Какая деталь на обратной стороне NANO?
ну давай код мигалки :grinning:
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://docs.arduino.cc/hardware/
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
https://docs.arduino.cc/built-in-examples/basics/Blink/
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
$27=1.000
$30=1000
$31=0
$32=0
$100=2147483.648
$101=250.000
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.003
$132=200.000
ok
Это SERIAL MONITOR выдал
Нихрена себе.
Джентльмены, всем спасибо)
не стОит оно того-за 150 рублей так страдать)
__:man_facepalming: __
Во-во.))
От GRBL останки в контролёре.
На ПИК когда давал +12 на ногу то порт выгорал а сам был живой.
