w25qxx.h
#ifndef _W25QXX_H
#define _W25QXX_H
Author: Nima Askari
WebSite: http://www.github.com/NimaLTD
#include "main.h"
extern SPI_HandleTypeDef hspi3;
//extern UART_HandleTypeDef huart1;
#define DEBUG_UART &huart1
#define W25QXX_SPI_PTR &hspi3
//#define W25QXX_SPI SPI2
#define W25QFLASH_CS_SELECT HAL_GPIO_WritePin(FLASH_CS_GPIO_Port, FLASH_CS_Pin, GPIO_PIN_RESET)
#define W25QFLASH_CS_UNSELECT HAL_GPIO_WritePin(FLASH_CS_GPIO_Port, FLASH_CS_Pin, GPIO_PIN_SET)
#define _W25QXX_USE_FREERTOS 0
#define INIT_DEBUG 0
#define W25_WRITE_DISABLE 0x04
#define W25_WRITE_ENABLE 0x06
#define W25_CHIP_ERASE 0xC7 //0x60
#define W25_SECTOR_ERASE 0x20
#define W25_BLOCK_ERASE 0xD8
#define W25_FAST_READ 0x0B
#define W25_PAGE_PROGRAMM 0x02
#define W25_GET_JEDEC_ID 0x9F
#define W25_READ_STATUS_1 0x05
#define W25_READ_STATUS_2 0x35
#define W25_READ_STATUS_3 0x15
#define W25_WRITE_STATUS_1 0x01
#define W25_WRITE_STATUS_2 0x31
#define W25_WRITE_STATUS_3 0x11
#define W25_READ_UNIQUE_ID 0x4B
typedef enum
W25Q10 = 1,
W25Q20,
W25Q40,
W25Q80,
W25Q16,
W25Q32,
W25Q64,
W25Q128,
W25Q256,
W25Q512,
}W25QXX_ID_t;
typedef struct
W25QXX_ID_t ID;
uint8_t UniqID[8];
uint16_t PageSize;
uint32_t PageCount;
uint32_t SectorSize;
uint32_t SectorCount;
uint32_t BlockSize;
uint32_t BlockCount;
uint32_t CapacityInKiloByte;
uint8_t StatusRegister1;
uint8_t StatusRegister2;
uint8_t StatusRegister3;
uint8_t Lock;
}w25qxx_t;
extern w25qxx_t w25qxx;
// in Page,Sector and block read/write functions, can put 0 to read maximum bytes
uint8_t W25qxx_Init(void);
void W25qxx_EraseChip(void);
void W25qxx_EraseSector(uint32_t SectorAddr);
void W25qxx_EraseBlock(uint32_t BlockAddr);
uint32_t W25qxx_PageToSector(uint32_t PageAddress);
uint32_t W25qxx_PageToBlock(uint32_t PageAddress);
uint32_t W25qxx_SectorToBlock(uint32_t SectorAddress);
uint32_t W25qxx_SectorToPage(uint32_t SectorAddress);
uint32_t W25qxx_BlockToPage(uint32_t BlockAddress);
uint8_t W25qxx_IsEmptyPage(uint32_t Page_Address, uint32_t OffsetInByte);
uint8_t W25qxx_IsEmptySector(uint32_t Sector_Address, uint32_t OffsetInByte);
uint8_t W25qxx_IsEmptyBlock(uint32_t Block_Address, uint32_t OffsetInByte);
void W25qxx_WriteByte(uint8_t byte, uint32_t addr);
void W25qxx_WritePage(uint8_t *pBuffer, uint32_t Page_Address, uint32_t OffsetInByte, uint32_t NumByteToWrite_up_to_PageSize);
void W25qxx_WriteSector(uint8_t *pBuffer, uint32_t Sector_Address, uint32_t OffsetInByte, uint32_t NumByteToWrite_up_to_SectorSize);
void W25qxx_WriteBlock(uint8_t* pBuffer, uint32_t Block_Address, uint32_t OffsetInByte, uint32_t NumByteToWrite_up_to_BlockSize);
void W25qxx_ReadByte(uint8_t *pBuffer, uint32_t Bytes_Address);
void W25qxx_ReadBytes(uint8_t *pBuffer, uint32_t ReadAddr, uint32_t NumByteToRead);
void W25qxx_ReadPage(uint8_t *pBuffer, uint32_t Page_Address, uint32_t OffsetInByte, uint32_t NumByteToRead_up_to_PageSize);
