Проблемы с загрузкой скетча
avrdude: Version 6.3-20190619
     System wide configuration file is "C:\Users\2008a\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM3
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 3
     Firmware Version: 4.4
     Vtarget         : 0.3 V
     Varef           : 0.3 V
     Oscillator      : 28.800 kHz
     SCK period      : 3.3 us
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file “C:\Users\2008a\AppData\Local\Temp\arduino_build_443811/sketch_jan20a.ino.hex”
avrdude: writing flash (1626 bytes):
Writing | ################################################## | 100% 0.21s
avrdude: 1626 bytes of flash written
avrdude: verifying flash memory against C:\Users\2008a\AppData\Local\Temp\arduino_build_443811/sketch_jan20a.ino.hex:
avrdude: load data flash data from input file C:\Users\2008a\AppData\Local\Temp\arduino_build_443811/sketch_jan20a.ino.hex:
avrdude: input file C:\Users\2008a\AppData\Local\Temp\arduino_build_443811/sketch_jan20a.ino.hex contains 1626 bytes
avrdude: reading on-chip flash data:
Reading | ##################################Произошла ошибка при загрузке скетча
################ | 100% 0.20s
avrdude: verifying …
avrdude: verification error, first mismatch at byte 0x0000
0x62 != 0x0c
avrdude: verification error; content mismatch
avrdude done. Thank you.
с какой версии IDE?
1.8.19
попробуй блинк залить из примеров
всё то же самое
Ну тогда только Садман41 поможет, он тут дока…
Поведение твоей UNO один в один соответствует имеющейся у меня, но там чип CH340 поддельный, распиновка не соответствует даташиту, проблема ушла после прошивки большого скетча, в памяти более половины, прошивал блинк пока не стала прошиваться без ошибок. IDE 1.8.19 - держим кнопку РЕЗЕТ когда откомпилировалось и начинает заливаться (система остановилась) кнопку отпускаем, повторить, пока не зальётся без ошибок. С утра на своей UNO попытался повторить проблему, шьётся однако )))
Тема была тут
минут 20 этим занимался, не помогает.
остаётся только ждать, пока провод приедет.
ну или плату менять
Странно что сигнатуру читает верно.
А если выбрать другу плату - мега например.
Ругаться будет на сигнатуру ???
И еще может для Iskra плат они свой загрузчик какой написали и с ним надо как то по другому общаться ??? Что там на их сайте пишут по этому вопросу ???
avrdude: ser_open(): can’t open device “\.\COM3”: �������� � �������.
avrdude: ser_drain(): read error: �������� ����������.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: �������� ����������.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
выбранный последовательный порт
не существует или плата не подключена к нему
Никакого собственного загрузчика, общаться так же как и с обычной Arduino Uno
Вот, поймал и на моей плате:
         System wide configuration file is "D:\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM18
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 3
         Firmware Version: 8.0
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         SCK period      : 3.3 us
avrdude: reading input file "C:\Temp\arduino_build_141657/ST7789_graphicstest.ino.hex"
avrdude: writing flash (23096 bytes):
Writing | ################################################## | 100% 4.75s
avrdude: 23096 bytes of flash written
avrdude: verifying flash memory against C:\Temp\arduino_build_141657/ST7789_graphicstest.ino.hex:
avrdude: load data flash data from input file C:\Temp\arduino_build_141657/ST7789_graphicstest.ino.hex:
avrdude: input file C:\Temp\arduino_build_141657/ST7789_graphicstest.ino.hex contains 23096 bytes
Reading | #
avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x48
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x6c
ua6em
Это USB-UART отвалился в процессе
У ТС другая картина
64 строка - иногда считывало почти до конца
А программатора (типа USBasp) или другой ардуины (любой) нету случаем?
всё есть как жеж не есть )))
нету, а если бы был?
А если бы был, то можно попробовать прошить мк по ISP, если шьется - попробовать “перезалить бутлоадер”.
Все гораздо проще, утановите lib-usb поверх вашего com порта с говнуиной :wink:
