Микросхема стоит на его картинке - преобразователь уровней.
This is a library for the ST7789 IPS SPI display.
#include <Adafruit_GFX.h> // Core graphics library by Adafruit
#include <Arduino_ST7789.h> // Hardware-specific library for ST7789 (with or without CS pin)
#include <SPI.h>
#define TFT_DC 12 // RS
#define TFT_RST 13
#define TFT_MOSI 23 // SDA for hardware SPI data pin (all of available pins)
#define TFT_SCLK 18 // SCK for hardware SPI sclk pin (all of available pins)
//Arduino_ST7789 tft = Arduino_ST7789(TFT_DC, TFT_RST); //for display without CS pin
//Arduino_ST7789 tft = Arduino_ST7789(TFT_DC, TFT_RST, TFT_CS); //for display with CS pin
//or you can use software SPI on all available pins (slow)
Arduino_ST7789 tft = Arduino_ST7789(TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK); //for display without CS pin
//Arduino_ST7789 tft = Arduino_ST7789(TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_CS); //for display with CS pin
bool oldState = HIGH;
int showType = 0;
float p = 3.1415926;
void setup(void) {
tft.init(240, 240); // initialize a ST7789 chip, 240x240 pixels
tft.fillScreen(BLACK);
// large block of text
testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", WHITE);
// tft print function
tftPrintTest();
delay(2000);
// a single pixel
tft.drawPixel(tft.width()/2, tft.height()/2, GREEN);
delay(500);
// line draw test
testlines(YELLOW);
delay(500);
// optimized lines
testfastlines(RED, BLUE);
delay(500);
testdrawrects(GREEN);
delay(500);
testfillrects(YELLOW, MAGENTA);
delay(500);
testfillcircles(10, BLUE);
testdrawcircles(10, WHITE);
delay(500);
testroundrects();
delay(500);
testtriangles();
delay(500);
mediabuttons();
delay(500);
tft.invertDisplay(true);
delay(500);
tft.invertDisplay(false);
delay(500);
void testlines(uint16_t color) {
for (int16_t x=0; x < tft.width(); x+=6) {
tft.drawLine(0, 0, x, tft.height()-1, color);
for (int16_t y=0; y < tft.height(); y+=6) {
tft.drawLine(0, 0, tft.width()-1, y, color);
tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
tft.drawLine(tft.width()-1, 0, 0, y, color);
tft.drawLine(0, tft.height()-1, x, 0, color);
tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
void testdrawtext(char *text, uint16_t color) {
tft.setCursor(0, 0);
tft.setTextColor(color);
tft.setTextWrap(true);
tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
for (int16_t y=0; y < tft.height(); y+=5) {
tft.drawFastHLine(0, y, tft.width(), color1);
for (int16_t x=0; x < tft.width(); x+=5) {
tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
for (int16_t x=tft.width()-1; x > 6; x-=6) {
tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
for (int16_t x=radius; x < tft.width(); x+=radius*2) {
for (int16_t y=radius; y < tft.height(); y+=radius*2) {
tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
for (int16_t x=0; x < tft.width()+radius; x+=radius*2) {
for (int16_t y=0; y < tft.height()+radius; y+=radius*2) {
tft.drawCircle(x, y, radius, color);
void testtriangles() {
int color = 0xF800;
int t;
int w = tft.width()/2;
int x = tft.height()-1;
int y = 0;
int z = tft.width();
for(t = 0 ; t <= 15; t++) {
tft.drawTriangle(w, y, y, x, z, x, color);
x-=4;
y+=4;
z-=4;
color+=100;
void testroundrects() {
int color = 100;
int i;
int t;
for(t = 0 ; t <= 4; t+=1) {
int x = 0;
int y = 0;
int w = tft.width()-2;
int h = tft.height()-2;
for(i = 0 ; i <= 16; i+=1) {
tft.drawRoundRect(x, y, w, h, 5, color);
x+=2;
y+=3;
w-=4;
h-=6;
color+=1100;
color+=100;
void tftPrintTest() {
tft.setTextWrap(false);
tft.setCursor(0, 30);
tft.setTextColor(RED);
tft.setTextSize(1);
tft.println("Hello DSTIKE");
tft.setTextColor(YELLOW);
tft.setTextSize(2);
tft.setTextColor(GREEN);
tft.setTextSize(3);
tft.setTextColor(BLUE);
tft.setTextSize(4);
tft.print(1234.567);
delay(1500);
tft.setTextColor(WHITE);
tft.setTextSize(0);
tft.println("DSTIKE!");
tft.setTextSize(1);
tft.print(p, 6);
tft.println(" Want pi?");
tft.println(" ");
tft.print(8675309, HEX); // print 8,675,309 out in HEX!