void W25qxx_ReadSector(uint8_t *pBuffer, uint32_t Sector_Address, uint32_t OffsetInByte, uint32_t NumByteToRead_up_to_SectorSize);
void W25qxx_ReadBlock(uint8_t *pBuffer, uint32_t Block_Address, uint32_t OffsetInByte,uint32_t NumByteToRead_up_to_BlockSize);
uint8_t W25qxx_Spi(uint8_t Data);
#endif
w25qxx.c
#include "w25qxx.h"
#if (INIT_DEBUG == 1)
#include "string.h"
#include "stdio.h"
char buf[64] = {0,};
#endif
#define W25QXX_DUMMY_BYTE 0xA5
w25qxx_t w25qxx;
#if (_W25QXX_USE_FREERTOS == 1)
#define W25qxx_Delay(delay) osDelay(delay)
#include "cmsis_os.h"
#else
#define W25qxx_Delay(delay) HAL_Delay(delay)
#endif
uint8_t ret;
HAL_SPI_TransmitReceive(W25QXX_SPI_PTR, &Data, &ret, 1, 100); // spi2
return ret;
uint32_t W25qxx_ReadID(void)
uint32_t Temp = 0, Temp0 = 0, Temp1 = 0, Temp2 = 0;
W25QFLASH_CS_SELECT;
W25qxx_Spi(W25_GET_JEDEC_ID);
Temp0 = W25qxx_Spi(W25QXX_DUMMY_BYTE);
Temp1 = W25qxx_Spi(W25QXX_DUMMY_BYTE);
Temp2 = W25qxx_Spi(W25QXX_DUMMY_BYTE);
W25QFLASH_CS_UNSELECT;
Temp = (Temp0 << 16) | (Temp1 << 8) | Temp2;
return Temp;
/*void W25qxx_ReadUniqID(void)
W25qxx_Spi(W25_READ_UNIQUE_ID);
for(uint8_t i = 0; i < 4; i++)
for(uint8_t i = 0; i < 8; i++)
w25qxx.UniqID[i] = W25qxx_Spi(W25QXX_DUMMY_BYTE);
void W25qxx_WriteEnable(void)
W25qxx_Spi(W25_WRITE_ENABLE);
W25qxx_Delay(1);
void W25qxx_WriteDisable(void)
W25qxx_Spi(W25_WRITE_DISABLE);
W25qxx_Delay(1);
/*uint8_t W25qxx_ReadStatusRegister(uint8_t SelectStatusRegister_1_2_3)
uint8_t status=0;
if(SelectStatusRegister_1_2_3 == 1)
W25qxx_Spi(W25_READ_STATUS_1);
status = W25qxx_Spi(W25QXX_DUMMY_BYTE);
w25qxx.StatusRegister1 = status;
else if(SelectStatusRegister_1_2_3 == 2)
W25qxx_Spi(W25_READ_STATUS_2);
w25qxx.StatusRegister2 = status;
W25qxx_Spi(W25_READ_STATUS_3);
w25qxx.StatusRegister3 = status;
return status;
/*void W25qxx_WriteStatusRegister(uint8_t SelectStatusRegister_1_2_3, uint8_t Data)
W25qxx_Spi(W25_WRITE_STATUS_1);
w25qxx.StatusRegister1 = Data;
W25qxx_Spi(W25_WRITE_STATUS_2);
w25qxx.StatusRegister2 = Data;
W25qxx_Spi(W25_WRITE_STATUS_3);
w25qxx.StatusRegister3 = Data;
W25qxx_Spi(Data);
void W25qxx_WaitForWriteEnd(void)
W25qxx_Delay(1);
do{
w25qxx.StatusRegister1 = W25qxx_Spi(W25QXX_DUMMY_BYTE);
W25qxx_Delay(1);
while((w25qxx.StatusRegister1 & 0x01) == 0x01);
w25qxx.Lock = 1;
while(HAL_GetTick() < 100)
W25qxx_Delay(1);
W25qxx_Delay(100);
uint32_t id;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Init Begin...\n", 14, 1000);
#endif
id = W25qxx_ReadID();
snprintf(buf, 64, "ID:0x%lX\n", id);
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)buf, strlen(buf), 1000);
#endif
switch(id & 0x0000FFFF)
case 0x401A: // w25q512
w25qxx.ID = W25Q512;
w25qxx.BlockCount = 1024;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q512\n", 14, 1000);
#endif
case 0x4019: // w25q256
w25qxx.ID = W25Q256;
