У меня вчера была маленькая радость в 3 часа ночи: синтаксис языка улучшился настолько, что код на ПХП, который выдала ИИшка по запросу “напиши-ка мне фильтр Калмана на современном ПХП” запустился и отработал:
Исходный кот
<?php
class KalmanFilter
private float $r; // Process noise covariance
private float $q; // Measurement noise covariance
private float $a; // State transition matrix
private float $b; // Control matrix
private float $c; // Measurement matrix
private float $Cov;
private ?float $x = null; // Estimated signal value
* KalmanFilter Constructor
* @param float $r Process noise (how much we expect the system to wiggle on its own)
* @param float $q Measurement noise (how much jitter/noise your sensor has)
* @param float $a State vector
* @param float $b Control vector
* @param float $c Measurement vector
public function __construct(
float $r = 1,
float $q = 1,
float $a = 1,
float $b = 0,
float $c = 1
$this->r = $r;
$this->q = $q;
$this->a = $a;
$this->b = $b;
$this->c = $c;
$this->Cov = 0;
* Filters a new noisy measurement to return a clean prediction.
* @param float $z The raw measurement value
* @param float $u Optional control vector input
* @return float The estimated/filtered value
public function filter(float $z, float $u = 0): float
// 1. Initialize state if this is the first execution
if (is_null($this->x)) {
$this->x = (1 / $this->c) * $z;
$this->Cov = (1 / $this->c) * $this->q * (1 / $this->c);
return $this->x;
// 2. Prediction step
$predX = ($this->a * $this->x) + ($this->b * $u);
$predCov = (($this->a * $this->Cov) * $this->a) + $this->r;
// 3. Update / Correction step
$kalmanGain = $predCov * $this->c * (1 / (($this->c * $predCov * $this->c) + $this->q));
$this->x = $predX + ($kalmanGain * ($z - ($this->c * $predX)));
$this->Cov = $predCov - ($kalmanGain * $this->c * $predCov);
return $this->x;
* Get the current state estimate
public function getState(): ?float
return $this->x;
// Tuning parameters:
// R (Process Noise) = 0.01: We assume the true value is mostly stable.
// Q (Measurement Noise) = 1.00: We trust our raw data less because it's noisy.
$filter = new KalmanFilter(0.01, 1.00/*, 1.0, 0.0, 1.0*/);
// Simulated noisy incoming data stream
$noisyData = [10.5, 9.2, 11.1, 8.9, 10.8, 9.5, 10.1, 11.5, 9.0, 10.2];
echo "Raw Value -> Filtered Value\n";
echo "---------------------------\n";
foreach ($noisyData as $reading) {
$corrected = $filter->filter($reading);
printf("%6.2f -> %6.4f\n", $reading, $corrected);
Чтобы это произошло понадобилось добавить поддержку типизации в классы. Но самый геморой, занявший неделю, было добавить короткий синтаксис массивов:
$array = array(1,2,3) // <-- по-старинке
$array = [1,2,3] // <-- по-новому
Вложенные массивы и прочее поддерживаются так же:
$b = [[1,2],[3,4]];
$c = ['x'=>[1=>2], 'y'=>3];
echo [1,2,3][1]; // выведет "2"
function &foo() : array {
return [4,5,6];
echo foo()[0]; // выведет "4", в ZendPHP такое не скомпилируется
Раз уж Zend PHP8 и PH8 уже довольно сильно расплылись по языковым фичам, то я решил добавлять вещи, которых в обычном PHP нет. Например - структуры, чтобы можно было лазить по заголовкам бинарных файлов или, скажем, рулить MMIO регистрами. В планах
Что еще.. А, функции-стрелки добавил. Как по мне - масло маслянное, но пусть будет:
$a = fn(int $x) => $x*$x;
// по-старинке было так: $a = function(int $x) {return $x * $x;};
echo $a(2); // напечатает 4
Переделал фомат байткода, чтобы туда зашить еще и номера строк исходника. Нужно это было для того, чтобы правильно печатать номера строк в исключениях. Размер инструкции при этом не увеличился - номер строчки запихал в неиспользуемое место каждой инструкции.
Сделал небольшрй дизассемблер, чтобы было видно скомпилированный код перед исполнением:
@function "hell"
.arg "$a" ; function argument
.arg "$b" ; function argument
.section @defarg b
#00000000: LOAD.C 0 4 0; line 3
#00000001: LOAD.C 0 4 0
#00000002: ADD 0 0 0
#00000003: LOAD.C 0 4 0
#00000004: ADD 0 0 0
#00000005: LOAD.C 0 4 0
#00000006: ADD 0 0 0
#00000007: DONE 1 0 0
.ends