tft.println(" Print HEX!");
tft.println(" ");
tft.println("Sketch has been");
tft.println("running for: ");
tft.setTextColor(MAGENTA);
tft.print(millis() / 1000);
tft.print(" seconds.");
void mediabuttons() {
// play
tft.fillRoundRect(25, 10, 78, 60, 8, WHITE);
tft.fillTriangle(42, 20, 42, 60, 90, 40, RED);
delay(500);
// pause
tft.fillRoundRect(25, 90, 78, 60, 8, WHITE);
tft.fillRoundRect(39, 98, 20, 45, 5, GREEN);
tft.fillRoundRect(69, 98, 20, 45, 5, GREEN);
delay(500);
// play color
tft.fillTriangle(42, 20, 42, 60, 90, 40, BLUE);
delay(50);
// pause color
tft.fillRoundRect(39, 98, 20, 45, 5, RED);
tft.fillRoundRect(69, 98, 20, 45, 5, RED);
// play color
tft.fillTriangle(42, 20, 42, 60, 90, 40, GREEN);
tft.setCursor(60, 200);
tft.setTextSize(4);
tft.println("DSTIKE");
Вот, есп32 тестировал. Надо только подставить в строки 11-15 свои выводы платы и в 29 заменить 240,240 на 135,240.
У меня проект на Arduino nano, скачал библиотеку:
Код взял из примера библиотеки:
#include <SPI.h>
#define TFT_DC 8
#define TFT_RST 9
#define TFT_CS 10 // only for displays with CS pin
#define TFT_MOSI 11 // for hardware SPI data pin (all of available pins)
#define TFT_SCLK 13 // for hardware SPI sclk pin (all of available pins)
Не работает
Тоже не работает
Работает.
Почему то на аппаратном SPI только
Adafruit_ST7789 TFT = Adafruit_ST7789(10, 8, 9);
Работает
По Вашим записям соответствует Arduino_ST7789 tft = Arduino_ST7789(8,9,10);
Это нестыковачка с Adafruit_ST7789 TFT = Adafruit_ST7789(10, 8, 9);
Напутали с пинами небось ![]()
Наиболее радикальный метод - переход с последовательного интерфейса на параллельный.
Ну а вообще нужно выяснить, где именно происходят неоптимальности с одной стороны, и используется ли режим аппаратного ускорения, который есть практически во всех цветных дисплеях. Для начала посмотреть, как именно выводится символ.
Ну и грубые оценки:
Берется символ 5х7 пикселей, масштабируется в 5 раз, т.е. получаем в одном символе 875 пикселей или 1750 байтов или 14000 битов. На экране 5 символов, т.е. всего выводится 70000 битов. При частоте SPI 4 МГц и оптимальном кодировании это составит порядка 50 fps.
У Adafruit другой немного порядок
Adafruit_ST7789(int8_t cs, int8_t dc, int8_t rst);
Так не в этом дело, I2C отказывается корректно работать при коде
ACSR = _BV(ACI)
| _BV(ACIE)
| _BV(ACIS0) | _BV(ACIS1);
TCCR1A=0; TIMSK1 = 1<<TOIE1;
TCCR1A=1<<COM1A0;
TCCR1B=0;
А на нём построен проект, придётся отказаться от дисплея походу в пользу другого, менее эффектного.
При чем тут вообще I2C?
Ошибся, SPI, думал об одном, написал другое.