w25qxx.BlockCount = 512;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q256\n", 14, 1000);
#endif
case 0x4018: // w25q128
w25qxx.ID = W25Q128;
w25qxx.BlockCount = 256;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q128\n", 14, 1000);
#endif
case 0x4017: // w25q64
w25qxx.ID = W25Q64;
w25qxx.BlockCount = 128;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q64\n", 13, 1000);
#endif
case 0x4016: // w25q32
w25qxx.ID = W25Q32;
w25qxx.BlockCount = 64;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q32\n", 13, 1000);
#endif
case 0x4015: // w25q16
w25qxx.ID = W25Q16;
w25qxx.BlockCount = 32;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q16\n", 13, 1000);
#endif
case 0x4014: // w25q80
w25qxx.ID = W25Q80;
w25qxx.BlockCount = 16;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q80\n", 13, 1000);
#endif
case 0x4013: // w25q40
w25qxx.ID = W25Q40;
w25qxx.BlockCount = 8;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q40\n", 13, 1000);
#endif
case 0x4012: // w25q20
w25qxx.ID = W25Q20;
w25qxx.BlockCount = 4;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q20\n", 13, 1000);
#endif
case 0x4011: // w25q10
w25qxx.ID = W25Q10;
w25qxx.BlockCount = 2;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25q10\n", 13, 1000);
#endif
case 0x3017: // w25x64
//w25qxx.ID = W25Q64;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25x64\n", 13, 1000);
#endif
case 0x3016: // w25x32
//w25qxx.ID = W25Q32;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25x32\n", 13, 1000);
#endif
case 0x3015: // w25q16
//w25qxx.ID = W25Q16;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25x16\n", 13, 1000);
#endif
case 0x3014: // w25x80
//w25qxx.ID = W25Q80;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25x80\n", 13, 1000);
#endif
case 0x3013: // w25x40
//w25qxx.ID = W25Q40;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25x40\n", 13, 1000);
#endif
case 0x3012: // w25x20
//w25qxx.ID = W25Q20;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25x20\n", 13, 1000);
#endif
case 0x3011: // w25x10
//w25qxx.ID = W25Q10;
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Chip: w25x10\n", 13, 1000);
#endif
default:
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Unknown ID\n", 11, 1000);
#endif
w25qxx.Lock = 0;
return 0;
w25qxx.PageSize = 256;
w25qxx.SectorSize = 0x1000;
w25qxx.SectorCount = w25qxx.BlockCount * 16;
w25qxx.PageCount = (w25qxx.SectorCount * w25qxx.SectorSize) / w25qxx.PageSize;
w25qxx.BlockSize = w25qxx.SectorSize * 16;
w25qxx.CapacityInKiloByte = (w25qxx.SectorCount * w25qxx.SectorSize) / 1024;
//W25qxx_ReadUniqID();
//W25qxx_ReadStatusRegister(1);
//W25qxx_ReadStatusRegister(2);
//W25qxx_ReadStatusRegister(3);
snprintf(buf, 64, "Page Size: %d Bytes\n", w25qxx.PageSize);
snprintf(buf, 64, "Page Count: %lu\n", w25qxx.PageCount);
snprintf(buf, 64, "Sector Size: %lu Bytes\n", w25qxx.SectorSize);
