESPCOM::print (FW_VERSION, output, espresponse);
    ESPCOM::print (" ESP8266/8586", output, espresponse);
#else
    ESPCOM::print (" ESP32", output, espresponse);
#endif
    if (!plaintext)
        ESPCOM::print (F ("\"}"), output, espresponse);
    } else
#ifdef DEBUG_OUTPUT_SOCKET
#if defined(ARDUINO_ARCH_ESP8266)
const char * pathToFileName(const char * path)
    size_t i = 0;
    size_t pos = 0;
    char * p = (char *)path;
    while(*p) {
        i++;
        if(*p == '/' || *p == '\\') {
            pos = i;
        p++;
    return path+pos;
#endif //ARDUINO_ARCH_ESP8266
void log_socket(const char *format, ...){
    if(socket_server){
        char loc_buf[255];
        char * temp = loc_buf;
        va_list arg;
        va_list copy;
        va_start(arg, format);
        va_copy(copy, arg);
        size_t len = vsnprintf(NULL, 0, format, arg);
        va_end(copy);
        if(len >= sizeof(loc_buf)){
            temp = new char[len+1];
            if(temp == NULL) {
                return;
        len = vsnprintf(temp, len+1, format, arg);
        socket_server->sendBIN(ESPCOM::current_socket_id,(uint8_t *)temp,strlen(temp));
        va_end(arg);
        if(len > 255){
            delete[] temp;
#endif
и где ты его взял?
библиотеку недостающую не искал, если 36 строку замаркировать, то компилируется (ESP8266 D1 mini)
//#define USING_AXTLS
#if defined(USING_AXTLS)
#include "WiFiClientSecureAxTLS.h"
. Variables and constants in RAM (global, static), used 34336 / 80192 bytes (42%)
║   SEGMENT  BYTES    DESCRIPTION
╠══ DATA     1512     initialized variables
╠══ RODATA   5304     constants
╚══ BSS      27520    zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 62115 / 65536 bytes (94%)
╠══ ICACHE   32768    reserved space for flash instruction cache
╚══ IRAM     29347    code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 506460 / 1048576 bytes (48%)
╚══ IROM     506460   code in flash
Несколько библиотек найдено для "WebSocketsServer.h"
 Используется: D:\arduino-1.8.19-YA\portable\sketchbook\libraries\arduinoWebSockets-master
Не используется: D:\arduino-1.8.19-YA\portable\sketchbook\libraries\arduinoWebSockets
Используем библиотеку ESP8266WiFi версии 1.0 из папки: D:\arduino-1.8.19-YA\portable\packages\esp8266\hardware\esp8266\3.1.1\libraries\ESP8266WiFi
Используем библиотеку ESP8266mDNS версии 1.2 из папки: D:\arduino-1.8.19-YA\portable\packages\esp8266\hardware\esp8266\3.1.1\libraries\ESP8266mDNS
Используем библиотеку ESP8266WebServer версии 1.0 из папки: D:\arduino-1.8.19-YA\portable\packages\esp8266\hardware\esp8266\3.1.1\libraries\ESP8266WebServer
Используем библиотеку EEPROM версии 1.0 из папки: D:\arduino-1.8.19-YA\portable\packages\esp8266\hardware\esp8266\3.1.1\libraries\EEPROM
Используем библиотеку DNSServer версии 1.1.1 из папки: D:\arduino-1.8.19-YA\portable\packages\esp8266\hardware\esp8266\3.1.1\libraries\DNSServer
Используем библиотеку arduinoWebSockets-master версии 2.3.7 из папки: D:\arduino-1.8.19-YA\portable\sketchbook\libraries\arduinoWebSockets-master
Используем библиотеку ESP8266SSDP версии 1.0 из папки: D:\arduino-1.8.19-YA\portable\packages\esp8266\hardware\esp8266\3.1.1\libraries\ESP8266SSDP
Используем библиотеку Hash версии 1.0 из папки: D:\arduino-1.8.19-YA\portable\packages\esp8266\hardware\esp8266\3.1.1\libraries\Hash
Есть еще прошивка прошивает подключается но пишет,
Error opening: /home.tpl
там же всё написано, ядро 2.5.2 ставь и будет тебе счастье, но на 3.1.1 тоже компилируется, если строку 36 замаркировать
не поленился, поставил это ядро, всё компилируется и работает, по крайней мере на вэбморду по адресу 192.168.0.1 захожу, тут два пункта доступны Flash Filesystem и Firware Update еще объём свободной и занятой памяти показывает
в мониторе порта
M117 Error Wifi AP!
M117 192.168.0.1
M117 New client
Я только начель разбиратса, пока учусь, я скачал скетч для 3д принтера все перепробовал, скетч прошиваетса сеть пояляетса но при подключение к сети пишет не верный пароль.
так исправь на верные ищи поиском (CTRL+F)
Вот в этом и причина заменил пароль и все равно пишет не верный пароль.
а имя точки кто менять будет, см. режим STA
