Помогите с датчиком отпечатка пальца
Подключил датчик FPM10a на Arduino UNO
вот такая схема:
монитор порта выдает
Did not find fingerprint sensor
Он сенсор не видит вообще
скетч:
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
uint8_t id;
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit Fingerprint sensor enrollment");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
  Serial.print(F("Security level: ")); Serial.println(finger.security_level);
  Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
uint8_t readnumber(void) {
  uint8_t num = 0;
  while (num == 0) {
    while (! Serial.available());
    num = Serial.parseInt();
  return num;
void loop()                     // run over and over again
  Serial.println("Ready to enroll a fingerprint!");
  Serial.println("Please type in the ID # (from 1 to 127) you want to save this finger as...");
  id = readnumber();
  if (id == 0) {// ID #0 not allowed, try again!
     return;
  Serial.print("Enrolling ID #");
  Serial.println(id);
  while (!  getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
  int p = -1;
  Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println(".");
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
    default:
      Serial.println("Unknown error");
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  Serial.print("ID "); Serial.println(id);
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      Serial.print(".");
    default:
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  Serial.print("Creating model for #");  Serial.println(id);
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
    return p;
  return true;
Попробуйте поменять местами провода на 2 и 3 пинах платы Arduino …
датчик перестает работать, если если зелёный провод в 3ий пин вставить
На датчике эти провода как подписаны?
RX и TX
Подключать нужно крест на крест: RX <-> TX, TX <-> RX
SoftwareSerial инициализирован на пинах 2 и 3 (rx и tx), соответственно к пину 2 нужно подключать вывод TX датчика, к пину 3 - вывод RX. Подключено так?
Да, если подключить наоборот датчик перестает работать(светиться)
https://www.youtube.com/watch?v=V4meUB5qhnw
“Во всех руководствах написано, что используется белый и зеленый, но это не так, данный девайс подключается по белому и желтому”
И еще, питание у него от 3,3 вольт
От 3.3 он у меня не питается, но с проводами попробую
Капец, все провода перепробовал, 3 скетча скомпилировал и ничего :frowning:
Видимо не зря он попал на Авито …
Не начинайте опять, датчик рабочий, он светится
Это лампочка светится. А сам датчик почему-то не обнаруживается. Кстати, может быть потому, что его подключали на 5 вольт вместо 3,3
Если я подключаю его на 3.3 то датчик тухнет
220 тогда надо !
Смирись, датчик скорее мертвый, чем живой. Во всех описаниях говорится, что питание у него 3,3В
Интересно, а я наоборот встречал, что надо 3.6 - 6В
Вот это делать опасно
Хм, а я чет думал, что он по прежнему мучает датчик из этой темы, а там он писал, что датчик AS608. Вот для того только 3,3В
Да, похоже уже “мучает” другой датчик))
P.S. Вот отличное описание с примерами
http://repository.umy.ac.id/bitstream/handle/123456789/22709/FPM10A.pdf?sequence=13&isAllowed=y