snprintf(buf, 64, "Sector Count: %lu\n", w25qxx.SectorCount);
snprintf(buf, 64, "Block Size: %lu Bytes\n", w25qxx.BlockSize);
snprintf(buf, 64, "Block Count: %lu\n", w25qxx.BlockCount);
snprintf(buf, 64, "Capacity: %lu KBytes\n", w25qxx.CapacityInKiloByte);
HAL_UART_Transmit(DEBUG_UART, (uint8_t*)"Init Done\n", 10, 1000);
#endif
w25qxx.Lock = 0;
return 1;
while(w25qxx.Lock == 1)
W25qxx_Delay(1);
w25qxx.Lock = 1;
W25qxx_WriteEnable();
W25qxx_Spi(W25_CHIP_ERASE);
W25qxx_WaitForWriteEnd();
W25qxx_Delay(10);
w25qxx.Lock = 0;
W25qxx_Delay(1);
w25qxx.Lock = 1;
SectorAddr = SectorAddr * w25qxx.SectorSize;
W25qxx_Spi(W25_SECTOR_ERASE);
if(w25qxx.ID >= W25Q256)
W25qxx_Spi((SectorAddr & 0xFF000000) >> 24);
W25qxx_Spi((SectorAddr & 0xFF0000) >> 16);
W25qxx_Spi((SectorAddr & 0xFF00) >> 8);
W25qxx_Spi(SectorAddr & 0xFF);
W25qxx_Delay(1);
w25qxx.Lock = 0;
W25qxx_Delay(1);
w25qxx.Lock = 1;
BlockAddr = BlockAddr * w25qxx.SectorSize * 16;
W25qxx_Spi(W25_BLOCK_ERASE);
if(w25qxx.ID>=W25Q256)
W25qxx_Spi((BlockAddr & 0xFF000000) >> 24);
W25qxx_Spi((BlockAddr & 0xFF0000) >> 16);
W25qxx_Spi((BlockAddr & 0xFF00) >> 8);
W25qxx_Spi(BlockAddr & 0xFF);
W25qxx_Delay(1);
w25qxx.Lock = 0;
return((PageAddress * w25qxx.PageSize) / w25qxx.SectorSize);
return((PageAddress * w25qxx.PageSize) / w25qxx.BlockSize);
return((SectorAddress * w25qxx.SectorSize) / w25qxx.BlockSize);
return(SectorAddress * w25qxx.SectorSize) / w25qxx.PageSize;
return (BlockAddress * w25qxx.BlockSize) / w25qxx.PageSize;
W25qxx_Delay(1);
w25qxx.Lock = 1;
uint8_t pBuffer[256] = {0,};
uint32_t WorkAddress = 0;
uint16_t size = 0;
size = w25qxx.PageSize - OffsetInByte;
WorkAddress = (OffsetInByte + Page_Address * w25qxx.PageSize);
W25qxx_Spi(W25_FAST_READ);
W25qxx_Spi((WorkAddress & 0xFF000000) >> 24);
W25qxx_Spi((WorkAddress & 0xFF0000) >> 16);
W25qxx_Spi((WorkAddress & 0xFF00) >> 8);
W25qxx_Spi(WorkAddress & 0xFF);
W25qxx_Spi(0);
HAL_SPI_Receive(W25QXX_SPI_PTR, pBuffer, size, 100);
for(uint16_t i = 0; i < size; i++)
if(pBuffer[i] != 0xFF)
w25qxx.Lock = 0;
return 0;
w25qxx.Lock = 0;
return 1;
W25qxx_Delay(1);
w25qxx.Lock = 1;
uint16_t s_buf = 256;
uint16_t size = 0;
size = w25qxx.SectorSize - OffsetInByte;
WorkAddress = (OffsetInByte + Sector_Address * w25qxx.SectorSize);
//char buf2[64] = {0,};
//snprintf(buf2, 64, "SIZE %d \n", size);
//HAL_UART_Transmit(&huart1, (uint8_t*)buf2, strlen(buf2), 100);
uint16_t cikl = size / 256;
uint16_t cikl2 = size % 256;
uint16_t count_cikle = 0;
if(size <= 256)
count_cikle = 1;
//HAL_UART_Transmit(&huart1, (uint8_t*)"1\n", 2, 100);
else if(cikl2 == 0)
count_cikle = cikl;
//HAL_UART_Transmit(&huart1, (uint8_t*)"2\n", 2, 100);
count_cikle = cikl + 1;
//HAL_UART_Transmit(&huart1, (uint8_t*)"3\n", 2, 100);
for(uint16_t i = 0; i < count_cikle; i++)
W25qxx_Spi(0);
if(size < 256) s_buf = size;
