Спасибо!
Скетч для wemos.
// FastLED: Control (5v) WS2812 RGB LED Modules in a strip
// Uses FastLED's library: https://github.com/FastLED/FastLED
// Wiring info: https://learn.adafruit.com/digital-led-strip/wiring
// LED -> Arduino
// 5V -> 5V
// GND -> GND
// DIN -> Digital 2
// LED library includes
#include <FastLED.h>
#define DATA_PIN D0
// lights config
#define NUM_LEDS 100
CRGB leds[NUM_LEDS];
// interval between hardware updates
static unsigned long lastLEDTime = 0;
const long ledInterval = 16;
// VL53L1X: Read distance from sensor in mm
// Uses Polulu's library: https://github.com/pololu/vl53l1x-arduino
// Wiring info: https://learn.adafruit.com/adafruit-vl53l0x-micro-lidar-distance-sensor-breakout/arduino-code
// Sensor -> Arduino
// VIN -> VIN
// GND -> GND
// SCL -> SCL (aka A5)
// SDA -> SDA (aka A4)
// sensor library includes
#include <Wire.h>
#include <VL53L0X.h>
// sensor object
VL53L0X sensor;
int sensorMM = 0;
static unsigned long lastSensorTime = 0;
const long sensorInterval = 100;
// Main app:
// Read VL53L1X data and use it to light up WS2812 LEDs
unsigned long now;
initSerial();
initSensor();
initLEDs();
now = millis(); // get durrent time. usually a single device interface would use something like `delay(100)`
updateSensor();
updateLEDs();
// Make serial connection for logging to Serial Monitor
void initSerial() {
// Connect to serial so we can watch debug values
Serial.setTimeout(0);
Serial.println("<Arduino is ready>");
// Sensor communication
void initSensor() {
Serial.println("mVL53L1X initializing");
Wire.begin();
Wire.setClock(400000); // use 400 kHz I2C
// Attempt to initialize the sensor library
sensor.setTimeout(500);
if (!sensor.init()) {
Serial.println(F("Failed to detect and initialize VL53L1X"));
while (1);
Serial.println("VL53L1X API Started");
// Configure the sensor
//sensor.setDistanceMode(VL53L0X::Long);
sensor.setMeasurementTimingBudget(50000);
sensor.startContinuous(50);
Serial.println("VL53L1X API Configured");
void updateSensor() {
// set delay between updates
if (now < lastSensorTime + sensorInterval) return;
lastSensorTime = now;
int distanceMM = sensor.readRangeContinuousMillimeters();
if (sensor.timeoutOccurred()) {
Serial.println(F("VL53L0X error: Timeout"));
Serial.println("Dist (mm): "+String(distanceMM));
sensorMM = distanceMM;
// LED communication
void initLEDs() {
FastLED.addLeds<WS2812B, DATA_PIN>(leds, NUM_LEDS);
void updateLEDs() {
if (now < lastLEDTime + ledInterval) return;
lastLEDTime = now;
// update all LEDs every frame
int numToLight = sensorMM / 10;
for(int i = 0; i < NUM_LEDS; i++) {
// are we below threshold or not?
if(i == numToLight) {
leds[i] = CRGB(10, 10, 10); // CRGB::White;
leds[i] = CRGB::Black;
// Show the leds (only one of which is set to white, from above)
FastLED.show();
Спасибо, со скетчем для WS2812 у меня нет проблем.
кому не слабо изготовить калькулятор больших чисел на ардуино ?))) ну если все делали уже, и кодом сможете поделится было бы шикарно)))
вам в платный раздел видимо)
Расчётная сумма будет сжата…до 1 бита…чёрно-белого.
Примитивно, ещё много лет назад на 8и битных процессорах писали, включите уже мозг и почитайте двоичную арифметику.
За минусом комисси за перевод)) Вы эту свою банальную арифметику не путайте с банковской математикой ![]()
господа, я этаки и не поняла, мы шо, в минусе?
это 0 или 1?
Смотря с какой ты стороны)) И смотря кто банкомет
все…
кто то стуканул…
пришла коса, расходимся…
Будем уходить - прирежу Штехеля! (С)
ой мужики, весело с вами, третий час не могу вентилятор перебрать, то наливай, то читай, то отвечай
Ты, это… вентилятор сейчас не трогай. Наливай, отвечай, @би катушечников… Главное железки не попалить в ажитации
так, яж, это…
катушкой не пользуюсь, кристаллами фронты не заваливаю, все по старинке..
может прокатит, как думаешь)
Может и прокатит. Если управдом не спалит)) Колбаса где?
что за колбаса (если не шутка)?
Какие шутки, вотка есть, чернушка присутствует, а колбаски нет
Вооот! А я сейчас блинов нафигачил в 2 сковородки штук 100. Фото не буду тут постить, это не гуманно. Масленка вроде, или как то так сейчас. Тоже налью себе
