Строка 74, оператор if игнорируется, сразу начинается выполнение функции после него в бесконечном цикле.
Компилируется без ошибок.
Подскажет кто?
[code]
// Demo: Dual CAN-BUS Shields, Data Pass-through
// Written by: Cory J. Fowler
// January 31st 2014
// This examples the ability of this library to support more than one MCP2515 based CAN interface.
#include <mcp_can.h>
#include <SPI.h>
unsigned long rxId;
byte len;
byte rxBuf[8];
byte txBuf0[] = {0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55};
byte txBuf1[] = {0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA};
char msgString[128]; // Array to store serial string
MCP_CAN CAN0(2); // CAN0 interface usins CS on digital pin 2
MCP_CAN CAN1(3); // CAN1 interface using CS on digital pin 3
#define CAN0_INT 8 //define interrupt pin for CAN0 recieve buffer
#define CAN1_INT 9 //define interrupt pin for CAN1 recieve buffer
pinMode(CAN0_INT, INPUT_PULLUP);
pinMode(CAN1_INT, INPUT_PULLUP);
// init CAN0 bus, baudrate: 250k@16MHz
if (CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK) {
Serial.print("CAN0: Init OK!\r\n");
CAN0.setMode(MCP_NORMAL);
} else Serial.print("CAN0: Init Fail!!!\r\n");
// init CAN1 bus, baudrate: 250k@16MHz
if (CAN1.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK) {
Serial.print("CAN1: Init OK!\r\n");
CAN1.setMode(MCP_NORMAL);
} else Serial.print("CAN1: Init Fail!!!\r\n");
SPI.setClockDivider(SPI_CLOCK_DIV2); // Set SPI to run at 8MHz (16MHz / 2 = 8 MHz)
CAN0.sendMsgBuf(0x1000000, 1, 8, txBuf0);
CAN1.sendMsgBuf(0x1000001, 1, 8, txBuf1);
if (!digitalRead(CAN0_INT)) { // If interrupt pin is low, read CAN0 receive buffer
Serial.println("CAN0 receive buffer:");
CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
if ((rxId & 0x80000000) == 0x80000000) // Determine if ID is standard (11 bits) or extended (29 bits)
sprintf(msgString, "Extended ID: 0x%.8lX DLC: %1d Data:", (rxId & 0x1FFFFFFF), len);
sprintf(msgString, "Standard ID: 0x%.3lX DLC: %1d Data:", rxId, len);
Serial.print(msgString);
if ((rxId & 0x40000000) == 0x40000000) { // Determine if message is a remote request frame.
sprintf(msgString, " REMOTE REQUEST FRAME");
for (byte i = 0; i < len; i++) {
sprintf(msgString, " 0x%.2X", rxBuf[i]);
Serial.println();
if (rxId == 0x7DF) // && rxBuf[0] == 0x02 && rxBuf[1] == 0x09 && rxBuf[2] == 0x02);
rxId = 0x7E8;
len = 8;
rxBuf[0] = 0x10;
rxBuf[1] = 0x14;
rxBuf[2] = 0x49;
rxBuf[3] = 0x02;
rxBuf[4] = 0x01;
rxBuf[5] = 0x31;
rxBuf[6] = 0x46;
rxBuf[7] = 0x54;
CAN0.sendMsgBuf(rxId, 0, len, rxBuf); // Immediately send message out CAN0 interface
// if (rxId == 0x7E0 && rxBuf[0] == 0x30);
// byte t = rxBuf[2];
// rxId = 0x7E8;
// len = 8;
// rxBuf[0] = 0x31;
// rxBuf[1] = 0x31;
// rxBuf[2] = 0x31;
// rxBuf[3] = 0x31;
// rxBuf[4] = 0x31;
// rxBuf[5] = 0x31;
// rxBuf[6] = 0x31;
// rxBuf[7] = 0x31;
// delay(t);
// CAN0.sendMsgBuf(rxId, 0, len, rxBuf); // Immediately send message out CAN0 interface
// { rxId = 0x7E8;
// len = 8;
//rxBuf[0] = 0x33;
//rxBuf[1] = 0x33;
//rxBuf[2] = 0x33;
//rxBuf[3] = 0x33;
//rxBuf[4] = 0x33;
//rxBuf[5] = 0x33;
//rxBuf[6] = 0x33;
//rxBuf[7] = 0x33;
//CAN0.sendMsgBuf(rxId, 0, len, rxBuf); // Immediately send message out CAN0 interface
CAN1.sendMsgBuf(rxId, 0, len, rxBuf); // Immediately send message out CAN1 interface
Serial.println();
if (!digitalRead(CAN1_INT)) { // If interrupt pin is low, read CAN1 receive buffer
Serial.println("CAN1 receive buffer:");
CAN1.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
Serial.println();
END FILE
[/code]