//snprintf(buf2, 64, "RECIV %d %d %d %lu\n", size, s_buf, i, WorkAddress);
HAL_SPI_Receive(W25QXX_SPI_PTR, pBuffer, s_buf, 100);
for(uint16_t i = 0; i < s_buf; i++)
w25qxx.Lock = 0;
return 0;
size = size - 256;
WorkAddress = WorkAddress + 256;
w25qxx.Lock = 0;
return 1;
W25qxx_Delay(1);
w25qxx.Lock = 1;
uint32_t size = 0;
size = w25qxx.BlockSize - OffsetInByte;
WorkAddress = (OffsetInByte + Block_Address * w25qxx.BlockSize);
//snprintf(buf2, 64, "SIZEB %lu \n", size);
if(size <= 256)
count_cikle = 1;
else if(cikl2 == 0)
count_cikle = cikl;
W25qxx_Spi(0);
//snprintf(buf2, 64, "RECIVB %lu %d %d %lu\n", size, s_buf, i, WorkAddress);
w25qxx.Lock = 0;
return 0;
size = size - 256;
w25qxx.Lock = 0;
return 1;
W25qxx_Delay(1);
w25qxx.Lock = 1;
W25qxx_Spi(W25_PAGE_PROGRAMM);
W25qxx_Spi((addr & 0xFF000000) >> 24);
W25qxx_Spi((addr & 0xFF0000) >> 16);
W25qxx_Spi((addr & 0xFF00) >> 8);
W25qxx_Spi(addr & 0xFF);
W25qxx_Spi(byte);
w25qxx.Lock = 0;
W25qxx_Delay(1);
w25qxx.Lock = 1;
if(((NumByteToWrite_up_to_PageSize + OffsetInByte) > w25qxx.PageSize) || (NumByteToWrite_up_to_PageSize == 0))
NumByteToWrite_up_to_PageSize = w25qxx.PageSize - OffsetInByte;
if((OffsetInByte + NumByteToWrite_up_to_PageSize) > w25qxx.PageSize)
Page_Address = (Page_Address * w25qxx.PageSize) + OffsetInByte;
W25qxx_Spi((Page_Address & 0xFF000000) >> 24);
W25qxx_Spi((Page_Address & 0xFF0000) >> 16);
W25qxx_Spi((Page_Address & 0xFF00) >> 8);
W25qxx_Spi(Page_Address & 0xFF);
HAL_SPI_Transmit(W25QXX_SPI_PTR, pBuffer, NumByteToWrite_up_to_PageSize, 100);
W25qxx_Delay(1);
w25qxx.Lock = 0;
if((NumByteToWrite_up_to_SectorSize > w25qxx.SectorSize) || (NumByteToWrite_up_to_SectorSize == 0))
NumByteToWrite_up_to_SectorSize = w25qxx.SectorSize;
uint32_t StartPage;
int32_t BytesToWrite;
uint32_t LocalOffset;
if((OffsetInByte + NumByteToWrite_up_to_SectorSize) > w25qxx.SectorSize)
BytesToWrite = w25qxx.SectorSize - OffsetInByte;
BytesToWrite = NumByteToWrite_up_to_SectorSize;
StartPage = W25qxx_SectorToPage(Sector_Address) + (OffsetInByte / w25qxx.PageSize);
LocalOffset = OffsetInByte % w25qxx.PageSize;
do
W25qxx_WritePage(pBuffer, StartPage, LocalOffset, BytesToWrite);
StartPage++;
BytesToWrite -= w25qxx.PageSize - LocalOffset;
//pBuffer += w25qxx.PageSize;
pBuffer += w25qxx.PageSize - LocalOffset;
LocalOffset = 0;
while(BytesToWrite > 0);
if((NumByteToWrite_up_to_BlockSize>w25qxx.BlockSize)||(NumByteToWrite_up_to_BlockSize == 0))
NumByteToWrite_up_to_BlockSize=w25qxx.BlockSize;
uint32_t StartPage;
if((OffsetInByte+NumByteToWrite_up_to_BlockSize) > w25qxx.BlockSize)
BytesToWrite = w25qxx.BlockSize - OffsetInByte;
BytesToWrite = NumByteToWrite_up_to_BlockSize;
StartPage = W25qxx_BlockToPage(Block_Address)+(OffsetInByte/w25qxx.PageSize);
LocalOffset = OffsetInByte%w25qxx.PageSize;
do
W25qxx_WritePage(pBuffer,StartPage,LocalOffset,BytesToWrite);
StartPage++;
LocalOffset = 0;
