#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
/////////////////// SETTINGS /////////////////////////////
// Wi-Fi
const char* ssid = "******";
const char password = “********”;
// MQTT
const char* mqtt_server = “.wqtt.ru";
const int mqtt_port = 13065;
const char* mqtt_user = "******”;
const char* mqtt_password = “**********”;
// SENSOR
const int sending_period = 5;
const bool retain_flag = false;
const char* temperature_topic = “bme280/temperature”;
const char* humidity_topic = “bme280/humidity”;
const char* pressure_topic = “bme280/pressure”;
WiFiClient espClient;
PubSubClient client(espClient);
Adafruit_BME280 bme;
uint32_t tmr1;
void setup_wifi() {
delay(10);
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
delay(500);
Serial.print(“.”);
Serial.println(“”);
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
void reconnect() {
while (!client.connected()) {
Serial.print(“Attempting MQTT connection…”);
String clientId = “ESP8266-” + WiFi.macAddress();
if (client.connect(clientId.c_str(), mqtt_user, mqtt_password) ) {
Serial.println(“connected”);
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000);
void sendData() {
float temperature = bme.readTemperature();
float pressure = bme.readPressure() / 133.3224;
float humidity = bme.readHumidity();
Serial.print(“Temperature = “);
Serial.print(temperature);
Serial.println(” °C”);
Serial.print(“Pressure = “);
Serial.print(pressure);
Serial.println(” mm”);
Serial.print(“Humidity = “);
Serial.print(humidity);
Serial.println(” %”);
client.publish(temperature_topic, String(temperature).c_str(), retain_flag);
client.publish(humidity_topic, String(humidity).c_str(), retain_flag);
client.publish(pressure_topic, String(pressure).c_str(), retain_flag);
if (!bme.begin(0x76)) {
Serial.println(“Could not find a valid BME280 sensor, check wiring, address, sensor ID!”);
while (1){
delay(10);
setup_wifi();
client.setServer(mqtt_server, mqtt_port);
if (!client.connected()) {
reconnect();
client.loop();
if (millis() - tmr1 >= (sending_period * 1000)) {
tmr1 = millis();
sendData();
на какие пины вешать BME280 Я собираю на ESP_01