while(w25qxx.Lock==1)
W25qxx_Delay(1);
w25qxx.Lock=1;
W25qxx_Spi((Bytes_Address & 0xFF000000) >> 24);
W25qxx_Spi((Bytes_Address & 0xFF0000) >> 16);
W25qxx_Spi((Bytes_Address& 0xFF00) >> 8);
W25qxx_Spi(Bytes_Address & 0xFF);
W25qxx_Spi(0);
*pBuffer = W25qxx_Spi(W25QXX_DUMMY_BYTE);
w25qxx.Lock = 0;
void W25qxx_ReadBytes(uint8_t* pBuffer, uint32_t ReadAddr, uint32_t NumByteToRead)
W25qxx_Delay(1);
w25qxx.Lock = 1;
W25qxx_Spi((ReadAddr & 0xFF000000) >> 24);
W25qxx_Spi((ReadAddr & 0xFF0000) >> 16);
W25qxx_Spi((ReadAddr& 0xFF00) >> 8);
W25qxx_Spi(ReadAddr & 0xFF);
W25qxx_Spi(0);
HAL_SPI_Receive(W25QXX_SPI_PTR, pBuffer, NumByteToRead, 2000);
/*uint16_t i = 0;
while(NumByteToRead > 0U)
//while(!(W25QXX_SPI->SR & SPI_SR_TXE));
W25QXX_SPI->DR = 0;
while(!(W25QXX_SPI->SR & SPI_SR_RXNE));
pBuffer[i++] = W25QXX_SPI->DR;
NumByteToRead--;
W25qxx_Delay(1);
w25qxx.Lock = 0;
W25qxx_Delay(1);
w25qxx.Lock = 1;
if((NumByteToRead_up_to_PageSize>w25qxx.PageSize) || (NumByteToRead_up_to_PageSize==0))
NumByteToRead_up_to_PageSize=w25qxx.PageSize;
if((OffsetInByte+NumByteToRead_up_to_PageSize) > w25qxx.PageSize)
NumByteToRead_up_to_PageSize = w25qxx.PageSize - OffsetInByte;
Page_Address = Page_Address * w25qxx.PageSize + OffsetInByte;
W25qxx_Spi((Page_Address& 0xFF00) >> 8);
W25qxx_Spi(0);
HAL_SPI_Receive(W25QXX_SPI_PTR, pBuffer, NumByteToRead_up_to_PageSize, 100);
/*uint16_t i = 0;
while(NumByteToRead_up_to_PageSize > 0U)
W25QXX_SPI->DR = 0;
NumByteToRead_up_to_PageSize--;
W25qxx_Delay(1);
w25qxx.Lock=0;
void W25qxx_ReadSector(uint8_t *pBuffer,uint32_t Sector_Address,uint32_t OffsetInByte,uint32_t NumByteToRead_up_to_SectorSize)
if((NumByteToRead_up_to_SectorSize>w25qxx.SectorSize) || (NumByteToRead_up_to_SectorSize==0))
NumByteToRead_up_to_SectorSize=w25qxx.SectorSize;
uint32_t StartPage;
int32_t BytesToRead;
if((OffsetInByte + NumByteToRead_up_to_SectorSize) > w25qxx.SectorSize)
BytesToRead = w25qxx.SectorSize - OffsetInByte;
BytesToRead = NumByteToRead_up_to_SectorSize;
do
W25qxx_ReadPage(pBuffer, StartPage, LocalOffset, BytesToRead);
StartPage++;
BytesToRead -= w25qxx.PageSize-LocalOffset;
//pBuffer+=w25qxx.PageSize;
LocalOffset = 0;
while(BytesToRead > 0);
void W25qxx_ReadBlock(uint8_t *pBuffer, uint32_t Block_Address, uint32_t OffsetInByte, uint32_t NumByteToRead_up_to_BlockSize)
if((NumByteToRead_up_to_BlockSize > w25qxx.BlockSize) || (NumByteToRead_up_to_BlockSize == 0))
NumByteToRead_up_to_BlockSize = w25qxx.BlockSize;
uint32_t StartPage;
if((OffsetInByte+NumByteToRead_up_to_BlockSize) > w25qxx.BlockSize)
BytesToRead = w25qxx.BlockSize-OffsetInByte;
BytesToRead = NumByteToRead_up_to_BlockSize;
StartPage = W25qxx_BlockToPage(Block_Address) + (OffsetInByte / w25qxx.PageSize);
do
W25qxx_ReadPage(pBuffer,StartPage,LocalOffset,BytesToRead);
StartPage++;
BytesToRead-=w25qxx.PageSize-LocalOffset;
LocalOffset=0;
